Laptop battery charging circuit
This is a sticky topic.
  • Greg81
    • Jul 2020
    • 12
    Re: Laptop battery charging circuit
    I have a question to the following:
    DCIN/VCC: input voltage from the AC adapter, should be close to AC adapter voltage
    Does the input voltage always come from the AC Adapter? Is the charger IC inactive when running from battery? I was trying to understand the input voltage for Quanta FH5 mainboard, there seems to be no connection to the battery rail although in every IC charger datasheet you read about input from battery and in other schematics VCC is connected to the battery input.
    • piernov
      • Jan 2016
      • 4439
      • France
      Yes indeed, some platforms only have the AC adapter connected to the DCIN/VCC pin of charger IC, and others have the DCIN/VCC pin of the charger IC connected to both battery and AC adapter (through a dual diode).
      I don't have a definitive explanation about it.
      It makes sense to have the battery connected to it if you still use some features of the charger IC like current sensing on battery only, but at the same time some platforms provide these features on battery only even though the DCIN/VCC pin is not connected to the battery. So I assume they take the power internally from the battery rail.
      • Gomez2969
        • Feb 2021
        • 7
        • Republica dominicana
        Thanks so mush
        • lappyfixer
          • Feb 2021
          • england
          thank you for the detailed post piernov, exactly what ive been searching for...
          • Weelcup
            TopTech
            • Oct 2017
            • 307
            Thanks a lot
            • fabio fanesi
              • Jul 2020
              • Italy
              #26
              Thank you so much for the precious informations!!
              • emirich
                • Apr 2021
                • Nigeria
                #27
                • antunes.jrca
                  • Jul 2021
                  • Brasil
                  #28
                  Thanks for this very good topic.
                  • Cuboy
                    • Dec 2018
                    • 27
                    • Spain
                    #29
                    Thank you for the post.
                    • lazaro.089
                      • Jun 2014
                      • 87
                      • Mexico
                      #30
                      Thank you @Piernov!
                      I have a question. I have 2 identical laptops (HP Pavilion Gaming Laptop 15-dk011la)
                      1 does charge the other doesn't. Both batteries charge in one laptop. Both adapters are recognized in both laptops.
                      But one of them refuses to charge the battery. What should I check first?. The battery is detected correctly in the laptop that doesn't charge (powercfg /batteryreport OK). It discharges just fine. But charging doesn't work.
                      Aný ideas?
                      • FaissalDZ
                        • May 2018
                        • 48
                        • Algeria
                        #31
                        Very helpful information, thanks
                        • fauzanmint
                          • Jun 2018
                          • 81
                          • Indonesia
                          #32
                          Thank You
                          • crowntoy99
                            • Oct 2012
                            • 267
                            • india
                            #33
                            Good job bro
                            • mitu_sharma
                              • Jul 2015
                              • 182
                              • india
                              #34
                              great job thanks for sharing
                              • ghalli
                                • Dec 2021
                                • Morocco
                                #35
                                very good informations
                                • laptopservice
                                  • Oct 2013
                                  • 35
                                  • india
                                  #36
                                  thanks
                                  • vesponescassato
                                    • Jan 2021
                                    • italy
                                    #37
                                    Thank you piernov. This helped me a lot understanding how those circuits work!
                                    • Fr4gz0n3
                                      • Feb 2022
                                      • 31
                                      • Italy
                                      #38
                                      Thank you. I helped me a lot.
                                      • rediii
                                        h???, spurrrn
                                        • Mar 2018
                                        • 504
                                        • somewhere in europe
                                        #39
                                        well done, love it
                                        • manuel.it.solution
                                          • May 2020
                                          • 30
                                          • Ghana
                                          #40
                                          Thanks so much
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • questore
                                            XPS 13 9370 CMOS battery voltage always low
                                            by questore
                                            Hi Everyone,
                                            I have brought you a mistery item
                                            This laptop have come with some strange faults.
                                            1. CMOS battery was flat 0v
                                            Symptoms:
                                            - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
                                            Amp drawing was stuck at 0.005 milliamps.
                                            - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
                                            After inverstigation RTCD1 diode had a low value...
                                            09-30-2025, 05:47 AM
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
                                            MT3608 Step-Up Converter IC Datasheet
                                            The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
                                            Internal soft-start results in small inrush current and extends battery life.
                                            The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
                                            10-07-2024, 05:02 AM
                                          • alro7779
                                            MOSFET? Is its voltage reading normal?
                                            by alro7779
                                            Hello, guys!
                                            Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
                                            06-19-2025, 08:19 AM
