XPS 13 9370 CMOS battery voltage always low
  • questore
    • Dec 2015
    • 574
    • csongrád
    Hi Everyone,
    I have brought you a mistery item
    This laptop have come with some strange faults.
    1. CMOS battery was flat 0v
    Symptoms:
    - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
    Amp drawing was stuck at 0.005 milliamps.
    - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
    After inverstigation RTCD1 diode had a low value (2.5) on pin #1 and measuring the diode turned out to be faulty so I have replaced it. and also CMOS battery to new.
    Now EC won't freeze anymore after removing the AC adapter BUT...
    After some using and turning off and on suddenly the EC resets and shows "CMOS battery failure" 1 white 3 amber LED error. then starts with resetet BIOS.
    So I have started measured CMOS battery and its only 2,6v (new CMOS battery drained as hell)
    removing CMOS battery revealed that even with main Battery connected the RTCVCC is only 2,55V (RTCD1 output is still 3.12V OK)
    After hooking Lab power supply and injecting 3.0V to RTCVCC the board draws 180 milliams !!!! nothing is getting hot and RTCVCC line has a Mohms resistance but something is taking much more power than it should.
    I'm thinking since POWER SW is also connected to this line, maybe this is why the laptop autostarts.
    Do you have any theory why this is happening?
  • mon2
    • Dec 2019
    • 14731
    You can remove the pull-up resistor mated to the power switch and this +RTCVCC rail to investigate if that is a root cause. Each leg of this power rail appears to have a local part that can be temp removed to check if that load is the fault or not.
    Confirm the 2 resistors are ok @ RTCR1 and RTCR2.
    • questore
      • Dec 2015
      • 574
      • csongrád
      Both resistors have a good value.
      • questore
        • Dec 2015
        • 574
        • csongrád
        + What i have managed to figure out. If only AC adapter is plugged in (no main battery or cmos battery) then laptop starts with power button press bios reseted and complains abouth battery voltage low but OK.
        + When only AC adapter plugged in, the board draws 100 milliamps and after about 20 seconds it jumps up to 380 milliamps (in this state, the resistor R251 next to u22 and one spot inside UE3 (MEC5105_WFBGA169) also getting hot (both IC spot are 38 Celsius )
        Click image for larger version  Name:	inverter_en_noreason.png Views:	0 Size:	91.1 KB ID:	3739899
        Its like the inverter is turned on but nothing is connected on that port so why? This happens even when the board is not connected to any of the periferials or screen. The board takes the same amps.
        + R251 value isnormal 240 ohms when measured.
        + When only main battery plugged in then its voltage is dropping to 7.3V (normal standard is 7.6V, battery health is 85% so its good) laptop won't event reacts to power button even when AC adapter is plugged in.
        + When measuring R251 when AC plugged in, it shows 0V on both side so it is pulled to ground .
        Any idea what this means? my suspect is UE3 because it turns on the U22 for no reason but why is u22 pulling inverter line to ground?
        • questore
          • Dec 2015
          • 574
          • csongrád
          After cleaning the board with isopropyl alcohol.
          When applaying 3v on the RTC battery positive, it only takes 15 milliams.
          Symptoms a bit different:
          1. I can start the laptop from AC adapter (no main battery or CMOS battery plugged) (shows battery error led code but starts fine) - OK
          2. After windows in booted i plug in the main battery and remove the AC adapter (windows still fine, and batteryviewer shows 7,9V and runs fine) - OK
          HERE COMES THE STRANGE PART: Measured battery voltage directly with multimeter (7.38V) WHAT?
          3. Shuting down the laptop and I starting again (still only the battery connected) - OK
          4. Shuting down again from battery then plugging in the AC adapter again. After this No reaction to power button and only 5 milliamps draw. FAULT
          • questore
            • Dec 2015
            • 574
            • csongrád
            MORE diagnostics:
            - Mesured RTCBATT line is taking 15 milliamps (seems fine)
            - When a new CMOS battery is plagged after connecting (3.3V battery) it instantly reads only 2.9V
            - (when no main battery plugged but CMOS battery is plugged and AC adapter also plugged) Then starting laptop, shuting down is fine but if i remove the AC adapter and plug it back in the EC again freezees on 4 millimaps draw and no reaction to power button anymore until CMOS battery is unplugged.
            - Cannot reprogramm EC because i found no way to do that.
            Any ideas?
            • questore
              • Dec 2015
              • 574
              • csongrád
              EC has a 85 degree hot spot in the middle, an sends enable to the inverter chip all the time.
              Since i have tryed to get a donor but all 2 of them having similar EC problems does anyone knows how to repogram EC on this machine?
              • reformatt
                • Feb 2020
                • 1536
                LA-E671P motherboard? Uses MEC5105 which according to the SVOD Telegram forum doesn't have internal flash, programming is via SPI. Referring back to another post I did (for a LA-F211P using the same EC), the MEC gets the EC code from the main BIOS chip.
                • Genghis_Khan
                  ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
                  by Genghis_Khan
                  I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
                  Issue summary:
                  Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
                  However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
                  11-11-2025, 11:51 AM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • mkdj
                  ASUS X571 no power : battery issue?
                  by mkdj
                  Mark and model: ASUS X571
                  Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                  Tests already made:
                  - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                  - I have removed...
                  07-14-2025, 09:16 AM
                • techfreak9356
                  Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                  by techfreak9356
                  I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                  09-14-2023, 11:10 PM
                • magistertc
                  CMOS battery drains quickly
                  by magistertc
                  This problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
                  as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
                  Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
                  Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
                  configured to support the RTC and some volatile RAM (when SMPS is on). What you may...
                  07-06-2024, 09:55 AM
