Dell XPS 13 bios needed
  • naeemshahzad
    • Jan 2015
    • 129
    • uae
    Hi i need Dell XPS bios dump motherbord number is DAD13CMBAG0 RGF2V
    MODEL : D13C thanks
  • kotnatan
    Banned
    • Apr 2014
    • 181
    • Ukraine
    Re: Dell XPS 13 bios needed
    Try this DELL XPS13 DAD13CMBAG0 REV G BIOS
    • naeemshahzad
      • Jan 2015
      • 129
      • uae
      not working
      • quic307
        • Jun 2015
        • 259
        • Greece
        Works fine to me...
        • ilian359
          • Dec 2015
          • 5
          • Bulgaria
          Works fine for me too. Thank you!
          • lenovo gala
            • Aug 2017
            • 1
            • uae
            thanks
            • jatoi
              • Jan 2015
              • 84
              • pakistan
              • vougheart
                • Jul 2020
                • 65
                • philippines
                tested thank you
                • ismaelstepheno
                  • Jun 2020
                  • 231
                  • UE
                  Thank you its working
                  • ismaelstepheno
                    • Jun 2020
                    • 231
                    • UE
                    This one works perfectly because the one that is posted works too but in my laptop takes a little to show the image this one posted with clean region me
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • mikeybass
                      Dell 9010 MT BIOS Update Always Fails
                      by mikeybass
                      Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
                      04-23-2025, 04:30 PM
                    • capoplays
                      Help with BIOS update on Dell G15 5515 after chip replacement
                      by capoplays
                      Hey everyone,
                      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                      When I check the BIOS using the F12 menu Flash...
                      10-24-2025, 06:53 AM
                    • Akhlz001
                      Dell Pro 13 Plus PB13250 Bios Unlock
                      by Akhlz001
                      Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                      09-20-2025, 07:15 PM
                    • 417731
                      BIOS needed for Dell Vostro 3405
                      by 417731
                      Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                      Model: Dell Vostro 3405
                      Tag:F0B1YF3
                      CPU:Ryzen 3500U
                      Thanks in advance
                      07-06-2025, 06:48 PM
