Dell xps 13 9350 bios bin
    Re: Dell xps 13 9350 bios bin
    I need ut6 and ut5 bios please
      Originally posted by peste View Post
      try...
      try help me clean me pls
        I have a problem with the bios file Lenovo T450NM-A251. I deleted the original by mistake and tried many files, but the computer turns on and there is no display
        Please help me
          Please help me
          Wrong topic.
          https://www.badcaps.net/forum/showth...ht=Lenovo+T450
          Become a Badcaps supporter
          Thanks to all supporters.
            notebook got bios password mobo code is:la-c881p need help to remove password
              dell xps 13 aaz80 la-c881p rev:1.0 [a00]
              processor:sr2ez.
              Requesting clear me bios;machine has no display.
                processor:sr2ez.
                anybody with this file plizzzz
                  processor:sr2ez.
                  Here's your New BIOS, try it and let me know.
                  Service Tag: GQJS662.
                  all donations are welcome,
                    Kindly Rebuild Bios Dell XPS 13 9350 due to system error during update
                    Dell XPS 13 9350
                    AAZ80 LA-C881P REV: 2.0 (A01)
                    I can't boot after update due to the process was not successful and can't reboot!
                    Chip : Winbond 25Q128BV
                    MTKS Best regards
                      Re: Kindly Rebuild Bios Dell XPS 13 9350 due to system error during update
                      Originally posted by chinsuckseed View Post
                      Dell XPS 13 9350
                      MTKS Best regards
                      Your file isn't good, try to read the Chip again correctly.
                      Also write your device Service Tag.
                        Hi This is my service tag : J5P1LC2
                        Express Service Code 41703259970
                        Thank you very much
                          Sorry I dump after it failed to update hope that it's incomplete file
                            try...
                            thanks working for me
                              Hi, can you please fix BIOS? After board repair no boot, no AC_Present, it blinks 2 white and 5 amber. tried diferent other BIOS dumps - didn't work.
                              AAZ80 LA-C81P Rev. 2.0
                              Service Tag: 2D3GHC2
                                Motherboard Number should be "LA-C881P" not "LA-C81P".
                                  Thank You for helping, but same blinking 2 times amber, 5 times white. Maybe fault elsewhere, wanted to reflash EC but didn't find EC dump.
                                  Maybe I should change EC chip if it doesn't give EC_Present signal.
                                    Hello @hardware1, was wondering if you can please help me take a look at my 9350 dump and see if it's recoverable? I am sorry I don't know how/where to locate the board number. the ST is GJ2B562. appreciate your help. thank you
                                      You didn't mention your device problem, you can also try the BIOS from post #35 and see if it will works fine or gives you same symptoms.
                                        Thank you for your feedback. The unit powers on briefly and does a 2 amber 2 white blink code repeatedly until it powers itself off. Searching online would suggest this is a BIOS/ROM issue. I tried flashing the ROM from #35 as per your suggestion but the unit is still exhibiting the same behavior so it doesn't appear to be a BIOS problem. Looks like there's a deeper issue with the MOBO, unfortunately, and is beyond my skill level. I do appreciate your help.
                                          its invalid memory
