Repair Fence Energizer SS-1000E Fi-Shock
  • stormy1777
    • Oct 2015
    • 141
    Re: Repair Fence Energizer SS-1000E Fi-Shock
    Originally posted by goontron
    My experience exactly. Even just a nearby strike will kill these things.
    In this particular case, starting to think the WIRING is not 100% right, he was mumbling something about that, so now read up on how it should be done, may pay a visit to make sure enough grounding and no obvious (periodic??) shorts going on there
    It nice to see that you have it back up and running again
    Would not have been possible w/o the great support and spirit of folks on this board, keep up.. this is definitely not my day job, but I'll be sure to turn in future for help
    Lets hope this holds, and if not, I'll report just for the record, and will keep replacing the parts one by one
    Cheers.
    Stormy.
    • stormy1777
      • Oct 2015
      • 141
      Originally posted by eccerr0r
      BTW, when we say that capacitor is leaky, we mean EPR or effective parallel resistance, not ESR. Simply use a regular ohmmeter (DC ohmmeter, not AC ohmmeter which is used for ESR) with the probes in the right direction and wait for the capacitor to charge up, the/all capacitor/capacitors should eventually show up as infinite resistance.
      Dear eccerr0r,
      I was curious, so powered it up with open case, hopefully for the last time in a while the Ohm reading one side shows as 10M, flipping the leads shows it as OL (infinity) and when the TICK/neon light comes on, it goes to ZERO, so about every one second tick tick tick, it goes to zero, zero, other times it is OL/infinity..
      I think that is OK..
      Only thing now if it breaks it might be the resistors b/c some smoke did come out before diodes were replaced.. but they still seem OK, 360Ohm both.
      Signing off for now all'ya'all.
      Stormy.
        • 31156
        i'v seen those type of resistors smoking like a vape-pipe and still work fine when the fault is fixed.
        you just have to check the solder joints werent effected by the heat.
        • stormy1777
          • Oct 2015
          • 141
          Thanks, yeah, stopped it right away when it was in my possession, the first time it was in the farm, but then the second resistor burnt to the ground, so i guess it took all the "hear" so to speak. back side of board is clean/very good soldering for all parts..
          may report back in a month either way given the apparent "popularity" of this thread
          Stormy.
          • stormy1777
            • Oct 2015
            • 141
            Over a month passed, no failures, and fence zaps just right so the farmer reports. Thanks again!!
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              #126
              Good to hear. Nice to see one fixed instead of scrapped and a new one picked up from Murdochs or Tractor Supply.
              Follow the white rabbit.
              • jshhh
                Help repairing Yamaha RM1X synthesizer/groovebox - PCB trace for capacitor has been pulled off
                by jshhh
                Hi guys,
                I've been trying to restore this Yamaha RM1X groove-box I bought, and the first thing on my agenda was to replace a bad capacitor that was making it so that the screen was super dim. As I'm a complete novice I went and accidentally pulled off one of the trace pads for the SMD capacitor as I was removing it, pulling up some of the green PCB with it. I've been trying to repair it by gluing down copper tape from where it began to pull off and solder the capacitor on after...atm I've just been attempting to do the same kind of thing on rubbish PCBs I got at a recycling place,...
                03-26-2025, 07:05 PM
              • Xiran
                Macbook A1502 820-3476-a don´t turn on (measures included)
                by Xiran
                Hi to all:
                I have a Macbook pro model A1502
                Board 820-3476-a
                Liquid damage, cleaned with isopropyl.
                Don´t boot in SMC Bypass, it tries to turn on without luck (check voltages, for example 5v usb intermittent).
                I have two chargers, one is an original apple magsafe 85w 16.5-18.5v 4.6a max. And 60w generic clone.
                Sometimes Stays with orange light, fan OFF. No heat.
                Measures:
                CLONE:
                ppbus_g3h 12.55v
                PP3V42_G3H 3.41v
                PPVRTC_G3H 3.33v
                PP5V_S5 5.02v
                PP5V_S3...
                12-23-2023, 02:10 PM
              • Benass
                GigaByte Radeon Rx5700xt 8gb VDDCR_GFX_PWR_GOOD Signal is missing.
                by Benass
                This will be a headscratcher. I don't know how to break it down to a readable topic.
                Im troubleshooting Rx5700 GPU. Core voltage missing.
                I have schematics and Boardview.
                I'm currently troubleshooting a power management setup that involves the IR35217M and NCP81022 chips. I've encountered some issues specifically with the SM_ALERT#, SM_DIO, and SM_CLK pins, and I'm hoping to get some insights or suggestions from those who might have experience with these components. Current Observations:
                • The SM_ALERT# pin is active (pulled low), indicating a potential fault condition.
                10-11-2024, 01:58 PM
              • ohren
                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                by ohren
                Hello!
                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                Measured voltages with no load:
                After rectifier diodes
                12V: 6.17 V
                5V: 5.67 V
                Secondary transformer pins AC measurement (really don't know if this says anything)
                12V: 2-2.5 V
                5V: 1.04 V
                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                03-18-2023, 10:33 AM
              • seppde
                AMD Desktop Kit - no display, no POST (?)
                by seppde
                Hey,
                I've recently sold a PC and (trying to reduce e-waste) told the buyer to bring me his old setup, and I'd take a look at it. Recently I've been trying to repair laptops, mainly, with so-so results.
                I'm now looking at an AMD Desktop Kit with no display. Apparently this board reuses (possibly defective) Playstation 5 chips 4700s. It does not provide an internal GPU, or better say in any case it doesn't provide an output for the internal GPU.
                There was one obvious fault: One of the caps of the CPU power rail was missing, that happened when the previous owner was changing...
                12-03-2024, 12:09 PM
