Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
  • NotEnough
    • Oct 2024
    • 5
    I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
    What I've Tried So Far:
    • Reseated the cables.
    • Reinstalled AWCC and AlienFX services.
    • Attempted BIOS downgrade but no improvement.
    • Inspected ribbon cables for damage.
    • Explored the possibility of BIOS or EC firmware issues with various versions, without success.
    • Have realized that similar models like the Alienware M15 R5 have specific keyboard controller drivers available on Dell's support site, hinting at potential cross-model compatibility solutions.
    • Have tried a few other things, if required I can detail in replies.
    Progress and Insights:
    • I've identified that the AWCC fails to recognize the keyboard post-installation, despite being a compatible model.
    • Found out that BIOS downgrades were unsuccessful and blocked by system security features meant to prevent firmware regressions.
    • Found out that the EC is responsible for a "4_Zone_DET" process via schematics to detect presence of 4 zone rgb keyboard.
    • Investigated similar issues found on platforms with no definitive solutions.
    What I Suspect:
    • There could be a BIOS or EC firmware issue preventing the RGB controller from being recognized. Since the hardware is compatible, I'm looking for help with modding BIOS or EC firmware to get the RGB controller working properly or any other fixes.
    • Could also have to do with a driver that's not readily available or installing due to service tag mismatch. Possibly someone can send me their driver files info that has a working rgb g15 setup.
    Seeking Help On:
    • Modding tools, methods, or existing solutions to enable RGB functionality on Dell G15 5515.
    • Any guidance on firmware modifications that might have worked on similar models, or advice from those who've faced and fixed similar issues.
    Thanks in advance for any help you can provide!
  • popzeggey
    • Aug 2019
    • 15
    • ghana
    I know what your issue is. It has to do with an IC that controls the RGB functionality of the keyboard. That chip is directly behind the KB SM/B connector at the other side of the motherboard. I am pretty sure that IC is absent on all G15 5515 motherboards that came with a LED backlight keyboard
    • capoplays
      Help with BIOS update on Dell G15 5515 after chip replacement
      by capoplays
      Hey everyone,
      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
      When I check the BIOS using the F12 menu Flash...
      10-24-2025, 06:53 AM
    • zenius
      by zenius
      12-08-2024, 06:13 AM
    • mikeybass
      by mikeybass
      04-23-2025, 04:30 PM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • Sathsul
      Dell Latitude 5431 issues with dumping bios
      by Sathsul
      So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
      The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
      However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
      10-28-2025, 07:49 AM
