playstation 5 digital firmware dump
  • albertojrb93
    • Nov 2021
    • República Dominicana
    #61
    i have a CFI-1015A PS5 Disk Version - Board EDM-010 . this is my ic dump . i need a compatible digital version dump.
    • mr39893
      • united states of america
      #62
      hey guys , i have this ps5 disk ver. edm-33 CFI-1215a / i believe its the bios/ can anyone please send the file for this board, much appreciated
      • Abady Ta
        Abady
        • Libya
        #63
        Originally posted by stj
        Re: playstation 5 digital firmware dump
        Is it working with disk version
        • Abady Ta
          Abady
          • Libya
          #64
          Here is a firmware dump for CFI-1015A. Note that it must end A. Copied from known working and it helped me fix a PS5 that had 3 beeps as soon as you plugged in the AC cable. I believe the board was originally also going to 30mA and then shutting back down.
          Upon boot it is now asking me to reset the software, will update to see if software reset/update will work.
          My ps5 worked but no picture no display
          • Michael Omoniyi
            Delmark-son
            • 3
            • Nigeria
            #65
            My ps5 is having 3beeps of death immediately I plugged it, I've tried writing several dumps found here, but doesn't work, even tried changing it using nor modifier but doesn't work.
            Please, I need firmware dump for cfi-1216a
            • englez
              • Jul 2012
              • 31
              • Serbia
              #66
              Try,untested...
              • Michael Omoniyi
                Delmark-son
                • 3
                • Nigeria
                #67
                Originally posted by englez
                Try,untested...
                Thanks so much for the file, I really appreciate the effort but the file didn't seem to work, when I wrote it to the BIOS, when I plug the console, it won't even respond, no 3 beeps, eject/power button not responding, it's like a dead console and when I rewrite the old BIOS back, I get the 3beeps immediately when plugged and nothing else
                the console motherboard is edm-031 cfi-1216A
                Or am I missing any required procedure?
                Here's my own BIOS having the 3beeps
                • general1986
                  • Aug 2016
                  • 6
                  • iraq
                  #68
                  hi friend i need bios file for ps5 bin file PS5 BLOD- CFI-1115A it have 3 beeps
                  • badmanpro
                    • Mar 2024
                    hi guys i need bios file for ps5 bin file PS5 BLOD- CFI-1218a edm-030 it have 3 beeps, thanks
                    • Cobbes
                      • Mar 2024
                      • 27
                      Here is a working dump from a edm-031 cfi-1216a with 69gg southbridge. Change at 0x001C7200 the console unique data (MainboardS/N and SerialNo)
                      • Michael Omoniyi
                        Delmark-son
                        • 3
                        • Nigeria
                        #71
                        Thanks so much, it really worked and did the trick for me, thanks so much
                        • eznacho
                          • Mar 2024
                          • 4
                          Need CFI-1215B EDM-030 digital version. Thanks in advance.
                          • Cobbes
                            • Mar 2024
                            • 27
                            Here is a working dump from an edm-031 cfi-1215b with 61gg southbridge. I'm not sure if it works without any issues on an edm-030.
                            • eznacho
                              • Mar 2024
                              • 4
                              Thanks I had taken this already, it goes straight to safemode but then restarts so it leads me to believe there's an issue with it working.
                              • Cobbes
                                • Mar 2024
                                • 27
                                From my experience so far, if there is a issue with the nor data the PS5 will beep three time or doesn't react at all. A safemode direct/only I would suspect a problem with the ssd.
                                • eznacho
                                  • Mar 2024
                                  • 4
                                  Yeah, safe mode loads with the file you gave but then it shuts off, obviously it's not the correct one so i'm thinking that's an issue, great thing about this it's showing signs of life! Where before it wasn't showing anything.
                                  • Cobbes
                                    • Mar 2024
                                    • 27
                                    The southbridge starts working as soon as 12V are present. If an issue appears in the prestart phase, like corrupted nor data, the system normally wouldn't boot. If the ps5 is showing something on the screen, I would consider the southbridge and nor data as functional.
                                    • gettindrunk
                                      • Mar 2024
                                      • 4
                                      • usa
                                      #78
                                      i have a CFI-1015A PS5 Disk Version - Board EDM-010 looking for a bin to turn into digital
                                      • Cobbes
                                        • Mar 2024
                                        • 27
                                        Open the nor dump in an hex editor and change:
                                        0x001C7011 = 02 (BD) to 03 (digital)
                                        0x001C7028 = 89 (BD) to 8D (digital)
                                        • Cobbes
                                          • Mar 2024
                                          • 27
                                          Sorry, typing error. It should be:
                                          0x001C7038 = 89 (BD) to 8D (digital)​
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • Tamo Neko
                                            Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                                            by Tamo Neko
                                            I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                                            What Happened:
                                            I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                                            • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                                            • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                                            What I Need:
                                            • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                                            02-12-2025, 11:29 PM
                                          • jorpec
                                            Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
                                            by jorpec
                                            Hi, all
                                            I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
                                            10-17-2025, 03:51 AM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • gun4as
                                            Need firmware dump for LG 23MP48HQ-P
                                            by gun4as
                                            Hello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
                                            08-25-2025, 04:28 AM
