ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
  • Boardview and Schematic Bot
    • 116032
    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
    Narrow VDC applications where the system power source is
    either the battery pack or the regulated output of the charger.
    This makes the max voltage to the system equal to the max
    battery voltage instead of the max adapter voltage. Operating
    at lower system voltage can improve overall efficiency. High
    efficiency is achieved in the charger with a synchronous buck
    topology. The low-side MOSFET emulates a diode at light
    loads to improve the light load efficiency and prevent system
    bus boosting.
    The constant output voltage can be selected for 2, 3 and 4
    series Li-Ion cells with ±0.5% accuracy over temperature. It
    can also be programmed between 4.2V + 5% per cell and
    4.2V - 5% per cell to optimize battery capacity. When
    supplying the load and battery charger simultaneously, the
    input current limit for the AC adapter is programmable to
    within ±3% accuracy to avoid overloading the AC adapter and
    to allow the system to make efficient use of available adapter
    power for charging. It also has a wide range of programmable
    charging current. The ISL6257 automatically transitions from
    regulating current mode to regulating voltage mode.
    Features
    • ±0.5% Charge Voltage Accuracy (-10°C to +100°C)
    • ±3% Accurate Input Current Limit
    • ±3% Accurate Battery Charge Current Limit
    • ±25% Accurate Battery Trickle Charge Current Limit
    • Programmable Charge Current Limit, Adapter Current
    Limit and Charge Voltage
    • Fixed 300kHz PWM Synchronous Buck Controller with Diode Emulation at Light Load
    • AC Adapter Present Indicator
    • Fast Input Current Limit Response
    • Input Voltage Range 7V to 25V
    • Support 2, 3 and 4 Cells Battery Pack
    • Up to 17.64V Battery-Voltage Set Point
    • Control Adapter Power Source Select MOSFET
    • Thermal Shutdown
    • Aircraft Power Capable
    • DC Adapter Present Indicator
    • Battery Discharge MOSFET Control
    • Less than 10µA Battery Leakage Current
    • Support Pulse Charging
    • Charge any Battery Chemistry: Li-Ion, NiCd, NiMH, etc.
    • Pb-Free Plus Anneal Available (RoHS Compliant)
    Applications
    • Notebook, Desknote and Sub-notebook Computers
    • Personal Digital Assistant​
    Our boardview and schematic bot.
