FX553VE-DM318T(FX553v) not POSTING
  • m1ch43lzm
    • Mar 2019
    • 487
    • Peru
    https://www.onetransistor.eu/2018/11...n-windows.html
    Press the read ID button, it's the one with question mark, it should detect the chip
    If the chip is not detected properly, check the connection on the clip, make sure it's aligned properly
    After it gets properly detected click the read button
    You should get something else on the hex view, not just full of FF FF...,
    I gotta sleep, it's 2a.m here
    • claws77
      • Apr 2024
      • 103
      • India
      here is the bios dumps, you are right, it was a connection issue.
      sure good night! thanks
      model: FX553VE-DM318T(FX553v) -- 7265NGW
      board: GL553VE
      serial: H8N0CV04T36032G
      status: trying to enter bios sometimes freezes my boot, sometimes work, cannot delete secureboot variables, cannot update bios, used to get MOKlist errors, trying to boot with usb always freezes my computer except if no windows drive is present. If i do not try to enter bios, the pc works fine, boots into windows without any issue,
      https://www.badcaps.net/forum/troubl...-gl553vd/page4
      • Sephir0th
        • Oct 2020
        • 1283
        Someone thought about to replace the SPI flash IC or to check general board health at chip-level?
        I mean a partial short circuit somewhere could cause the behaviour too. I'd especially inspect the 5V rails and the chipset related power rails for something off.
        FairRepair on YouTube
        • claws77
          • Apr 2024
          • 103
          • India
          how would i go about that?, mind you i am just starting to learn laptop repair.
          i could not find schematic or boardviews for my board, how to find 5v lines.?
          it may be significant to point out that i never had usb port problems. sometimes i did find out that my cables were faulty.
          i think( correct me if i am wrong) we should focus on flashing bios.
          if this doesnot work then i'll check for partial shorts. cuz i do not even know where to begin.
          thank you for replying..
          could you please check my biosdump- if the read was ok!
          • Sephir0th
            • Oct 2020
            • 1283
            Let's call it like it is: To read or write the BIOS with the alligator clip is BAD PRACTICE when you are not aware of the disadvantages.
            Best practice is to read and write the IC soldered on a discrete programming board which you can install on the CH341A.
            However, there are options to minimise the risk of data corruption while reading or writing the flash IC when you are not willing to go the safe route or when you have a Plan B in the backhand (for the experienced technicians).
            With Software like FlexHex you can compare two dumps.
            a) reading a dump and check for data integrity - Here you want to take two or three dumps from the flash IC and compare these. If they are different, you have read corrupted files and you need to check the connection (and health of the power rail connected to Pin 8 of the flash IC). To be in almost full fail-save conditions you need to completely disconnect and re-connect to the flash IC after each read attempt. You have to read dumps from the flash IC until you get at least 2 (better 3) dumps which are identical.
            b) writing a dump and check for data integrity - after writing the dump, you read out the dump again and compare it with the source file you have written. If the dumps are NOT identical, you have probably written or read a corrupted dump. You have to repeat this until FlexHex (or similar software) tells you that the source file is identical with the file you have read out again.
            with these simple but important steps you can work with the CH341A in combination with the alligator clip. I don't say that this is 100% safe, but the risk should be minized down to less than 1%.
            However what I was suggesting instead is to replace the Flash IC, the BIOS chip, hehe.
            The work at chip-level can be still started afterwards.
            • claws77
              • Apr 2024
              • 103
              • India
              #26
              done, done, done
              i am using "fc /b" cmd utility.
              there are 3 bios dump in my bios.zip. they are identical. they are also non empty
              i compared my bios dump with the manufacturer's one using fc /b found several differences
              one youtube video taught me that manufacturer provides bios in a capsule and we have to extract it using uefi tool.
              i did that.
              i also tried to read with uefi tool, my bios dump, it seems readable and similar to manufacturer's bios. but only in the bios section, so i cannot know for sure
              is my manufacturer bios ready for flashing? or do i need to edit it? --- maybe add serial no and model no etc but i do not know where
              img names flasbios.in is manufacturer bios from site after extraction, rest two are my bios dumps
              does not apply yet.
              thank you fpr not suggesting to replace the motherboard or laptop, double hehe
              • m1ch43lzm
                • Mar 2019
                • 487
                • Peru
                #27
                Sephir0th I checked BIOS dumps with UEFItool, at least the BIOS code section looks OK compared to the one from ASUS website (excluding ME region and flash descriptor, not present on BIOS from ASUS web), differences are in NVRAM variables, noticed also some extra UEFI certs by Canonical on the dump ( claws77 installed Linux before)
                Code:
                Canonical Ltd. Master Certificate Authority
                http://www.canonical.com/secure-boot-master-ca.crl
                From the previous posts laptop boots Windows from internal drive but nothing else from external devices, BIOS setup cannot be entered/hangs, so I thought it was corrupted BIOS, or corrupt NVRAM area
                Unless the BIOS flash IC is stuck on "read only" for some reason.... Only one way to find out besides just replacing it (that is, erasing it and doing a blank check it should be FF FF...)
                Now that we have a backup we could test with erasing the chip and writing a new BIOS to it, or writing that backup to a new chip
                Not yet, the BIOS from ASUS website is missing the flash descriptor and ME region, it only contains UEFI capsule
                Waiting for someone on the bios requests section to "fix" it or to make a clean BIOS with your serial/windows key
                The bios from here, post #10 should boot, it's the same version you have
                but with missing serial/windows key
                Boardview (should be 99% similar if not the same)
                https://www.badcaps.net/forum/troubl...-2-0-boardview
                Schematics https://www.badcaps.net/forum/troubl...ematics-please
                • claws77
                  • Apr 2024
                  • 103
                  • India
                  #28
                  yay, BIOS is ready.
                  one question though
                  should i remove every peripheral like hdd , keyboard, track pad and cmos, battery, lcd, dvd writer (ik RAM is non negotiable) before flashing.
                  • claws77
                    • Apr 2024
                    • 103
                    • India
                    #29
                    https://www.badcaps.net/filedata/fetch?id=3658240
                    this bios works with lcd and battery, keyboard, keyboard light and hdd and nvme and speaker and daughter board
                    can access bios too
                    this bios does not work when trackpad is connected.
                    serial no, model no both are wrong.
                    same issues booting from usb still persists.
                    could not boot into windows even with trackpad disconnected.
                    boot device not found.
                    reflashed my old bios - boots into windows but cannot access bios
                    Sephir0th may be right, will check this now
                    • Sephir0th
                      • Oct 2020
                      • 1283
                      The note about the Trackpad. What is that? Might be important.
                      A bad Touchpad can indeed cause the behaviour you're challenging right now
                      • claws77
                        • Apr 2024
                        • 103
                        • India
                        #31
                        After flashing the bios "https://www.badcaps.net/filedata/fetch?id=3658240" i tried to do my first boot. ik, it takes time so i waited 30 mins
                        it got stuck at asus logo.
                        so i went back and shorted my cmos battery pins.
                        removed everything except keyboard, keyboard backlight, lcd, ac adapter.
                        the bios lit up. in 15 secs
                        so i went back AGAIN and inserted each cable one by one.
                        i narrowed it down to my trackpad.
                        so without only my trackpad connected
                        i booted into windows only to get boot device failure. -- i suspect this is because of the secureboot variables (idk for sure)
                        since i do want a clean install, boot device failure means nothing
                        i tried to boot up my live puppy llinux usb -- again stuck at asus logo, cannot enter bios as well.
                        so i thought maybe its the 5v rail. cuz trackpad uses 5v and usb too. the trackpad is still unattached.
                        tried some combinations-- removing one or cables
                        atlast i flashed my backed up bios
                        connected my trackpad too -- everything boots up to windows like there was nothing wrong ever
                        my usb also gets detected in windows, trackpad works fine too
                        but i still cannot enter into bios with or without trackpad also with and without usb
                        i am stumped - either i can have perfect bios with no windows and no trackpad
                        or i can have windows with trackpad but cannot enter bios
                        both get stuck as soon as i stick a usb
                        • m1ch43lzm
                          • Mar 2019
                          • 487
                          • Peru
                          #32
                          Try the BIOS posted by SMDFlea https://www.badcaps.net/forum/troubl...e5#post3658543
                          Database error on the bios request forum for now
                          • m1ch43lzm
                            • Mar 2019
                            • 487
                            • Peru
                            #33
                            I found my old CH341A and a compatible flash chip (same size, different model/brand) from a dead board to test
                            On AsProgrammer, after you press Read ID, follow the steps in this order:
                            1. Erase the chip (button with X)
                            2. Write the new BIOS posted by SMDFlea (link is working now)
                            3. Press the Verify button (the one with the = symbol)
                            • claws77
                              • Apr 2024
                              • 103
                              • India
                              #34
                              Thank you!! Sephir0th m1ch43lzm It worked With conditions.
                              So as mentioned i needed to shift data between drives and install fresh windows on ssd.
                              After flashing the bios, the bios worked ok, i was able to boot into my live usb by selecting from boot menu.
                              After booting,
                              i just format my old windows partition.
                              Shift data around. Etc. (Now without the live usb i donot have any bootable drive, in my pc)
                              Since then, i was unable to acess the boot menu again.😥
                              I was still able to boot into windows installer usb because it was the only boot option.
                              Now i cannot get into bios or boot menu, again. 😥
                              i got lucky.
                              I would like to explore and solve this issue.
                              • m1ch43lzm
                                • Mar 2019
                                • 487
                                • Peru
                                #35
                                So the windows installer USB works now? And your Linux boot USB broke the BIOS again? Weird things happen... May be a BIOS bug that never got fixed by ASUS
                                Can be also related to this other bug, on a different ASUS laptop: https://www.badcaps.net/forum/troubl...iable-bios-fix
                                At least your laptop works 😁, and you have a way to recover it with the BIOS from SMDflea, next time try disabling Secure Boot in BIOS before booting anything from USB
                                • claws77
                                  • Apr 2024
                                  • 103
                                  • India
                                  #36
                                  I donot think the linux usb broke my bios.
                                  windows installer USB(or any other usb) worked once(won't work again) only because it was the olny boot option available for my bios to boot into, now it won't as i have installed windows.
                                  Since i cannot access bios, the the bios will keep using the default i.e. my windows on ssd.
                                  Yes secure boot is/was disabled for sure.
                                  Yeah, you guys are a laptop saver.
                                  • claws77
                                    • Apr 2024
                                    • 103
                                    • India
                                    #37
                                    i messed up, i reflashed the bios given by SMDFlea after reinstalling (fresh) windows, now its stuck at Asus logo, cannot go into windows or bios, 🤣🤣
                                    i looked it up - google response boot order issues, but i cannot do anything
                                    • m1ch43lzm
                                      • Mar 2019
                                      • 487
                                      • Peru
                                      #38
                                      Now I'm beginning to think it's a hardware issue, with the 3.3v supply to the BIOS chip, the 5v supply, or a faulty flash chip, and the BIOS corruption/not going into BIOS setup is a side effect of that
                                      As you said on the bios request thread it boots now into Windows but can't enter setup/change boot order anymore
                                      You'll need a multimeter with sharp probes
                                      Measure resistance across both R2802 and R2804, should be 0 ohms (same as touching the probes together), the schematics and board view linked above in post #27 will help to locate those parts
                                      Also measure the voltage on pin 8 on the BIOS chip, should be 3.3v
                                      • claws77
                                        • Apr 2024
                                        • 103
                                        • India
                                        #39
                                        Coin cell battery [C] =2.9 V
                                        battery [B] = 50%
                                        AC [A] = 19V
                                        The output at pin 8 of bios chip after plugging each powersource and their combinations in order - first coin cell, then battery then ac.
                                        See image.
                                        resistance across r2802 and r2804 is 0.8, 0.6 ohms.
                                        leads resistance 0.6 ohms.
                                        Sorry it took quite a time to respond, job stuff.
                                        • m1ch43lzm
                                          • Mar 2019
                                          • 487
                                          • Peru
                                          #40
                                          Voltage in pin 8 of the BIOS is OK, I can't think of anything else except a failing BIOS chip (W25Q64FV)
                                          You'll need a hot air station to replace it, if you don't have the tools/skills best to take it to a repair shop explaining the issue (can't enter BIOS setup/boot menu)
                                          You have a known working BIOS dump from SMDflea, it has to be flashed onto a new chip and soldered on the motherboard
                                          • throwaway327
                                            by throwaway327
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            06-18-2025, 05:52 PM
                                          • iZakre
                                            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                                            by iZakre
                                            Hello everybody!
                                            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                                            The thing is that I had installed TeamViewer and could log into the computer...
                                            02-19-2023, 02:27 PM
                                          • q2v5
                                            Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                            by q2v5
                                            Lenovo T480s
                                            Model 20L8-S3TE00
                                            Board ET481-U10
                                            Chip MX25L12873F
                                            Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                            2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                            The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                            08-15-2024, 10:40 PM
                                          • Neddsme
                                            Bios partially corrupted somehow and now warm boot doesn't work which is critical
                                            by Neddsme
                                            Hie.
                                            I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                                            Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                                            I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                                            I managed to run Windows troubleshooting and...
                                            02-04-2022, 05:57 AM
                                          • Max029
                                            Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                                            by Max029
                                            I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                                            I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                                            TY,
                                            08-18-2024, 08:28 PM
