Dell G15 5515 Ryzen Edition Apparently Bricked BIOS Request
  • DavidChunco
    • Mar 2024
    • México
    Hi, I hope someone can help me with this, my Dell G15 Ryzen Edition does not post anymore (black screen, no Windows boot, no BIOS screen) after Windows Update pushed what appears to be a buggy bios image, I've tried the following with no success:
    - Receive help from Dell Support (it is out of warranty).
    - Disconnect machine from AC power and battery overnight.
    - BIOS recovery process
    - Connected external display via HDMI
    - Disassembled machine and found bios chip, its a Gigadevice 25LR128DSIG (GD25LR128DSIG), at first I tried to get it detected by CH341A (with clamp) with no success. It got detected after trying with clamp and motherboard on connected to AC power.
    Problem is I do not have original BIOS backup, and the bios images I have found on the internet for this model, do not work. I am out of ideas, I've seen on internet that it is possible to build the correct bios from original Dell .exe package but I'm not sure how to do it or if it is possible to recover my bios.
    Motherboard shows this model: LA-K453P
    Service Tag is: G0VT7K3
    I hope someone can shed a light on this or it is permanently bricked? Thank you in advance
    pd: sorry for my english, not my native language
  • hoaca388
    Badcaps
    • Jan 2022
    • 12520
    Do you understand what a bios backup is? It's the bios in your computer, back it up even if it's broken, but unfortunately you lost it when you wrote the bios on the internet.
    • capoplays
      • Oct 2025
      • 15
      • South Africa
      HI hoaca388 is this BIN the same for Dell G15 5515 Motherboard GDL56 LA-K453P System Board R7-5800H Processor RTX 3060 6GB 0XF7N6 XF7N6 ? perhaps i can use this to restore my bios
      • String2016
        • Nov 2015
        • 2242
        • philippines
        service tagZ2CGD3
        BOARD CODE:GDL56 LA-K453P REV:1.0
        HI can someone fix this corrupted bios please. the owner update the bios then suddenly the power loss after turned on it stuck at dell logo, the bios is corrupted
        can someone help fix this attached is the original corrupted
          SMDFlea commented
          Editing a comment
          Thread merged.
      • String2016
        • Nov 2015
        • 2242
        • philippines
        I TRIED above post number 2 but no display does anyone can fix my original file plsease
        • danito
          • Jun 2016
          • 1303
          • Romania
          Dell G15 5515 Ryzen Edition, Bios ver. 1.28.1
          • String2016
            • Nov 2015
            • 2242
            • philippines
            danito thank you its working now
            • cr4zychriss
              by cr4zychriss
              • Rebrand: PC Specialist
              11-14-2025, 04:04 PM
            • studdy05
              Bricked HP Probook 450 G7 Bios questions
              by studdy05
              Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
              Ive got...
              07-08-2025, 09:24 PM
            • capoplays
              Help with BIOS update on Dell G15 5515 after chip replacement
              by capoplays
              Hey everyone,
              I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
              The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
              When I check the BIOS using the F12 menu Flash...
              10-24-2025, 06:53 AM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • Loki_Fido
              BIOS for HP 15-an004TX Star Wars Special Edition (8MB BIOS)
              by Loki_Fido
              Hi ya folks,
              I have a HP Star Wars Special Edition laptop for fixing.
              System pulls the right voltage and fan spins but nothing on the screen
              Im leaning towards BIOS.
              Ive checked the BadCaps and found that HP 15-an***** are all 16MB files. But my lap has 8MB file.
              So, i couldn't find my BIOS here.
              Anyone happened to have this BIOS for me?
              Make HP
              Model 15-an004TX
              Star Wars Special Edition Notebook
              ProdID T0Z05PA#ABJ
              SN 5CD5455H39
              BIOS reading <<W25Q64FV [3.3V]>>
              Motherboard marking...
              08-13-2025, 08:10 PM
