Bios partially corrupted somehow and now warm boot doesn't work which is critical
  • Neddsme
    • Sep 2021
    • 30
    • Malawi
    Hie.
    I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
    Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
    I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
    I managed to run Windows troubleshooting and restarted in safe mode which seemed to make the problem disappear. Restarting in normal mode resulted in the same issue shortly after boot, mostly even before putting my password.
    I decided to shut down the Intel graphics driver which seemed to work, but now I got an awkwardly looking graphics output but it's usable. At least, until I realized in place of the sudden distortion, the LCD just goes black after the same amount of time. As if in place of the distortion from the disabled drivers, the LCD just disconnects.
    I immediately tried a Windows reset as my first instinct. Starnge enough after preparing the reset from Windows environment and going into restart to complete the reinstalling,, the PC just stuck with a black screen and a fan spinning at its highest rpm.
    I did some further investigations including trying a bios settings reset and that's when I started to realize how serious this was. The PC after selecting save and exit in bios, would just hang with the screen black and the fans spinning at maximum. Identical to when restating it in windows. I installed a secondary OS, remix OS from the android-x86 project and it boots up fine with no graphics distortion problem but it doesn't restart there either. Same problem in bios, Windows and Android OS environments. However shutdown seems to work fine but just not restart option.
    I immediately knew that if bios can't restart either then it's probably a corrupted bios issue. But now here is where the problem is, I got my bios update downloaded and ready. It executes in windows OK and prepares everything just like it's supposed to. And then, it has to restart for the capsule update. Which is where this bug kicks in and stops it from restating.
    In essence I can't update any firmware related to bios nor can I reset the PC or boot a new copy of windows..
    I never thought I'd learn the importance of the restart option I've taken for granted all along in such a cruel way.
    Also, I tried to boot Linux to maybe utilize fwupdate software to try and create a storage bootable capsule update since the problem is that I can only start from cold boot and I need the bios update to initiate from a cold boot state like from USB etc.
    But when I boot Linux, an OS I believed to overcome alot of hardware bugs and driver issues due to its open source community, I was welcomed with the same distorted screen from Windows had graphics driver right off the bat. The moment it loads from grub it's completely a mess of lines. It however works in compatibility mode but even I can tell it's long code of start-up check list has quite a number of detected bugs.
    I don't know what else is wrong with the PC apart from the restarting issue but I can say that the hard drive has been running slow ever since the distortion started happening and it the fun is more noisy now even though it's not really hot.
    I believe it's a bios issue of partial corruption and I would like to fix it if possible coz I can't afford a new motherboard option at the moment.
    Note: I tried the official Lenovo support advice and other similar approach like resetting RTC and disconnecting the entire board and power drain etc. Nothing worked. Bios reset didn't really work either. And nothing seems amiss from the bios it's self only the restart bug.
    I would like any help that includes getting dirty with the board it's self or getting it to flash the capsule update from USB etc. Any ideas and suggestions are welcome
  • hoaca388
    Badcaps
    • Jan 2022
    • 12717
    Re: Bios partially corrupted somehow and now warm boot doesn't work which is critical
    I found this to be because the CPU was overheating causing the Artifact error. First you should clean the laptop, replace the thermal paste and then review the results.
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our bios, boardview & schematic archive.
    Subscribe to support us. It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
    • Neddsme
      • Sep 2021
      • 30
      • Malawi
      Alright, let me try doing that and see what the result will be. Maybe reapply some thermal paste while I am at it.
      • kenkaniff
        HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
        by kenkaniff
        Product Name: HP Pro x360 Fortis 11-inch G9
        System BIOS: U94 Ver.01.08.00 10/06/2023
        Serial Number: 5CG31946F5
        SKU Number: 85W05EC#AK8
        Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
        This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
        I needed to remove bios password...
        10-01-2025, 04:32 AM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • ilkor
        BIOS Request: Lenovo ThinkCentre M73 Tiny (IS8XM Rev 1.1) - Error 0162 Boot Loop
        by ilkor
        I need help repairing/fixing my corrupted BIOS dump for a Lenovo ThinkCentre M73 Tiny.
        Motherboard Details:
        • Model: IS8XM Rev 1.1
        • Lenovo FRU: 03T7239
        How the problem happened:
        The motherboard was working perfectly before. The issue started after a failed BIOS update that was interrupted by Windows Security settings. After the interruption, the PC was still able to boot into Windows but I could not enter the BIOS setup at all.
        To fix this, I performed the Hardware Boot Block Recovery procedure using the motherboard jumper (Clear/Recovery pin 2-3) and a FAT32...
        05-25-2026, 08:20 AM
      • q2v5
        Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
        by q2v5
        Lenovo T480s
        Model 20L8-S3TE00
        Board ET481-U10
        Chip MX25L12873F
        Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
        2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
        The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
        08-15-2024, 10:40 PM
      • TopPop
        Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
        by TopPop
        Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
        I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
        12-14-2025, 09:40 PM
