Xbox One Power Supply - Orange Light & the dies when console is plugged in
  • hdguy
    • Sep 2014
    • 49
    Xbox One Power Supply / Brick ( PB-2201-02M1 )
    Plug in to wall: Orange (Standby Light) comes on
    Plug in to Xbox One: Lights go off (not white or blinking)
    Xbox One works with a different power supply.
    Xbox One Power Supply exhibits the same behavior when plugged in to a different Xbox One system.
    Conclusion: Problem with the Power Supply.
    I replaced the (2) 1000uf 16v caps (top right hand larger & bottom right hand larger in the pic)
    I replaced the (2) 2200uf 16v caps (top right hand small caps in the pic)
    (even though none of them were visually showing signs of failure)
    I think I know this group well enough to know we can fix it! I think I know this group well enough to know the expertise is here to do it (just not with me).
    Any thoughts on Next Steps?
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Xbox One Power Supply - Orange Light & the dies when console is plugged in
    Looks like a dual-output PSU. Probably 5V or 3.3V standby and a main 12V output.
    Since the orange light is dying when the PSU is plugged into the console, that suggest the standby supply may be having issues.
    As such, there is a good posibility that the issue may be related to the start-up cap(s). I see two caps that fit this description. One is C400 (a small-ish cap next to the two large 200V caps) and the other is a small green cap next one of the small yellow transformers (this appears to be the standby transformer.)
    Before changing them, try heating the PSU with a hair drier inside - particularly the are of these small startup caps. Don't get it too toasty. Just where it is hot to the touch, but not burning. Now try plugging it into the console and see if it the light goes out. If it doesn't, then those startup caps are very likely bad. And if the light does go out, you may have to change those startup caps anyways to make sure that is not the issue.
    Also, just a curious question: what brand and series were the original caps in the power supply and what brand and series did you replace them with?
    • hdguy
      • Sep 2014
      • 49
      The original caps were (3) JACKCON LHK Series & (1) Samxon. Pic attached.
      The remaining “suspect” caps are so tightly grouped on the PCB that I can't read the ratings. Tomorrow I’ll desolder, order, install & reply back on results.
      Thank you very much for the input!
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        OK, I see now the originals are three TAICON caps (not JACKCON) and one Samxon, but looks like you used the JACKCON caps for the repair. If that's the case, you may be better off with the Taicon and Samxon caps back in, as JACKCON is pretty terrible for reliability... but let's just keep the old caps for now (don't throw them away yet) and leave the Jackcon caps in the adapter for the time being.
        • hdguy
          • Sep 2014
          • 49
          I removed the other caps you were referencing
          C551: 25v 68 uF (Taicon)
          C400: 50v 48 uF (Ltec)
          I’ll go order these, and maybe the ones I already replaced since you said my new ones suck worse than the original ones! I’ll post an update when the new caps arrive.
          I’m actually doing this mostly for my notes..
          • hdguy
            • Sep 2014
            • 49
            Well - the Mouse box showed up with the following:
            25v 67 uF
            50v 48 uF
            I put them in the PCB - exact same result.
            I threw the whole thing in the garbage - at this point I’ve got more in parts (actually shipping) than the replacement on Amazon cost me.
            Thanks again for the help though!
            • electroman5946
              • Jul 2012
              • 11
              • US
              you have a short MOSFET its a HEX power FET. its on the heat sink.
              • duder
                • Oct 2013
                • 26
                • canada
                I realize that this is an old thread. I have the exact same situation as the opening post. I have the same model power supply with the 5 caps mentioned replaced. Only one cap was vented. Also, I have no shorted mosfet's. Wondering if anyone else has resolved this one.
                • MaxumElite
                  • Jan 2025
                  • 3
                  • México
                  I had the same problem, changed:
                  • 1000uf 16v caps
                  • 2200uf 16v caps
                  Actually only one of them presented signs of failure, but it didn't worked so I changed the rest of them.
                  Until I saw on this post that it could be a faulty MOS.
                  IT WAS INDEED.
Name:	Captura de pantalla 2025-01-22 001619.png
                  I know this is an old thread and maybe nobody is using an xbox one anymore, but I expect that just as me, someone would be looking for answers and found out that this could be the solution. 💛
                  • Unspun01
                    • Jun 2011
                    • 341
                    @MaxumElite: Can you confirm that you had the exact same problem as original poster? He stated that his power supply had orange LED and would turn off as soon as plugged into xbox console. The failure of your high voltage 500V mosfet is a high-side problem and I would think you didn't get any LEDs on the power supply (orange or white) at all? This issue is independent of the failing low side capacitors. Just looking for more info. Thanks.
                      • 31015
                      people need to stop buying capacitors (or anything else frankly) from fucking Amazon.
                      they areworse than Ebay
                      • MaxumElite
                        • Jan 2025
                        • 3
                        • México
                        Hello, I had the exact same problem:
                        I tried a different PSU (a cheap one) and the xbox worked perfectly.
                        A capacitor was inflated thats why I changed it instantly (changed the others also just beacuse 😅😳), but even after that the failure wasn't gone.
                        So thats why a came looking for some light and realized that it was indeed a faulty MOS.
                        All this happend me after my original HDD started to fail. (I dont even know if it has anything to do with)
                        Sorry if I wasn't that explicit in the first post.
                        • CapLeaker
                          Leaking Member
                          • 8148
                          Amazon… eBay… same effin junk.
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                            by sam_sam_sam
                            07-01-2024, 06:34 AM
                          • NatoPotato
                            Original Xbox Power Supply Repair - FTPS-0002
                            by NatoPotato
                            Hey there friends!
                            I have an original Xbox power supply, model FTPS-0002, that isn't showing any signs of life. I have never really done power supply repairs before but I'm eager to learn so I am hoping someone can help me diagnose this.
                            The issue is that I get no 3.3VSR standby voltage which in turn leads to no 5v or 12v. A couple things I have noticed in my initial inspection.
                            Resistor 25 and 29 are both reading OL, Capacitor 17 and 20 seem to be leaking as seen in the photos.
                            So far I have confirmed that 240v, main fuse and the 400v cap is...
                            09-04-2023, 06:45 AM
                          • gabri2211
                            Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
                            by gabri2211
                            Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
                            This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
                            This NEXUS connector broke.
                            Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
                            The Xbox has a power supply that provides 12 volts on all outputs, so the power...
                            07-28-2025, 07:13 PM
