Laptop battery charging circuit
This is a sticky topic.
  • huzo
    • Sep 2014
    • 178
    • CROATIA
    #41
    Re: Laptop battery charging circuit
    what about the battery that was long without charging and it's dead now? i open the battery, charge it from external PS, and how to get it to work again,since the managment chip is probably not turning the output...
    i did that multiple times,and it never works...just yesterday, i charged it from external PS,and it's now charged, i plug it in and it doesn't recognize it, it starts to charge for few seconds and that's that...
    • canali
      • Oct 2014
      • 192
      • turkey
      #42
      Thanks..Very useful especially for beginners like me.
      • NBel
        • May 2016
        • 11
        • Moldova
        #43
        Controller inside the battery is becoming locked if the cells were deeply discharged, so even if you charge the cells you need to reset the controller. It can be done with different ways, there are hardware and software tools like NLBA, be2works, etc....
        • kofe
          • Sep 2013
          • 32
          • Estonia
          #44
          Thank You for a great research!
          One question to: AC adapter not detected, wrong AC adapter
          what is AD_ID voltages for HP, Lenovo and other resistive dividers. (Dell has one-wire bus for it). If that ID voltages are model dependant, some examples please.
          Konstantin.
          • cecTech
            • May 2017
            • Philippines
            #45
            Thank you for this useful share.
            I have a question, which pin of kbc will activate the charging ic to charge the battery?
            • doros88
              • Dec 2015
              • 12
              • CYPRUS
              #46
              Thank you for the Information and starting guide for Charger IC !
              • Pino21
                • Jul 2022
                • Costa Rica
                #47
                thank you, good information
                • pacwcbs
                  • Nov 2015
                  • 27
                  • Dominican Republic
                  #48
                  excellent contribution, thanks for sharing
                  • Gau_saha
                    • Feb 2020
                    • 35
                    • India
                    #49
                    Very useful information. THANKS .
                    • sancho76
                      • Nov 2016
                      • 6
                      • United Kingdom
                      #50
                      Nice guide, Thank you!
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3597
                        • slovakia
                        #51
                        what about charger center pins and charger detection circuits?
                        • apolmhoojhaa
                          • Oct 2022
                          • Philippines
                          #52
                          thank you So much.
                          • netgearnetgear
                            • Mar 2022
                            • 30
                            • Trinidad
                            #53
                            Wonderful post. I had a low battery warning recently on a hp 14-018la laptop. Turns out it was the battery that needed to be replaced. Thanks
                            • mvrahie
                              • Jan 2021
                              • 4
                              • South Africa
                              #54
                              Thank you for the information 😊
                              • pappothar
                                • Apr 2023
                                • 6
                                • switzerland
                                #55
                                you guys are really amazing !
                                • dwnisup91
                                  • May 2023
                                  • 11
                                  Great thread! Thank you for sharing.
                                  • mikeondieki
                                    • May 2023
                                    • Kenya
                                    #57
                                    Very educating content thanks a lot it helped
                                    • chandrakant
                                      • Nov 2017
                                      • 38
                                      • india
                                      #58
                                      Thank u
                                      • RetroComputingGrotto
                                        • Aug 2023
                                        • 88
                                        • United Kingdom
                                        #59
                                        Some great information here! I'm currently working on a laptop motherboard that wont power on (no power LED even lighting up) so this information is going to help me a lot in the fault-finding process
                                        • adhiea7x
                                          • Jun 2014
                                          • 7
                                          • 404 not found
                                          #60
                                          Thanks for this wealth of information all in one
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                            MT3608 Step-Up Converter IC Datasheet
                                            The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                                            Internal soft-start results in small inrush current and extends battery life.
                                            The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                                            10-07-2024, 05:02 AM
                                          • Grafnus
                                            Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
                                            by Grafnus
                                            Hey there,
                                            first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
                                            So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
                                            Specs:
                                            • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
                                            • CPU, GPU, RAM work fine (not involved in the Problem)
                                            So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
                                            Now I noticed...
                                            08-06-2025, 11:54 AM
                                          • alro7779
                                            MOSFET? Is its voltage reading normal?
                                            by alro7779
                                            Hello, guys!
                                            Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
                                            06-19-2025, 08:19 AM
