Dell xps 13 9350 bios bin
  • medinfo
    • May 2016
    • 328
    • Morocco
  • sorinac
    • Jul 2013
    • 123
    • Romania
    Re: Dell xps 13 9350 bios bin
    please supply board info
    also check https://www.badcaps.net/forum/showthread.php?t=52792
    • medinfo
      • May 2016
      • 328
      • Morocco
      Aaz80 la-c881p rev : 1.0 (a00)
      chips size : 16 mb
      • mielta
        • Apr 2015
        • 368
        Mistake
        • mielta
          • Apr 2015
          • 368
          Hi
          Try this
          • salwan
            • Sep 2017
            • us
            I need Dell XPS 13 9350 bios bin pleasssssssssssssssssssse
            And this bios size should be 32 MB
            Thanks!
            • faisalali
              • Mar 2016
              • 25
              • pakistan
              need bin file AAz80 LA-c881p Rev: 1.0{A00}
              here is ec and main. need 8mb or 2mb
              plz help its urent
              • bryanpoints
                • Aug 2017
                • 56
                • Philippines
                need bios bin file
                AAZ80 LA-C881P
                Rev 2.0 (A01)
                core i7 7th gen
                thanks
                • xps9350
                  • Mar 2020
                  • Uganda
                  it says that size is larger than the chip, nybody knows how to fix this? im trying to flush it with the usb programmer ...thx
                  • Xman12
                    • Feb 2020
                    • 26
                    • Bangladesh
                    • fady foox
                      • Oct 2017
                      • 7
                      • cairo
                      need bios bin file
                      AAZ80 LA-C881P
                      Rev 2.0 (A01)
                      core i7 7th gen
                      • peste
                        • Dec 2016
                        • 12941
                        • ROMANIA
                        put the bios backup here
                        • fady foox
                          • Oct 2017
                          • 7
                          • cairo
                          i need bios
                          uh8 - ut5 - ut6
                          pleeese
                          • fady foox
                            • Oct 2017
                            • 7
                            • cairo
                            i am sooooory this bios its working
                            thank you for taking care of me
                            • lngcs
                              • Jul 2011
                              • 69
                              Hi Everyone, i have an xps p54g board label la-c881p rev 2.0. needed a good bios or help me repair my old one. thanks
                              • peste
                                • Dec 2016
                                • 12941
                                • ROMANIA
                                Originally posted by lngcs
                                hi everyone, i have an xps p54g board label la-c881p rev 2.0. Needed a good bios or help me repair my old one. Thanks
                                try...
                                  • 21145
                                  Try this bios. Your service tag config has non-vpro ,no AMT .
                                  • elaamraouiyouness
                                    • Feb 2017
                                    • 9
                                    • morroco
                                    Pleas i need dump bios dell xps 13
                                    DAD13BMBCC1 REV C
                                    • desone01
                                      • Sep 2020
                                      • 14
                                      Does anyone know what the UART connector adjacent the bios chip on the Dell XPS 13 9350 motherboard is for? It appears to be a Dell engineer's method of flashing the bios on a dead motherboard. I have three of these boards in non working computers. I haven't pulled them completely apart as yet in order to get the Dell part numbers as yet.
                                      I have searched Google extensively in order to identify the plug which connects to this UART connector but haven't found one as yet. It is a 4 pin connector.
                                      I did manage to cut a ribbon cable in two with 4 ribbons which seem to connect perfectly with the pins when a small plastic shim is wedged behind the cable. It's not an ideal fix but i think it will do the job. I also have an Willem eprom burner on order and I think that will do the job on the two completely dead motherboards.
                                      The bios or corruption of it seems to be a real problem with these particular motherboards.
                                      I have one of these computers which I am using now and "touch wood" it's been flawless up to now.
                                      • Shevy57
                                        • Feb 2020
                                        • 6
                                        • uganda
                                        Originally posted by peste
                                        try...
                                        Gives 2 amber and 5 white led blinks. RAM Error
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                        • gizaha
                                          by gizaha
                                          02-13-2024, 07:18 AM
                                        • mrrubik
                                          Dell Optiplex 7010 micro bad BIOS flash?
                                          by mrrubik
                                          Hi folks,
                                          I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                          After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                          Steps I took:
                                          1. Read BIOS with CH341a, verified hash twice
                                          2. Patched
                                          12-23-2024, 04:11 PM
                                          DELL XPS 9350 Notebook 13 Specification for Upgrade or Repair
                                          This specification for the DELL XPS 9350 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 9350 boardview and 9350 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL XPS 9350 Notebook...
                                          09-06-2024, 07:11 AM
