Repair Fence Energizer SS-1000E Fi-Shock
  • stormy1777
    • Oct 2015
    • 141
    Re: Repair Fence Energizer SS-1000E Fi-Shock
    sorry, yeah, i meant "open", not short!! sorry.. so you mean the "wirewound" type are OK as a replacement to this ceramic cement one? I tell u, I'm running around the house measuring resistance and found many objects (rocks, stones, blocks of wood, etc.) with 360Ohm, so tempting to hook them up just kidding may find an old part over weekend.. Thanks, will keep posted!
    • R_J
      • Jun 2012
      • 9580
      Yes those are wirewound, and the replacements will be wirewound. If you opened it it would look like this inside
      • stormy1777
        • Oct 2015
        • 141
        I thought failed resistor is "Ceramic Cement", but can't find it in such lists:
        https://www.lifewire.com/types-of-resistors-818848
        https://en.wikipedia.org/wiki/Resistor
        Is it same as wirewound ? just maybe not wound so much, so in effect the construction is similar?
        It might be that the shocker was mis-used, maybe someone put a tool or something that caused the fence to constantly "shock" the tool, not sure, it's very told too
        • stormy1777
          • Oct 2015
          • 141
          ah, ok, sorry our posting crossed, funny it did not alarm me to reload page due to new posting... Thanks, will go with wirewound and open it up later on..
          • R_J
            • Jun 2012
            • 9580
            https://www.digikey.com/products/en/...=1&pageSize=25
              • 31154
              smash the faulty one open and check, they arent always wirewound.
              i have seen the cement box type with ceramic/metal-film resistors in them a number of times.
              usually where you dont want inductance or any magnetic issues.
              • stormy1777
                • Oct 2015
                • 141
                OK, took the advice, and it seems like wirewound. Searching I've found THREE very similar resistors, pair of 470 Ohm 390Ohm, 330 Ohm, all 10W, the question is it going to work with either one? probably not want to mix the existing 360 Ohm...
                any thoughts welcomed, that would be an instant fix, no need to ship anything
                Stormy
                • stormy1777
                  • Oct 2015
                  • 141
                  found another with 350 Ohm / 10W, i think that is close enough to try replacing both
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Probably safer to replace one at a time since you're dealing with not-exact matches.
                    Anyway no point in replacing the other resistor - resistors usually aren't 'wear' items unlike capacitors...
                      RJ already done the research for you and found the resistor for you so why not order two of them and just replace them.
                      • stormy1777
                        • Oct 2015
                        • 141
                        I was thinking to keep things more 'in balance', but I'll go with that and replace just one with 350 Ohm and see if that works. at this point it's also for educational purposes, sure can order, but that will take few days, until then, folks here are eager to see it work again, farmers are lovely people you know
                        I think tomorrow we'll know
                        Thanks folks!!
                        BTW: tested the existing/good shows exactly 360 Ohm, the bad one, shows upwards to 600K Ohm, and sometimes 1M Ohm, and sometimes OL so, it's bad
                        Stormy.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Keep in mind, 600KΩ is near the resistance of sweaty human fingertips from hand to hand, and that's why it's dangerous to touch live voltages...
                            • 31154
                            and on a related subject, how do you intend to test this device?
                            • stormy1777
                              • Oct 2015
                              • 141
                              If u ask me, it's also dangerous touching a failed resistor; why? b/c I've just embarrassed myself
                              You probably know the rest, but I'll spell it out for those interested!!
                              I was measuring my own "sweaty hands" as was struggling to make good contacts with the loose resistor now re-testing over and over, it is OL for sure, no nothing, just ===dead=== cut wire or burnt or something..
                              Thanks for the remark, learning a lot
                              Stormy.
                              PS: Do they give forum points for honesty ? at least you got a good laugh
                              • stormy1777
                                • Oct 2015
                                • 141
                                good question:
                                test1: see if NEON yellow light turns ON.
                                test2: measure Volt difference between the two external rods.
                                test3: short them for a split second?? like this maybe: https://www.youtube.com/watch?v=-ncPc8iNmyU
                                test4: take it to the fence and hook to wires, and see if it works
                                Stormy.
                                • petehall347
                                  • Jan 2015
                                  • 4431
                                  #76
                                  a spark should jump across the electrodes when its working . best test is set up in the field and touch the fence .
                                    • 31154
                                    not testing it fully then?
                                    https://www.youtube.com/watch?v=iDJp2tHmEQo
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      No, no no...We don't need Bigclive to test one. We need ElectroBOOM to test one
                                      • stormy1777
                                        • Oct 2015
                                        • 141
                                        I'm trying to find the right HTML tags to wire it to this thread using PoE (power over ethernet , anyone posting should feel some jolt depending on their distance from the main servers
                                        Stormy
                                        PS: Yeah, Internet is not the same as Ethernet, darn, it could work you know if you didn't point that out!!!
                                        • stormy1777
                                          • Oct 2015
                                          • 141
                                          oh dear, oh dear, was not aware of this guy, I'm still crying from laughter:
                                          https://www.youtube.com/watch?v=CoxHOHYz1_k
                                          and definitely feel a lot better about my mishaps thus far
                                          • jshhh
                                            Help repairing Yamaha RM1X synthesizer/groovebox - PCB trace for capacitor has been pulled off
                                            by jshhh
                                            Hi guys,
                                            I've been trying to restore this Yamaha RM1X groove-box I bought, and the first thing on my agenda was to replace a bad capacitor that was making it so that the screen was super dim. As I'm a complete novice I went and accidentally pulled off one of the trace pads for the SMD capacitor as I was removing it, pulling up some of the green PCB with it. I've been trying to repair it by gluing down copper tape from where it began to pull off and solder the capacitor on after...atm I've just been attempting to do the same kind of thing on rubbish PCBs I got at a recycling place,...
                                            03-26-2025, 07:05 PM
                                          • Xiran
                                            Macbook A1502 820-3476-a don´t turn on (measures included)
                                            by Xiran
                                            Hi to all:
                                            I have a Macbook pro model A1502
                                            Board 820-3476-a
                                            Liquid damage, cleaned with isopropyl.
                                            Don´t boot in SMC Bypass, it tries to turn on without luck (check voltages, for example 5v usb intermittent).
                                            I have two chargers, one is an original apple magsafe 85w 16.5-18.5v 4.6a max. And 60w generic clone.
                                            Sometimes Stays with orange light, fan OFF. No heat.
                                            Measures:
                                            CLONE:
                                            ppbus_g3h 12.55v
                                            PP3V42_G3H 3.41v
                                            PPVRTC_G3H 3.33v
                                            PP5V_S5 5.02v
                                            PP5V_S3...
                                            12-23-2023, 02:10 PM
                                          • Benass
                                            GigaByte Radeon Rx5700xt 8gb VDDCR_GFX_PWR_GOOD Signal is missing.
                                            by Benass
                                            This will be a headscratcher. I don't know how to break it down to a readable topic.
                                            Im troubleshooting Rx5700 GPU. Core voltage missing.
                                            I have schematics and Boardview.
                                            I'm currently troubleshooting a power management setup that involves the IR35217M and NCP81022 chips. I've encountered some issues specifically with the SM_ALERT#, SM_DIO, and SM_CLK pins, and I'm hoping to get some insights or suggestions from those who might have experience with these components. Current Observations:
                                            • The SM_ALERT# pin is active (pulled low), indicating a potential fault condition.
                                            10-11-2024, 01:58 PM
                                          • ohren
                                            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                            by ohren
                                            Hello!
                                            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                            Measured voltages with no load:
                                            After rectifier diodes
                                            12V: 6.17 V
                                            5V: 5.67 V
                                            Secondary transformer pins AC measurement (really don't know if this says anything)
                                            12V: 2-2.5 V
                                            5V: 1.04 V
                                            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                            03-18-2023, 10:33 AM
                                          • seppde
                                            AMD Desktop Kit - no display, no POST (?)
                                            by seppde
                                            Hey,
                                            I've recently sold a PC and (trying to reduce e-waste) told the buyer to bring me his old setup, and I'd take a look at it. Recently I've been trying to repair laptops, mainly, with so-so results.
                                            I'm now looking at an AMD Desktop Kit with no display. Apparently this board reuses (possibly defective) Playstation 5 chips 4700s. It does not provide an internal GPU, or better say in any case it doesn't provide an output for the internal GPU.
                                            There was one obvious fault: One of the caps of the CPU power rail was missing, that happened when the previous owner was changing...
                                            12-03-2024, 12:09 PM
