Dell xps 13 9350 bios bin
  • medinfo
    • May 2016
    • 331
    • Morocco
  • sorinac
    • Jul 2013
    • 123
    • Romania
    Re: Dell xps 13 9350 bios bin
    please supply board info
    also check https://www.badcaps.net/forum/showthread.php?t=52792
    • medinfo
      • May 2016
      • 331
      • Morocco
      Aaz80 la-c881p rev : 1.0 (a00)
      chips size : 16 mb
      • mielta
        • Apr 2015
        • 368
        Mistake
        • mielta
          • Apr 2015
          • 368
          Hi
          Try this
          • salwan
            • Sep 2017
            • us
            I need Dell XPS 13 9350 bios bin pleasssssssssssssssssssse
            And this bios size should be 32 MB
            Thanks!
            • faisalali
              • Mar 2016
              • 25
              • pakistan
              need bin file AAz80 LA-c881p Rev: 1.0{A00}
              here is ec and main. need 8mb or 2mb
              plz help its urent
              • bryanpoints
                • Aug 2017
                • 57
                • Philippines
                need bios bin file
                AAZ80 LA-C881P
                Rev 2.0 (A01)
                core i7 7th gen
                thanks
                • xps9350
                  • Mar 2020
                  • Uganda
                  it says that size is larger than the chip, nybody knows how to fix this? im trying to flush it with the usb programmer ...thx
                  • Xman12
                    • Feb 2020
                    • 26
                    • Bangladesh
                    • fady foox
                      • Oct 2017
                      • 7
                      • cairo
                      need bios bin file
                      AAZ80 LA-C881P
                      Rev 2.0 (A01)
                      core i7 7th gen
                      • peste
                        • Dec 2016
                        • 13718
                        • ROMANIA
                        put the bios backup here
                        • fady foox
                          • Oct 2017
                          • 7
                          • cairo
                          i need bios
                          uh8 - ut5 - ut6
                          pleeese
                          • fady foox
                            • Oct 2017
                            • 7
                            • cairo
                            i am sooooory this bios its working
                            thank you for taking care of me
                            • lngcs
                              • Jul 2011
                              • 72
                              Hi Everyone, i have an xps p54g board label la-c881p rev 2.0. needed a good bios or help me repair my old one. thanks
                              • peste
                                • Dec 2016
                                • 13718
                                • ROMANIA
                                Originally posted by lngcs
                                hi everyone, i have an xps p54g board label la-c881p rev 2.0. Needed a good bios or help me repair my old one. Thanks
                                try...
                                  • 22077
                                  Try this bios. Your service tag config has non-vpro ,no AMT .
                                  • elaamraouiyouness
                                    • Feb 2017
                                    • 9
                                    • morroco
                                    Pleas i need dump bios dell xps 13
                                    DAD13BMBCC1 REV C
                                    • desone01
                                      • Sep 2020
                                      • 14
                                      Does anyone know what the UART connector adjacent the bios chip on the Dell XPS 13 9350 motherboard is for? It appears to be a Dell engineer's method of flashing the bios on a dead motherboard. I have three of these boards in non working computers. I haven't pulled them completely apart as yet in order to get the Dell part numbers as yet.
                                      I have searched Google extensively in order to identify the plug which connects to this UART connector but haven't found one as yet. It is a 4 pin connector.
                                      I did manage to cut a ribbon cable in two with 4 ribbons which seem to connect perfectly with the pins when a small plastic shim is wedged behind the cable. It's not an ideal fix but i think it will do the job. I also have an Willem eprom burner on order and I think that will do the job on the two completely dead motherboards.
                                      The bios or corruption of it seems to be a real problem with these particular motherboards.
                                      I have one of these computers which I am using now and "touch wood" it's been flawless up to now.
                                      • Shevy57
                                        • Feb 2020
                                        • 6
                                        • uganda
                                        Originally posted by peste
                                        try...
                                        Gives 2 amber and 5 white led blinks. RAM Error
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                        • Sathsul
                                          Dell Latitude 5431 issues with dumping bios
                                          by Sathsul
                                          So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                                          The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                                          However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                                          10-28-2025, 07:49 AM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
