Hp elitebook 840 g5 bios password
  • piotrekw27
    • Aug 2023
    • 5
    • Polska
    #241
    Originally posted by hoaca388
    VVV
    hoaca388 Thank You but it still asks for the password on your file.
    Vesko356 I don't think there's an option to edit the post, so I'm adding the info here​
    HP EliteBook 840 G5
    CTNumber 6GPRH05TZBF809
    Product 2FA66AV
    Serial 5CG8509CWB
    Build Id 17WWCSBT602#SABD#DABD
    • hoaca388
      Badcaps
      • Jan 2022
      • 11885
      #242
      HP EliteBook 840 G5
      Product 2FA66AV
      Serial 5CG8509CWB
      Again
      • piotrekw27
        • Aug 2023
        • 5
        • Polska
        #243
        Thank you very much hoaca388​ , with this file the laptop starts in "manufactured" mode (I guess that's how it should be?), after filling in the missing data in the BIOS, everything works as it should. I would like to know how to unlock the 32MB bios myself, but it's probably a secret? Thank you again for your help and best regards
        • gctdpacov
          • Nov 2022
          • 43
          HP Elitebook 840 G5
          Serial Number : 5CG9183NQT
          Password Remove please
          Attaching Backup Bios
          • rex98
            • Feb 2023
            • 1281
            • Mandaue CEBU, Philippines
            #245
            Originally posted by gctdpacov
            HP Elitebook 840 G5
            this file is not the main bios. find the other chip 32mb and upload here.
            • gctdpacov
              • Nov 2022
              • 43
              attaching other chip
              • rex98
                • Feb 2023
                • 1281
                #247
                only flash this ec. use RC unlocker in all HP 16MB ec next time.
                • vagabont78
                  • Jan 2017
                  • bulgaria
                  #248
                  Hi, i blown resistor next to 16mb bios chip. Does someone knows what value is it?
                  • qayyum786
                    • Aug 2018
                    • 1933
                    • INDIA
                    #249
                    If it is attach with pin 6 than its a SPI_CLK resistor
                    you can take a reverence of any schematic which has 25Q128JVPQ
                    (you can check pin 5 resistor value and place same ohm on missing resistor )
                    • vagabont78
                      • Jan 2017
                      • bulgaria
                      #250
                      Resistor is between pins 7 and 8
                      • qayyum786
                        • Aug 2018
                        • 1933
                        • INDIA
                        #251
                        you may try with 10K or 3.3K
                        • ay_bulut
                          • Feb 2016
                          • 114
                          • turkey
                          #252
                          The fan spins once, the charging light flashes. can you fix the bios?
                          HP EliteBook 840 G6
                          serial : 5CG9443TMY
                          • rex98
                            • Feb 2023
                            • 1281
                            #253
                            HP EliteBook 840 G6
                            serial : 5CG9443TMY
                            you posted in wrong thread this thread is for 840 G5 only.
                            • -=Leroy=-
                              • Jan 2024
                              • 10
                              Removing BIOS Password please
                              HP Elitebook 840 G5
                              S/N : 5CG936B9WW
                              Attaching BIOS dump of MX25L256 Chip
                              Thank you...
                              • qayyum786
                                • Aug 2018
                                • 1933
                                • INDIA
                                #255
                                HP Elitebook 840 G5
                                S/N : 5CG936B9WW
                                Thank you...
                                post EC backup
                                • -=Leroy=-
                                  • Jan 2024
                                  • 10
                                  post EC backup
                                  I found this chip on the backside of the board on U366 : ISSI IC25LP128
                                  I guess this is the EC , right?
                                  I have to unsolder the chip with my hot air station and will post the dump.
                                    Vesko356 commented
                                    Editing a comment
                                    Yes, U366 - ISSI IC25LP128 is indeed the EC memory chip.
                                • rex98
                                  • Feb 2023
                                  • 1281
                                  #257
                                  HP Elitebook 840 G5
                                  S/N : 5CG936B9WW
                                  Thank you...
                                  i don't know why i cant upload directly a file so i attached this link instead.
                                  no need EC file.
                                  first boot press f10 apply factory setting to defaults and exit, and 2nd boot reset security settings to defaults.
                                  here's your DMI info use BCU:
                                  Serial Number: 5CG936B9WW
                                  Product Number: 2FA64AV
                                  CT Number: PGWHQ00WBCQ2YU
                                  Description: HP EliteBook 840 G5
                                  build_id: 17WWCSCT601#SABD#DABD
                                  Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAfXhKhkjh.Rq
                                  MAC Address: 04-0E-3C-CC-6D-C6
                                  MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
                                  • -=Leroy=-
                                    • Jan 2024
                                    • 10
                                    no need EC file.
                                    Thank you very much!
                                    Your patched bios file worked perfect without touching the EC chip.
                                    • deeptenk
                                      • Sep 2023
                                      • 10
                                      • Belarus
                                      #259
                                      RCUnlocker can delete computrace lock? Sorry, this is my first time encountering this. The laptop was blocked for organization; the laptop was scrapped. I was able to fix it, it did not turn on, but I see a blockage when installing windows.
                                      computro 6050a2945601-mb-a01(1a)
                                      HP Elitebook 840 G5
                                        • 21173
                                        RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                                        You MUST:
                                        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          >Read BIOS guides, methods, resources and tools
                                          Ack
                                          >Try the method at BIOS guides, methods, resources and tools before requesting help
                                          Ack
                                          >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                          python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                          01-30-2025, 04:26 AM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
                                        • BlackVisor
                                          How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                                          by BlackVisor
                                          RedmiBook Pro 1542022 6800H
                                          SKU: TM2113-39463
                                          Model Number: RMA2204-AB
                                          CMIIT ID: 2022AP1835
                                          SN: 39463/22WD01355
                                          BIOS version: RMARB5B0P1010 20230628
                                          1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                                          2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                                          3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                                          01-14-2024, 06:35 AM
