XBOX Original - Won't power on
  • BEEKAY22
    • Apr 2014
    • 12
    Hello, I am a big fan of the original XBOX and I decided to buy (another) one. Taking it home and plugging it in, I discovered that it didn't even turn on. I searched through the internet and I read a lot of people saying it's most likely a power supply issue, so I decided to look myself. I also have another original XBOX that works fine with the same power cords, so it's not a cable issue.
    So then I opened up both XBOX's. The one that works looks fine, the PSU is a DELTA brand and it shows no signs of wear on top or underneath. Everything on the motherboard looks fine as well.
    But then I opened the XBOX that just simply doesn't turn on, and I immediately noticed something out of the ordinary. The capacitors were bulging, sticking out, and a few of them have some residue at the top. This was something I noticed right away as the XBOX that works looked very clean, yet this one has capacitors that look dysfunctional.
    Here are pics of the capacitors on the motherboard for the XBOX that works:
    Now here is the broken XBOX's motherboard:
    As you can see, there is something very different going on with the broken XBOX. These capacitors say on the side: 3300uF 6.3V --- The brand name is nichicon.
    So what do I do now? Desolder and remove these bad capacitors and replace them with new ones? I checked the motherboard and nothing else looks wrong. I know capacitors are readily available and I hope replacing them with the one's in the broken box will make it work again.
    Either way I need to learn to solder, and I have no problem with that. I would rather fix it myself then have someone do it for me.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: XBOX Original - Won't power on
    Yes, you'll definitely have to replace all of those bulging and/or leaking capacitors. They have failed.
    This could prevent the unit from turning on. Unfortunately, there is no way to tell if anything else has been damaged, without first replacing the caps.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Yeah you really should replace those.
      As shovenose said, it is hard to tell if they are causing the failure, however quite often this is the case.
      Don't replace them with capacitors from the local electronics store, they are likely going to be cheap ones which aren't "low-esr".
      Nichicon does make good capacitors however, they did have a batch of bad ones.
      These should do the trick!
      Muh-soggy-knee
      • BEEKAY22
        • Apr 2014
        • 12
        Thanks for the reply guys.
        I prefer not to buy the caps from these online stores because shipping is quite a rip off, so I will be looking on Ebay.
        I believe these will work:
        http://www.ebay.ca/itm/2-x-PANASONIC...eaf6994&_uhb=1
        http://www.ebay.ca/itm/6-Rubycon-MBZ...b9532c5&_uhb=1
        • cheapie
          null
          • Jul 2010
          • 849
          Please, anything BUT eBay!
          • BEEKAY22
            • Apr 2014
            • 12
            Haha what's wrong with that, fake capacitors? I'd buy them off a reputable Ebay seller!
            • cheapie
              null
              • Jul 2010
              • 849
              Well, good luck with that...
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                get these.
                https://www.badcaps.net/store/produc...roducts_id=142
                ebay is a minefield of crap when it comes to caps and batteries.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  BCN might carry $6.00 shipping but if you buy the fake craps on eBay then they fail again in two months, you will not only have to buy new capacitors again, but waste all the time to do it all over again.
                  So buying from badcaps.net online store or another reputable company will end up being cheaper in the long run.
                  • BEEKAY22
                    • Apr 2014
                    • 12
                    Thanks for the replys guys, I very much appreciate your point of views. And yeah, I won't buy the caps from Ebay, it's too risky.
                    I will definitely buy them from the BC webstore, the price and shipping is reasonable so I'll just go with that. Before doing any of this, I'll first get used to soldering and desoldering on a spare broken XBOX motherboard and get the hang of it.
                    • Ed Herdman
                      • Apr 2014
                      • 31
                      Hello there,
                      I just wanted to register to mention that this is also a great time to check out the aerogel-containing supercapacitor. On the Xboxes I've seen, this is located at the bottom-left hand of the board (a ways to the left of the power supply connector). This has been covered at the forum already, but just to reiterate: You can (and should) remove this on any Xbox you see. Only version 1.6 models (made in roughly 2004) you will need to have a replacement ready; on older models, you can simply desolder it and not have to worry any longer.
                      Another fun and cheap tip - replace that 40-wire IDE cable with an 80-wire to slightly boost internal data transfers.
                      • Rulycat
                        • Apr 2010
                        • 724
                        • United Kingdom
                        Question - my Xbox (V1.1 model) doesn't keep time when unplugged. Never has done. Should I check this capacitor?
                        • Ed Herdman
                          • Apr 2014
                          • 31
                          Yes, that's a good sign that cap is dead.
                          (For the quick explanation of what's happening: Microsoft was too cheap to install dedicated low-power real-time clock chips, so they had to keep another chip powered for up to weeks at a time - coin batteries wouldn't have provided enough power, and aren't rechargeable. Unfortunately, aerogel caps don't do that well with the high temperatures inside the Xbox.)
                          It's easy enough to get in there; all you need are some Torx bits and the ability to pry back the outward-facing sides of the rubber feet on the console slightly. Doing this will leave a slight film, which the Torx punches through easily. You don't need to remove the feet completely. Once inside, things should be pretty obvious. Don't forget your Isopropyl Alcohol to wipe off any residue from capacitor leakage.
                          • BEEKAY22
                            • Apr 2014
                            • 12
                            Yeah both of my XBOX's are the 1.6 version, and I read a lot through out the internet about the leaky clock capacitor.
                            Now that you mention it, I'll probably replace the clock caps in my 1.6 XBOX's as well as soon as I get my soldering tools.
                            • Rulycat
                              • Apr 2010
                              • 724
                              • United Kingdom
                              I had it chipped when I got it so the screws are already visible. I'll get on this tomorrow, if I get the time.
                              • Mssimsin
                                Beekay, how did it go?
                                My xbox had the exact same capacitors fail. I have replaced then but it hasn't made a difference.
                                  • 31304
                                  replace the clock cap in 1.6 with something like a 220uf 6.3v or anything else laying around.
                                  the clock cap is pointless and never really worked, but the 1.6 needs some type of cap or it wont boot.
                                  the older boxes dont need any cap.
                                  • ldeveraux
                                    • Mar 2017
                                    Just registered to say that I had the same problem. Replace all 5 bulging caps from BC and everything is up and running again. Thanks guys!
                                    • tudrojopsi
                                      • Nov 2017
                                      • 9
                                      • Israel
                                      I have the exact same problem.
                                      What are the best capacitors to put instead of the defected ones?
                                      Should I just put another 3300uF 6.3v capacitors or are higher voltage capacitors better?
                                      Also, are Capacitance and Voltage the only things that matter? Does ripple current matter? If so, lower is better, right?
                                      Thanks!
                                      • Wester547
                                        • Nov 2011
                                        • 1269
                                        • USA.
                                        Thanks!
                                        Higher ripple current is better, and lower ESR is also better in this case. You would ideally keep the capacitance and voltage ratings the same. These would work fine as replacements.
                                        • OriginalDaggers
                                          XBox 360 All Polymer Capacitors
                                          by OriginalDaggers
                                          As the title says, Xbox 360 Polymer Capacitors, replacing all on a Kronos 1 revision board.
                                          I went over a thread here (Xbox 360 with blown caps) and gather some extremely useful knowledge!
                                          If I have things right, I can replace them TO
                                          x9 : 1500uF 16V 10x20mm
                                          TO: 470uF Nichicon FPCAP R7
                                          x2 : 820uF 6.3V 8x12mm
                                          TO: 2.5V 820uF Nichicon FPCAP R5
                                          On this revision, there are other 820uF polymer capacitors for GPU/CPU - I'll be replacing those anyway with the above FPCAP R5
                                          What's a good replacement for the smaller...
                                          This can be anything from game consoles to arcade games to anything else that doesn't really fit into any of the above categories. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
                                          02-20-2024, 12:49 PM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • tccyo22
                                          Xbox One Original missing 12v enable signal
                                          by tccyo22
                                          Hi there, I have an Xbox One original in which I have all the 1.8v, 3.3v and 5.0v standby power rails present, however my 12v rail is not turning on and the enable signal PSU_V12P0_EN from the SMC to turn the power supply on is missing. There is high resistance on this line so it's not shorted directly to ground which leaves me with not many options.
                                          Was looking at a schematic and see the enable is created by the SMC. I have 3.3v on SMC_RST_N_IN but I'm a little stuck on where to look next. Is it likely that the SMC has gone bad or am I missing something else (it's my first time with...
                                          08-14-2023, 06:06 AM
                                        • bulkchart32
                                          Wanting To Try Something With Extra Capacitors for my original xbox
                                          by bulkchart32
                                          i have a shipment of capacitors arriving friday. i'm wanting to try an experiment where i fill all the cap spots(instead of just the 3 spots) in front of the processors with 3300uf caps to see if the extra power being available to the gpu/cpu help the xbox's performance. my question is, is there any chance that this will damage the xbox? also, has anyone ever tried this before?
                                          10-07-2020, 04:54 PM
                                        • bulkchart32
                                          does anyone have a schemtaic for what circuit each cap is in on the original xbox?
                                          by bulkchart32
                                          i have a 1.1v and i am having issues with faint wavy lines on the screen that i am trying to make perfect so it will be my main xbox.. also have some 1.0v's that are doing it but to a lesser degree. i really don't want to do a full board recap, especially don't want to have to replace those smds, so i want to find which specific caps that filter the video signal. i have already replaced several caps and messed up one of them that caused a dead short(has been repaired). so i really don't want to just do all the caps. plus, those 1.1v boards have a lot of them. i'd really like to just focus on the...
                                          05-16-2025, 07:33 PM
