Dell G15 5515 La-k454p rev 1.0 Bios Bin Need
DELL G15 5515 BIOS password forgotten
Please remove bios password
ST: 28Y9JP3
EX: 4894846455Attached FilesComment
Attached Files↵
https://www.badcaps.net/donateComment
I have this Dell G15 5515 that is fixed now. However, it is doing everything except posting. I suspect the bios is corrupted.
Please, help me fix the bios file.
ST# C3Z2YF3
EX: 26361711039
Thank you.
Hi, can someone help me, please.
dell g15 5515 ryzen edition
Service Tag: H43DZJ3
Express Service Code: 37252855839
Maybe my BIOS is corrupted. I'm not sure, but I think it happened after an update. It rebooted and now it shows a black screen.
I stripped the last 1K from the file to make it match the size. However, after reflashing the bios, computer is not even attempting to boot. I tried another bios file from this thread and the computer boots but with obviously the wrong service tag number.
Can you do me a favor and fix the bin file I posted in post 44 ? Thank you.Comment
Good afternoon, I need help with a Dell G15 5515 S.T laptop: GZWW7K3 The problem is that after updating the BIOS, the laptop stopped booting Windows and updating the BIOS from a flash drive. Please tell me what the problem could be. Thanks for the answerComment
etc.Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Dell G15 5515
I tried reinstalling the BIOS several times, but it didn't work. Every time the problem remains the same (hanging on the logo, endless boot. Booting from a flash drive also doesn't work. The SSD is recognized in the BIOS but doesn't boot. Please help.
Dell G15 5515
S.n GZWW7K3
Maybe someone have VBios and Bios files I want to try change both. that youComment
Dell G15 5515 Ryzen edition
GZWW7K3
In internet see dell 5510 it's intel processor
I am not sure if it works on Ryzen editionComment
- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Use search function in case someone already answered your request
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
- Name your thread with make, full model numbers and request
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
- Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
Here is a bin file that has been a life-saver in the past several times. It was extracted from a G15 5515 machine with a R7 CPU and RTX 3060 graphics card. Last usage: a similar model came with 2 ember/1 white light flashing pattern indicating CPU issue.
After applying this bin file, computer booted just fine. It will ask you to type the service tag#.
Let me know if this bin works for you.
by NotEnoughHi everyone,
I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
What I've Tried So Far:- Reseated the cables.
- Reinstalled AWCC and AlienFX services.
- Attempted BIOS downgrade but no improvement.
- Inspected ribbon cables for damage.
- Explored the possibility of BIOS or
Channel: BIOS Requests ONLY!
by DavidChuncoHi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
- Receive help from Dell Support (it is out of warranty).
- Disconnect machine from AC power and battery overnight.
- BIOS recovery process
- Connected external display via HDMI
- Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...-
by mikeybassHi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
04-23-2025, 04:30 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
- Loading...
