After replacing nec/tokin capacitor orange light blinking
  • robrock1
    • Jul 2013
    • 129
    • Ghana
    Hello, i replace the capacitor in a toshiba a305 and everything seems ok but when you power the laptop the power led is blinking orange and white. The cpu is working and the screen flashes then it goes off, like its detecting some voltage is wrong or something. I use the mini pci diagnostic card, i can see its reading so the cpu and board is ok, Anyone had this problem before?
  • dj_ricoh
    • 2073
    Re: After replacing nec/tokin capacitor orange light blinking
    move the memory to the other slot :P
    • robrock1
      • Jul 2013
      • 129
      • Ghana
      yes i did it worked. How is this possible?
      • jtamad44
        • Apr 2013
        • 145
        • israel
        make sure caps are not shortin each other from under, redo..
        • robrock1
          • Jul 2013
          • 129
          • Ghana
          Yes i already replaced the caps again, the fault was from the memory slot. i am just surprised how.
          • jtamad44
            • Apr 2013
            • 145
            • israel
            may be the voltage is fluctuating, try to measure it.
            • mockingbird
              • Dec 2008
              • 5486
              Let's have a look at your handywork.
              • bgaservis
                • Oct 2012
                • 36
                • Serbia
                Do you have scope ?
                Check capacitors and resistor if there is any.
                • robrock1
                  • Jul 2013
                  • 129
                  • Ghana
                  Thanks for help guys but the fault was simply from the memory slot.
                  • spleenharvester
                    • Mar 2010
                    • 921
                    Oddly enough - I have exactly the same problem on an L300 board I replaced the Tokin cap on. Flashes between green and orange and then shuts off. I'd love to know what's causing this since I can't see how a vCore cap replacement can interfere with a RAM slot.
                    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                    • robrock1
                      • Jul 2013
                      • 129
                      • Ghana
                      maybe because of the heat when you remove the old cap the northbridge gets damaged somehow or some bad connection of the solder balls
                      • spleenharvester
                        • Mar 2010
                        • 921
                        Possible, but I don't desolder the original cap - but instead crush it and solder the tantalums over the contacts. So not much heat exposure. Also I think that RAM slot worked initially and then stopped a few days later.
                        I read somewhere that it's Toshiba's code for one of the power controllers having detected a short circuit. But surely if that was the case, it would just refuse to boot?
                        • inflex
                          • Aug 2012
                          • 545
                          Hah, well blow me down - same here, same fault, swapped memory to the other slot and away it went all working fine.
                          So, what's the cause of this?
                          I was about to just toss this one in the bin ( L300 ) because I figured it wasn't worth spending more time on it - and I was lucky enough to see the title of this thread.
                          YouTube Repair Videos - https://www.youtube.com/user/19PLD73
                          FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
                          • Francisco.s
                            • 686
                            • Spain
                            Did you swapped memory again, to see if it works fine too?
                            • spleenharvester
                              • Mar 2010
                              • 921
                              Now that there's three of us maybe we could make some decent headway on figuring out the problem.
                              I'll take a look at some point soon but my multimeter is fudged right now! I have lots of L300 boards to compare resistance too luckily.
                              • dj_ricoh
                                • 2073
                                ok i got a300 intel ver.
                                mine got corosion near cpu socket.
                                maybe i can help with this one to.
                                let`s roll
                                • spleenharvester
                                  • Mar 2010
                                  • 921
                                  https://cdn.badcaps-static.com/pdfs/...13495f3279.pdf
                                  Okay guys, obviously we will have different versions of boards etc, but I think pages 26-28 on this diagram are where we need to be looking. If you can grab schematics for your own models I imagine you'll find they're fairly similar.
                                  My guess is a shorted cap on the +1.8v line somewhere perhaps? Maybe start by checking voltages are present there? Though IIRC these are the horrid tiny tiny little caps so it could be an interesting task.
                                  • spleenharvester
                                    • Mar 2010
                                    • 921
                                    First thing to do is figure out which of your slots has failed. Lines beginning with "MA_" appear to correspond to slot A. Lines beginning with "MB_" appear to correspond to slot B.
                                    Should be interesting to see if we all have the same failed slot.
                                    • spleenharvester
                                      • Mar 2010
                                      • 921
                                      Apologies for triple post, I have an update.
                                      1) I've compared the resistances of each slot's key pins (V1.8 etc etc) and found no differences.
                                      2) Both 1.8v and 0.9v voltages are present regardless of whether there is a stick in the failed slot (for me, it is the topmost slot, slot B)
                                      3) The flashing does not occur when no CPU is present. So presumably, the powergood signal is involved somewhere?
                                      4) +3VS on pin 200 reads at 1.6v when no DIMM is present. I cannot read it when a DIMM Is present but if I boot it with one, and then without one, it briefly appears at +3.2v before dropping to +1.6v. (note, DIMM A does not have +3VS on pin 200)
                                      5) VREF when read at pin 1 is always at 0.87v at both slots, regardless of the slot configuration.
                                      • robrock1
                                        • Jul 2013
                                        • 129
                                        • Ghana
                                        i also checked the voltages i can't find anything, seems all the voltages are there. the interessting thing is, the laptop is working the post is running its detecting the memory, you can see the screen flashing, like it wants to come on but then the orange light is shutting it down, but the system itself is working, maybe its a false alarm like some signal is not getting through. Should we try and update the bios here?
                                        • mosfetratus
                                          macbook A2918, orange light off when shut off
                                          by mosfetratus
                                          When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
                                          Works with battery and charges, but when i shut off i get this problem.
                                          It had liquid spill. Board has no corrosion, keyboard is working, power button...
                                          05-31-2024, 03:34 AM
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • Tomylee
                                          Nintendo 2DS XL – Orange light, no blue light, signs of overheating
                                          by Tomylee
                                          Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
                                          Here's what I've observed:
                                          All ribbon cables are properly connected
                                          Battery is present and in good condition
                                          No reaction even with screens disconnected
                                          There's a visible burn mark / overheating sign on the metal shield, right above the CPU
                                          I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
                                          06-26-2025, 02:33 PM
                                        • Jacksoft
                                          HP ProBook 440 G6 infinite orange blinking
                                          by Jacksoft
                                          I have an HP ProBook 440 G6 with DAX8JMB16E0 REV. E motherboard that got BIOS bricked after maaany bootloops caused by Window's BCD. I made a dump of the actual BIOS and written a found one.
                                          The PC worked but it was very slooow to show HP logo in first place.
                                          A friend of mine gave me another BIOS for this series and after the flash it powered on (white led on power button) but after few second shutted down and start blinking orange infinitely on the LED near the AC adapter connector on the side.
                                          The laptop doesn't power on anymore, and the blinking led happens...
                                          08-29-2025, 01:24 AM
                                        • jheunne
                                          A1466 macbook no boot green to orange light help
                                          by jheunne
                                          i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
                                          in first image there is 0v out for lcd
                                          https://ibb.co/5XppmpkH
                                          in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
                                          https://ibb.co/fdJkbJs8
                                          06-10-2025, 10:52 PM
