Repair Fence Energizer SS-1000E Fi-Shock
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    #101
    Re: Repair Fence Energizer SS-1000E Fi-Shock
    would running it transformer out of circuit cause damage ? like nowhere for the energy to go to ?
    These transformers aren't like a flyback. More like an ignition coil. They are pulsed to both drive the transformer, and give time to clear "load" (a cow, goat, horse, grass, etc). They are normally run open, but that neon tube does clamp some of the larger pulses.
    On a side note: They run resonate at 10-15 Khz if you ever find one and want to make it into an HV transformer, but submerge it in oil if you do.
    Follow the white rabbit.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      if the 360Ω resistors still heats up with the transformer disconnected, only thing that could be causing it is a shorted main filter cap...?
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        #103
        Or the Diodes. But if they are gone that cap is damaged also.
          • 31157
          unlikely that running without a load will damage the transformer, i'v seen people test tv outputs with the anode cable in a jam-jar!!!
          • stormy1777
            • Oct 2015
            • 141
            "shorted main filter cap" would that be the huge 400V Capacitor ? I am too scared of that huge cap..? or is that the smaller cap 25v, which is now 50v.
            It may take a few days to get time to attempt fixing it, will take all that into account and provide new data at that time. I have also smaller diodes, so might replace the original/big ones. anyways, i may just order bunch of parts and replace some of them..
            resistors definitely heated without the coil, and going forward i'm limiting testing to 10-20 seconds max until that is clear, so will need to take parts off circuit and re-test them.
            Thanks again.
            Stormy
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              #106
              ^ Yep. The big bastard.
              • redwire
                • Dec 2010
                • 3912
                Posting the updated schematic.
                You could test this with a series light-bulb, to limit current and give some indication of current draw. With the transformer disconnected, the only load that could heat up the power resistors is that big motor starting cap. It might be breaking down at high voltages.
                • stormy1777
                  • Oct 2015
                  • 141
                  Guardian angles, I may have time tomorrow, I'm so scared of that big guy, but will deal with it.. question, assuming I PULL the 2 diodes OFF circuit , to test them. now energize the board with no load/coil connected, the resistors should NOT heat up, and if they do, then they are BAD/low quality? I'm trying to find ways to debug why they over heat, but definitely i need more time to work and report back.. so far i'm not seeing any cows or horses running loose, so i got a bit time. Farmer says that once they see it working, for a week or so they'll not touch the fence
                  • R_J
                    • Jun 2012
                    • 9581
                    With the transformer disconnected, the only way to heat those resistors is with a short across the large capacitor, nothing else will do it. except maybe 2 leaky/shorted diodes but they would both need to be bad at the same time.
                    It's the cap.
                    • stormy1777
                      • Oct 2015
                      • 141
                      OK, took some time to test/measure, all tests were done without Load/COIL as follows:
                      Test1: Pull 400v/16uF large capacitor OFF circuit (pull cable) and energize the board. that came OK, no heat even after 3 minutes.
                      Test2: Connect 400v/16uF to board, energize the board within 5 seconds the resistors become super HOT to touch, Immediately cut power!!
                      Test3: pull both diodes out of circuit, energize board, resistors do not get hot
                      Measured components as follows:
                      Measure1: on-circuit both resistors show exactly as 360 Ohm. when board energized both resistors get 230VAC to them.
                      Measure2: Off-circuit large capacitor shows as 16uF (see photo) also, ESR 0.01 (very low).
                      Measure3: 1N5408 diodes show resistance of 70K Ohm vs 10M Ohm (other direction) and 80K Ohm vs 360K Ohm. Testing other diodes from other boards, it seems the other direction should be infinity so, maybe both diodes are (partly?) bad after all???
                      The 1N5408 described here:
                      have 1000V/700V RMS/3.0A.
                      I'll try to energize with the spare 2A diodes and see if resistors get hot, either way I'll find new 1000V/3A diodes soon.
                      Thanks for any tips, looks like the big guy gets to stay for now since diodes are suspects
                      Stormy.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        yeah, diodes seem like they've seen better days. Even vacuum tube diodes have near infinite reverse resistance.
                        Now what caused the diodes to go bad... Better make sure the big cap didn't go leaky...
                        • stormy1777
                          • Oct 2015
                          • 141
                          [RE-RESOLVED]: Repair Fence Energizer SS-1000E Fi-Shock
                          Hi there!!
                          Maybe we can say Miracles do happen!!? Looking in pile of unopened parts, found these new diode strip, within 3 minutes the unit is back working, now ticking every second or so, and giving very good ZAPS, more sparky than before!
                          Left it running for 20 min, and resistors were COLD...
                          Lets see what the farm animals will think up this time around
                          This was a joyful and fun learning experience!
                          Thanks for the absolutely AMAZING encouragement ("dark humor"??) and thorough knowledge.. it came in very handy!!
                          If the big capacitor is leaky? Not sure how to test for that, time will tell maybe..
                          See photos of proof the unit is working, you can see the new diodes, new resistors as well as NEON lighting up.
                          Maybe lessons learned, when one resistor burns change the other, and when diode is "weak" change both I'll try to remember that
                          Thanks again.
                          Stormy
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            BTW, when we say that capacitor is leaky, we mean EPR or effective parallel resistance, not ESR. Simply use a regular ohmmeter (DC ohmmeter, not AC ohmmeter which is used for ESR) with the probes in the right direction and wait for the capacitor to charge up, the/all capacitor/capacitors should eventually show up as infinite resistance.
                            • goontron
                              5000!
                              • Dec 2011
                              • 4108
                              • US
                              #114
                              And y'all were second guessin' the guy who lives in the cowboy state
                              This ain't my first rodeo, padner!
                              • petehall347
                                • Jan 2015
                                • 4433
                                #115
                                i dont know if its those series diodes ..if its parallel i match the vf . not sure when in series if it matters .. thinking it might do .. be good to know if anyone knows .
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  don't need to match if in series, just like LEDs. However if dealing with reverse voltage they may need to be treated like capacitors and deal with the leak caused by the balancing...
                                  • redwire
                                    • Dec 2010
                                    • 3912
                                    The two series-rectifiers are good to 2kV PIV, so I think mains transients damaged that one. With +340V on the big cap, you have -1.6kV left
                                    Lightning, or line switching transients, a reverse-voltage spike can avalanche a diode and kill it. The 2x360R resistance limits any current through them but diodes don't take much avalanche current.
                                    I think an outlet could see 1,500V-2,500V spikes depending on the electrical system and nearby loads etc.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      lightning may well be the root cause, it's outside after all...
                                      • goontron
                                        5000!
                                        • Dec 2011
                                        • 4108
                                        • US
                                        #119
                                        I've seen diodes get blown out on these things often, so check those.
                                        My experience exactly. Even just a nearby strike will kill these things.
                                          • Jul 2011
                                          • 6057
                                          It nice to see that you have it back up and running again
                                          • jshhh
                                            Help repairing Yamaha RM1X synthesizer/groovebox - PCB trace for capacitor has been pulled off
                                            by jshhh
                                            Hi guys,
                                            I've been trying to restore this Yamaha RM1X groove-box I bought, and the first thing on my agenda was to replace a bad capacitor that was making it so that the screen was super dim. As I'm a complete novice I went and accidentally pulled off one of the trace pads for the SMD capacitor as I was removing it, pulling up some of the green PCB with it. I've been trying to repair it by gluing down copper tape from where it began to pull off and solder the capacitor on after...atm I've just been attempting to do the same kind of thing on rubbish PCBs I got at a recycling place,...
                                            03-26-2025, 07:05 PM
                                          • Xiran
                                            Macbook A1502 820-3476-a don´t turn on (measures included)
                                            by Xiran
                                            Hi to all:
                                            I have a Macbook pro model A1502
                                            Board 820-3476-a
                                            Liquid damage, cleaned with isopropyl.
                                            Don´t boot in SMC Bypass, it tries to turn on without luck (check voltages, for example 5v usb intermittent).
                                            I have two chargers, one is an original apple magsafe 85w 16.5-18.5v 4.6a max. And 60w generic clone.
                                            Sometimes Stays with orange light, fan OFF. No heat.
                                            Measures:
                                            CLONE:
                                            ppbus_g3h 12.55v
                                            PP3V42_G3H 3.41v
                                            PPVRTC_G3H 3.33v
                                            PP5V_S5 5.02v
                                            PP5V_S3...
                                            12-23-2023, 02:10 PM
                                          • Benass
                                            GigaByte Radeon Rx5700xt 8gb VDDCR_GFX_PWR_GOOD Signal is missing.
                                            by Benass
                                            This will be a headscratcher. I don't know how to break it down to a readable topic.
                                            Im troubleshooting Rx5700 GPU. Core voltage missing.
                                            I have schematics and Boardview.
                                            I'm currently troubleshooting a power management setup that involves the IR35217M and NCP81022 chips. I've encountered some issues specifically with the SM_ALERT#, SM_DIO, and SM_CLK pins, and I'm hoping to get some insights or suggestions from those who might have experience with these components. Current Observations:
                                            • The SM_ALERT# pin is active (pulled low), indicating a potential fault condition.
                                            10-11-2024, 01:58 PM
                                          • ohren
                                            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                            by ohren
                                            Hello!
                                            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                            Measured voltages with no load:
                                            After rectifier diodes
                                            12V: 6.17 V
                                            5V: 5.67 V
                                            Secondary transformer pins AC measurement (really don't know if this says anything)
                                            12V: 2-2.5 V
                                            5V: 1.04 V
                                            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                            03-18-2023, 10:33 AM
                                          • seppde
                                            AMD Desktop Kit - no display, no POST (?)
                                            by seppde
                                            Hey,
                                            I've recently sold a PC and (trying to reduce e-waste) told the buyer to bring me his old setup, and I'd take a look at it. Recently I've been trying to repair laptops, mainly, with so-so results.
                                            I'm now looking at an AMD Desktop Kit with no display. Apparently this board reuses (possibly defective) Playstation 5 chips 4700s. It does not provide an internal GPU, or better say in any case it doesn't provide an output for the internal GPU.
                                            There was one obvious fault: One of the caps of the CPU power rail was missing, that happened when the previous owner was changing...
                                            12-03-2024, 12:09 PM
