ASUS GL553VD MAIN BOARD REV:2.0 - Boardview
  • Sephir0th
    • Oct 2020
    • 1289
    Kind regards!
    FairRepair on YouTube
  • MrEmiriv
    • Mar 2016
    • 14
    • Argentina
    Re: ASUS GL553VD MAIN BOARD REV:2.0 - Boardview
    Thanks! this made my job much easier
    • rizky
      • Jun 2021
      • 7
      • indonesia
      Originally posted by Sephir0th
      Kind regards!
      thanks sir
      • dreams28
        • Mar 2016
        • 22
        • turkey
        thank you ..
        • luisfm2
          • Jan 2015
          • 51
          • Portugal
          Thank you..
          • siroos_tz
            • Feb 2014
            • 121
            • the UK
            Kind regards!
            Thank you very much.
            • Fadda88
              • May 2017
              • 12
              • Italy
              Thank you
              • tomodachi
                • Apr 2012
                • 615
                • Turkey
                Thanks a lot
                • HA3BA
                  • Jan 2023
                  • Ukraine
                  Thank you very much!
                  • guizmo1967
                    • Sep 2022
                    • 77
                    Asus GL553VD Schematic needed !
                    Anyone has this schematic ??
                    Thank you if you do !
                    • kusal
                      • Jul 2021
                      • 28
                      • Sri Lanka
                      thankz
                      • lione
                        • Dec 2017
                        • 7
                        • Iran
                        thank you
                        • ettaki
                          • May 2018
                          • canada
                          thanks bro
                          • gensan
                            • Nov 2015
                            • Ukraine
                            Thank you
                            • dhanasiri.bac
                              • Dec 2012
                              • sri lanka
                              THANKS BOSS
                              • louiloiiuio
                                • Jul 2024
                                • france
                                Thanks you very much
                                • enes_rs
                                  • Aug 2024
                                  • brussel
                                  thank you ! Can i ask you for help if its possible, i have Asus gl553vd and the issue was when i shutdown the laptop then cannot turn it ON need to wait 20 30min.. and i did mistake to update bios from official website asus.. i dont know where is the issue but later i bought the bios chip installed again bios firmware but not working... in the end i found the same laptop. SO my plan is to check one by one hte parts of mainboard that owrking where can be the issue. The problem is that i dont know to read thsi digram
                                  • Mateo Rosas
                                    • Mar 2025
                                    • M
                                    • Dani_2024
                                      by Dani_2024
                                      10-28-2024, 05:06 PM
                                    • ygorsan
                                      by ygorsan
                                      🧩 Problem Summary:
                                      • I
                                      07-28-2025, 08:34 AM
                                    • jb_Bak
                                      by jb_Bak
                                      CN6401
                                      Pin 01 NC
                                      Pin 02 NC
                                      Pin 03 "BL_ON": 0V
                                      Pin 04 "N/C"
                                      Pin 05 "STBY 3.3V": 3.5V
                                      Pin 06 "GND": N/C
                                      Pin 07 "AC_OFF"...
                                      09-27-2021, 04:52 PM
                                    • JDC
                                      by JDC
                                      ONN 100012588
                                      Long answer:
                                      07-15-2022, 07:39 AM
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
