Dell G15 5515 La-k454p rev 1.0 Bios Bin Need
  • yukselen
    yukselen
    • Jun 2021
    • 41
    • türkiye
    #81
    Originally posted by yukselen
    DELL GDL5L LA-K454P REV.1
    SN.6K4L9L3
    I CANNOT INSTALL WINDOWS
    IT FLASHES AND REBOOTS
    CAN YOU FIX IT?
    Could you please help me
      • 21922
      try this bios https://www.badcaps.net/forum/troubl...13#post3650213
      • Adiham
        • Aug 2025
        • France
        #83
        Hello, I need help with a Dell 5515 S.T laptop: 27QXQL3 The problem is that the laptop stopped booting Windows. The fan starts and stops continuously. Thank you
        • hoaca388
          Badcaps
          • Jan 2022
          • 12330
          #84
          Inspiron 5515
          Service Tag: 27QXQL3
          • Adiham
            • Aug 2025
            • France
            #85
            Originally posted by hoaca388
            Inspiron 5515
            Thank you for your reply. I tried to use this file, but my laptop won't start at all with it. Do you have another solution?
            Thank you.
            • Maxsupri Informatica
              • Mar 2024
              • 3
              • Brazil
              #86
              Hi, I need help with a Dell G15 Ryzen Edition that shows 2 amber and 1 white (possible processor failure)
              Service Tag: 77FWVM3
              Express Service Code: 15687467787
              It's already been in another repair shop, and I believe the BIOS I backed up isn't the original because I couldn't find the DMI data.
              LA-K453P Rev: 1.0
              BIOS ic Winbond 25Q128JVSQ​
              • LBTT1121
                • Nov 2024
                • 1020
                • Việt Nam
                #87
                LA-K453P Rev: 1.0
                try https://www.badcaps.net/forum/troubl...13#post3605413
                  • Mar 2024
                  • 3
                  • Brazil
                  #88
                  thank you, I tried this one but it didn't work
                  • capoplays
                    Help with BIOS update on Dell G15 5515 after chip replacement
                    by capoplays
                    Hey everyone,
                    I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                    The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                    When I check the BIOS using the F12 menu Flash...
                    10-24-2025, 06:53 AM
                  • NotEnough
                    Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                    by NotEnough
                    I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                    What I've Tried So Far:
                    • Reseated the cables.
                    • Reinstalled AWCC and AlienFX services.
                    • Attempted BIOS downgrade but no improvement.
                    • Inspected ribbon cables for damage.
                    • Explored the possibility of BIOS or
                    10-19-2024, 01:34 AM
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
                  • DavidChunco
                    Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
                    by DavidChunco
                    Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
                    - Receive help from Dell Support (it is out of warranty).
                    - Disconnect machine from AC power and battery overnight.
                    - BIOS recovery process
                    - Connected external display via HDMI
                    - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
                    03-15-2025, 11:00 AM
                  • mikeybass
                    by mikeybass
                    04-23-2025, 04:30 PM
