GigaByte Radeon Rx5700xt 8gb VDDCR_GFX_PWR_GOOD Signal is missing.
  • Benass
    • Oct 2020
    • 73
    • Uk
    This will be a headscratcher. I don't know how to break it down to a readable topic.
    Im troubleshooting Rx5700 GPU. Core voltage missing.
    I have schematics and Boardview.
    I'm currently troubleshooting a power management setup that involves the IR35217M and NCP81022 chips. I've encountered some issues specifically with the SM_ALERT#, SM_DIO, and SM_CLK pins, and I'm hoping to get some insights or suggestions from those who might have experience with these components. Current Observations:
    • The SM_ALERT# pin is active (pulled low), indicating a potential fault condition. I understand this pin is an active low alert signal that indicates when the regulator status has changed, and it requires a pull-up resistor to function correctly.
    • The SM_DIO pin has a steady voltage of 3.3V, and the SM_CLK pin also measures 3.3V.
    Questions:
    1. Has anyone experienced similar issues with these pins, especially in the context of the IR35217M and NCP81022?
    2. What could be the potential causes for the SM_ALERT# being pulled low? Are there specific conditions I should check in the circuit?
    3. What troubleshooting steps do you recommend for ensuring that the SM_DIO and SM_CLK lines are communicating correctly?
    4. Could you share any resources or insights on proper pull-up resistor values or configurations that have worked for you in similar setups?
    [MOD EDIT] Link to schematic/boardview
    https://www.badcaps.net/forum/docume...1-0-board-view
    https://www.badcaps.net/filedata/fetch?id=3472710​
    I appreciate any advice or information you can provide. Thank you!
  • Benass
    • Oct 2020
    • 73
    • Uk
    Update:
    After doing some research, I learned that the IR35217M is a programmable chip and has USB005 along with software to monitor AMD GPU core voltage phases. I bought a dongle, installed a utility program, turned on telemetry, and received a report indicating an issue with phase 4.
    I took some measurements and found a shorted capacitor and one resistor on the same line. After replacing the faulty components, I got the core voltage working, and the GPU is now displaying an image.
    • Benass
      • Oct 2020
      • 73
      • Uk
      Unfortunately, Its crashing on Game benchmark like Heaven. So next is investigating memory and gpu core.
        AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
        The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
        10-01-2024, 12:46 PM
        Gigabyte Radeon RX 5700XT RX5700XT GV-R57XTGAMING-OC-8GD V1.0 Board View
        Gigabyte Radeon RX 5700XT RX5700XT GV-R57XTGAMING-OC-8GD V1.0 Board View...
        10-03-2024, 04:34 AM
        AMD Radeon RX 5700 XT (RX5700XT) Schematic & Board View
        The Radeon RX 5700 XT is a high-end graphics card by AMD, launched on July 7th, 2019. Built on the 7 nm process, and based on the Navi 10 graphics processor, in its Navi 10 XT variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 5700 XT. The Navi 10 graphics processor is an average sized chip with a die area of 251 mm² and 10,300 million transistors. It features 2560 shading units, 160 texture mapping units, and 64 ROPs. AMD has paired 8 GB GDDR6 memory with the Radeon RX 5700 XT,...
        10-01-2024, 12:06 PM
        Thermal pad thickness for various laptop GPU / Graphics Cards
        ASUS Dual RTX 2070 OC 8GB
        ASUS ROG STRIX RTX 3080 OC
        ASUS ROG STRIX RTX 3090
        ASUS TUF Gaming RTX 3080 OC Edition
        ASUS TUF GTX 1660 S-O6G GAMING
        EVGA RTX 3060 Ti XC GAMING 8GB
        EVGA RTX 3060 XC GAMING 12GB GDDR6
        EVGA RTX 3080 FTW3 ULTRA GAMING
        EVGA RTX 3080 TI FTW3 ULTRA GAMING
        EVGA RTX 3090 XC3 ULTRA GAMING 24GB
        Gainward RTX 2080 Phoenix GS Specs
        Gainward RTX 3070 Phoenix 8GB
        Gainward RTX 3080 Ti Phoenix
        GIGABYTE AORUS RTX 3080 MASTER 10G
        02-09-2024, 08:08 AM
        AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
        The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
        10-01-2024, 01:07 PM
