MT3608 Step-Up Converter IC Datasheet
    • 115474
    The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
    Internal soft-start results in small inrush current and extends battery life.
    The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available in a small 6-pin SOT-23
    package.
    Features
    • Integrated 80mΩ Power MOSFET
    • 2V to 24V Input Voltage
    • 1.2MHz Fixed Switching Frequency
    • Internal 4A Switch Current Limit
    • Adjustable Output Voltage
    • Internal Compensation
    • Up to 28V Output Voltage
    • Automatic Pulse Frequency Modulation Mode at Light Loads
    • up to 97% Efficiency
    • Available in a 6-Pin SOT23-6 Package
    Applications
    • Battery-Powered Equipment
    • Set-Top Boxed
    • LCD Bais Supply
    • DSL and Cable Modems and Routers
    • Networking cards powered from PCI or PCI express slots
    The MT3608 uses a fixed frequency, peak current mode boost regulator architecture to regulate voltage at the feedback pin. The operation of the MT3608 can be understood by referring to the block diagram of Figure 3. At the start of each oscillator cycle the MOSFET is turned on through the control circuitry. To prevent sub-harmonic oscillations at duty cycles greater than 50 percent, a stabilizing ramp is added to the output of the current sense amplifier and the result is fed into the negative input of the PWM comparator. When this voltage equals
    The output voltage of the error amplifier the power MOSFET is turned off. The voltage at the output of the error amplifier is an amplified version of the difference between the 0.6V bandgap reference voltage and the feedback voltage. In this way the peak current level keeps the output in regulation. If the feedback voltage starts to drop, the output of the error amplifier increases. These results in more current to flow through the power MOSFET, thus increasing the power delivered to the output. The MT3608 has internal soft start to limit the amount of input current at startup and to also limit the amount of overshoot on the output.
    MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
    The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
    Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
    10-23-2024, 03:23 AM
  • FrancescoV
    Onkyo HT-R390 no sound output, video output ok
    by FrancescoV
    Good morning everyone,
    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
    The firmware reported is the following:
    M:1.00/11107BLP
    D:?.??/????????
    O:1.00/11107AL
    The DSP firmware given the question marks seems corrupt.
    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
    05-11-2025, 02:59 AM
  • questore
    Looking for a DC-DC step down converter module to replace a 0.75v_ALW output and enable pin
    by questore
    Hello Everyone,
    I need your help, maybe you have know where to buy a replacement.
    I have a NM-D562 laptop motherboard that has a burned 0.75_ALW converter. (the layers and the pins also burned so i dont want to restore it but i need a replacement)
    I have checked with lab power supply output (0.77V) laptop works, so i need a DC-DC module that can do its job.
    According to schematic datasheet what i need on 0.75V_ALW:
    Vout=0.75V±37.5mV
    Vset=0.752V±1.46%
    Vref=0.6V
    TDC=4A
    OCP=9.5A TYP=10.5A MAX
    OVP=(1.15~1.25)*Vout
    UVP=(0.6~0.7)*Vout​...
    11-10-2025, 03:36 AM
    Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
    I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
    https://www.ebay.com/itm/116497313155?var=416785404161
    Here are some of the description from the eBay seller
    The main parameters:
    1. Product name: High-power non-isolated DC boost module power supply.
    2. Product model: 100A2000W.
    3. Input voltage: DC12V-60V.
    4. Input current: 100A (maximum)....
    05-18-2025, 09:45 AM
    Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
    The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
    The bq24745 features dynamic power management...
    10-23-2024, 02:50 AM
