Dell G15 5515 La-k454p rev 1.0 Bios Bin Need
  • Oleksandr Ivakhnenko
    • May 2025
    • 6
    • Dublin
    #61
    Thanks for this Bios, it works, but still have a problem with booting. Laptop switch on I can open a Bios but windows not started, infinity loading. I try installing new windows but from usb same problem infinity loading.
    I want to try install new VBios, maybe you have it from same laptop?
    • trepachka
      • Oct 2022
      • 429
      I would run memory test to make sure your RAM is fine. Then, I would attempt to do built-in hardware troubleshooting by hitting F12 key on start.
      My only experience with infinite loops has been involved CPU issues, in particular one or more pins losing their bond with the motherboard. In that case reflowing the CPU may do the trick.
      I doubt the issue is with the graphics card.
        • May 2025
        • 6
        • Dublin
        #63
        This happened after windows update, before everything works perfectly.
        So I think, need to try change VBios. It's last what I didn't try
        • hcinne
          • Jul 2024
          • 9
          • Algeria
          #64
          Vbios for Dell G15 5515 Ryzen Edition i got asked for it here in the forum so i decided to upload it for everyone i extracted it from a working laptop the file should be flashed onto the 25Q16JWSIQ chip
          • Raven7032
            • Mar 2025
            • 8
            • RU
            #65
            Please help with bios. Have dell g15 ryzen5 edition that shows 2amber and 1white, noticed that this might be bios problem. Tryed different bios from this topic but its not working.
            ST: 2S58ZK3, board GDL5L LA-K454P rev: 1.0 (A00). Thank you!
            • hoaca388
              Badcaps
              • Jan 2022
              • 11815
              #66
              • hoaca388
                Badcaps
                • Jan 2022
                • 11815
                #67
                The file you posted is not native to your machine, and I don't see anything wrong with it. You should look elsewhere for the problem
                • Raven7032
                  • Mar 2025
                  • 8
                  • RU
                  #68
                  I extracted this file from bios chip W25Q128FW with CH341 programmer. So, I assume, that someone flashed it and laptop bricked? So, my way is to get original BIOS file from dell site and flash it? Sorry for noob quiestion, just my first time dealing with this kind of problem. I flashed 3 different bios that found here for my machine, but cant localize problem.
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11815
                    #69
                    Find hardware problem.
                    • Raven7032
                      • Mar 2025
                      • 8
                      • RU
                      #70
                      trying, but no progress
                      Dell G15 Ryzen Edition (LA-K454P) – No SPI Activity, No Boot, No startup - Badcaps
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 11815
                        #71
                        Dell G15 5515 Ryzen Edition non DMI.
                        • PacoGT
                          • Sep 2022
                          • 97
                          • Guatemala
                          #72
                          DELL G15 RYZEN EDITION
                          SN:6V54NJ3
                          PROBLEM 1 WHITE 2 AMBER
                          CAN REPAIR THE BIOS FILE¡?
                          • hoaca388
                            Badcaps
                            • Jan 2022
                            • 11815
                            #73
                            SN:6V54NJ3
                            # 71
                            • Archristol
                              • Jul 2025
                              • 3
                              • US
                              #74
                              Hi guys, I'm super new here but have been looking at the different bin files posted to try and fix my friend's laptop. None of them will work, however, as the chip W25Q16JWSSIQ is only 2mb large.
                              I asked for the help of AI to help me summarize the issue:
                              BIOS Dump Extraction Issue – Dell G15 5515 / W25Q16JWSSIQ Flashing
                              I'm trying to extract a 2MB flashable BIOS region from a full 16MB dump (BIOS-UEFI [0x00A94A8D-0x01A94A8D].bin) intended for a Dell G15 5515 laptop. The goal is to flash this onto a W25Q16JWSSIQ chip using a CH341A programmer.
                              Using UEFITool NE, I found a firmware volume (EfiFirmwareFileSystem2Guid) inside the dump, but it spans ~19MB, which is too large for the target chip. I tried locating the $FV signature via HxD (5A 56 00 00), but couldn’t find it—possibly due to alignment or non-standard headers.
                              I’m now searching for a clean 2MB slice with valid UEFI structures that match the chip’s layout, but I’m unsure where to start the offset or how to validate the slice properly. Any tips on locating the correct region or dealing with OEM volume layouts would be appreciated!
                              To be clear, I haven't done this before. Any help would be appreciated!
                              My friend's laptop:
                              • Dell G15 Ryzen Edition
                                • MFGYR: 2021
                                • ST: 16118K3
                                • EX: 2541316755
                              What I'm using:My friend's backup bios:What I've extracted from the Dell BIOS exe:Thank you for having this forum!
                              • hoaca388
                                Badcaps
                                • Jan 2022
                                • 11815
                                #75
                                My friend's laptop:
                                  • MFGYR: 2021
                                  • ST: 16118K3
                                  • EX: 2541316755
                                W25Q16JWSSIQis not bios chip.
                                • Archristol
                                  • Jul 2025
                                  • 3
                                  • US
                                  #76
                                  W25Q16JWSSIQ is not bios chip.
                                  Sorry, it might be W25Q16JVSSI. It is hard to read.
                                  But a gentleman from YouTube said I could use the W25Q16JV or W25Q16BV setting on NeoProgrammer. When I plugged the programmer, it detected W25Q16FW.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11815
                                    #77
                                    Look for the chip with the number 128 (Ex: W25Q128JWSSIQ) because the bios file for this model is 16MB.
                                    • Archristol
                                      • Jul 2025
                                      • 3
                                      • US
                                      #78
                                      Ah okay. My mistake. Thank you. I found it after taking out the mobo. It is GD25LR128D. The NeoProgrammer doesn't seem to have this chip settings. Can I use another?
                                      Out of curiosity, what does the 2mb bios chip hold?
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11815
                                        #79
                                        I don't know because the content you posted is empty.
                                        • yukselen
                                          yukselen
                                          • Jun 2021
                                          • 34
                                          • türkiye
                                          #80
                                          DELL GDL5L LA-K454P REV.1
                                          SN.6K4L9L3
                                          I CANNOT INSTALL WINDOWS
                                          IT FLASHES AND REBOOTS
                                          CAN YOU FIX IT?
                                          • NotEnough
                                            Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
                                            by NotEnough
                                            I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
                                            What I've Tried So Far:
                                            • Reseated the cables.
                                            • Reinstalled AWCC and AlienFX services.
                                            • Attempted BIOS downgrade but no improvement.
                                            • Inspected ribbon cables for damage.
                                            • Explored the possibility of BIOS or
                                            10-19-2024, 01:34 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • DavidChunco
                                            Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
                                            by DavidChunco
                                            Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
                                            - Receive help from Dell Support (it is out of warranty).
                                            - Disconnect machine from AC power and battery overnight.
                                            - BIOS recovery process
                                            - Connected external display via HDMI
                                            - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with...
                                            03-15-2025, 11:00 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                            11-02-2024, 04:19 AM
