MOSFET? Is its voltage reading normal?
  • alro7779
    Alex
    • May 2025
    • 65
    • Mexico
    Hello, guys!
    Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can recommend me to check out?
    Thanks in advance!
  • harp
    • Jun 2022
    • 648
    • Planet Earth
    On input mosfets it is normal that voltage on gate is about 6v higher then source in order to mosfet switch on with low internal resistance (few miliohm). That results almost neglible voltage drop between source and drain, and helps to mosfets do not over heat. If is voltage on gate lower, eg equal with source, mosfet will switch on with higher resistance (few ohm) which will results big voltage drop on drain and occasionally burn up mosfet...
    • alro7779
      Alex
      • May 2025
      • 65
      • Mexico
      Thanks for telling me that, bro. Now I know that voltage is normal. However, I'll have to keep searching for the problem to be fixed (haven't found the culprit of not having video).
      • Instafixx
        Macbook A2179 820-01958
        by Instafixx
        Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
        The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
        I checked the Power Sequences below and found this -
        Once a valid external power source (Charger or battery) is connected, the following rails will come online.
        PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
        PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
        05-20-2023, 05:19 AM
      • tofik
        MOSFET equivalent K8A60DA
        by tofik
        Hello guys,
        I have a shorted MOSFET K8A60DA with the following characteristics:
        Type Designator: TK8A60DA
        Marking Code: K8A60DA
        Type of Transistor: MOSFET
        Type of Control Channel: N -Channel
        Maximum Power Dissipation (Pd): 45 W
        Maximum Drain-Source Voltage |Vds|: 600 V
        Maximum Gate-Source Voltage |Vgs|: 30 V
        Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
        Maximum Drain Current |Id|: 7.5 A
        Maximum Junction Temperature (Tj): 150 °C
        Total Gate Charge (Qg): 20 nC
        Rise Time (tr): 25 nS
        Drain-Source
        07-19-2023, 05:18 AM
      • crnimrki
        MacBook Pro 820-2327-A, have green light, charge, have normal voltage, no chime
        by crnimrki
        MacBook Pro 820-2327-A, have green light, charge, have normal voltage, no chime. On power on fan spins 5 seconds then stop and again spin and stay spinning.
        CPU Warm, DVD Drive not spinning, Mouse on USB Port inactive. No beeps without RAM DIMM-s.
        PPBUS_G3H - 12.55V without battery, 11.99 with battery charging
        PP3V42_G3H3.39V
        PPVCORE_S0_CPU - 0.98
        RAM VOLTAGE 1.49
        Where to search...
        01-02-2025, 12:51 PM
      • novice1
        Acer Aspire E5-574G - Not Powering On
        by novice1
        Laptop name Acer Aspire E5-574G. Processor = i7-6500u. GPU = NVIDIA GEFORCE 940M. Motherboard Model = DA0ZRWMB6G0
        This laptop was not powering on at all so I started investigating. The blue light would come on for a second, and then disappear. Fan would sometimes turn on for a second and then shut off immediately, and at other times would not turn on at all.
        To start with, about 3 months ago I had no clue about soldering, motherboard schematics, board view, and then I stumbled about this forum and other stuff online. I have never done any of those before. But to ask...
        11-03-2023, 05:53 PM
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
