Macbook A1502 820-3476-a don´t turn on (measures included)
  • Xiran
    • Jan 2019
    • 47
    • Qro
    Hi to all:
    I have a Macbook pro model A1502
    Board 820-3476-a
    Liquid damage, cleaned with isopropyl.
    Don´t boot in SMC Bypass, it tries to turn on without luck (check voltages, for example 5v usb intermittent).
    I have two chargers, one is an original apple magsafe 85w 16.5-18.5v 4.6a max. And 60w generic clone.
    Sometimes Stays with orange light, fan OFF. No heat.
    Measures:
    CLONE:
    ppbus_g3h 12.55v
    PP3V42_G3H 3.41v
    PPVRTC_G3H 3.33v
    PP5V_S5 5.02v
    PP5V_S3 ----
    PP5V_S0 0v
    SMC_LID 3.41v
    PP3V3_S5 3.33v
    PM_BATLOW_L 0.03v
    ORIG:
    ppbus_g3h 12.54v
    PP3V42_G3H 3.41v
    PPVRTC_G3H 3.33v
    PP5V_S5 5.03v
    PP5V_S3 -----
    PP5V_S0 0v
    SMC_LID 3.41v
    PP3V3_S5 3.33v
    PM_BATLOW_L 3.32v
    I have found water damage in components: c5010 and c5017, and sustitute (1uF both), like uploaded photo.
    Can anybody help me please?
    Thanks in advance
  • mon2
    • 14630
    PM_BATLOW_L 0.03v
    states the clone power adapter is not worthy enough to power this board. Sacrifice it at a nearby active volcano.
    • Xiran
      • Jan 2019
      • 47
      • Qro
      Originally posted by mon2
      PM_BATLOW_L 0.03v
      Good idea, =)
      • Xiran
        • Jan 2019
        • 47
        • Qro
        Somebody know, if the remade battery is ok? i didn't see the original polarity of the batteries...
        • mon2
          • 14630
          Battery repair is a very risky business as one wrong connection can lead to a fire or worse. Highly recommend that you consider to just replace the battery with a known good one. If available to you, Amazon is good for such sourcing since the customer (you) are able to return the item for any reason back to Amazon.
          • Xiran
            • Jan 2019
            • 47
            • Qro
            Thx for your answer mon2, actually, now it power on.
            two important factors:
            1) rebuild water damaged vias
            and
            2) Use original charger
            But the input is not the correct one. I solder the clone cable, to the original base, but it doesn´t work. so, the conclusion, the mac recognize the clone cable.​
            • Xiran
              • Jan 2019
              • 47
              • Qro
              UPDATE:
              Generic charger + original cable = turn on.
              • Xiran
                • Jan 2019
                • 47
                • Qro
                Excuse me,
                Does anyone know if there are any missing components here?
                I'm starting to think that something is missing here, and that's why it won't let me update the original bios...​
