A1466 macbook no boot green to orange light help
  • jheunne
    • Sep 2022
    • 90
    • philippines
    • games, basketball gadgets movies food
    i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
    in first image there is 0v out for lcd
    https://ibb.co/5XppmpkH
    in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
    https://ibb.co/fdJkbJs8
  • mon2
    • 16564
    What are the details of u1930? Have not checked the schematics yet. Best source of parts is a donor board. Many replacement boards for this model on eBay or AliExpress.
    • jheunne
      • Sep 2022
      • 90
      • philippines
      u1930
      1 PM SLP S3 L
      2 ALL SYS PWRGD
      3 GND
      4 CPU VCCST PWRGD
      5 UNCONNECTED
      6 PP3V3 S5
      PIN 6 VOLTAGE PRESENT POSSIBLE EVEN HAS NO PART UNIT MAY BOOT UP
      I CAN'T FIND COMPATIBLE PARTS FOR THIS ONE
      • mon2
        • 16564
        Review this flow chart:
        https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
        • jheunne
          • Sep 2022
          • 90
          • philippines
          i have already fix my macbook air i have found parts for it from a donor board thanks to all for the help a big help for me.
          • joeoffice12
            MacBook Air (2017, A1466, No power/orange-green light on)
            by joeoffice12
            I have a 13 inch MacBook Air 2017 that does not show any life, however, there is activity from the MagSafe light going from green to orange and staying. Normally, this battery works perfectly fine and it can actually charge the battery as if I were to leave it alone it would change to just green, however, this thing does not boot up at all, I was told the computer was at 30% and then it randomly shut off.
            Some voltages:
            PPBUS_G3H - 8.5V
            SMC_PM_G2_EN - 3.42V
            PP3V3_S5 - 3.32V
            PP3V42_G3H - 3.42V
            PPDCIN_G3H - 15.18V
            PP5V_S5 - 5.04V
            PP3V3_S5_REG_R...
            12-15-2023, 04:00 PM
          • judamex
            MacBook Air 820-00165 turns on But no green and orange light, not charge
            by judamex
            MacBook Air turns on without battery connected, no green or orange light comes on, I connect the battery and it shows battery with lightning and it restarts constantly.
            03-06-2025, 03:55 PM
          • techrepairheide
            MacBook Pro (A1502 / 820-3476-A) - No orange/green light and no power
            by techrepairheide
            Hello again,
            got an MacBook Pro from 2015, model A1502 and motherboard version 820-3476-A.
            Device died over night on charger.
            Currently I did the follow things:
            1. Checked visuell the board, test with another MagSafe-Charger and with another DC-IN-board too
            2. Measured 16,5V on ​PP18V5_DCIN_FUSE but 0V on ADAPTER_SENSE and 0V on PP_3V42_G3H and 0V on PPBUS_G3H but 16,5V goes to U7090
            3. Because of corrosion and bad resistor values I changed these components: U7090 / C7094 / C7095 / R7095 / R7096 / L7095 / C7099 -> But further...
            01-26-2025, 05:37 AM
          • aahazim
            Macbook Pro A1425 820-3462 (No Green/Orange Light)
            by aahazim
            Hello there. I've got an issue with my Macbook Pro A1425 820-3462 with no green/orange light when plug in. Also I was unable to boot with the battery plugged in. When I change the DC-in board to another spare one I had, it show orange light and boot up with fan spinning, without the battery plug in. But it will randomly just not showing the magsafe light and the system become slow and the fans just when erratic all of sudden
            Here's the voltage I've measured based on the guide I've read :
            Original DC-in board (no green/orange light, no fan spin) :
            SYS_ONEWIRE...
            03-14-2021, 02:44 AM
          • GB1999
            Macbook Air a1466 820-00165-a (No power , have orange light)
            by GB1999
            Hi there i have a Macbook Air A1466 board number 820-00165-A. No power, and has Orange light when plug in to charger. SMC is working and the Fuse is good. Found a Short and removed. But still there is short on mosfet. The short leading to Capacitors near Processor.
            - 2 Mosfet Near The Processor Is Shorted. (Already Tried Injecting 1V, draining 0.07A) Unable to shop the shorted area. Marked Blue.
            - Already Checked Big Capacitor below the processor. (Good Capacitor) Marked Blue.
            - Found a short and solved the issue. ( Red marked Big Cap)
            Anyone...
            04-09-2023, 12:24 PM
