XBox 360 All Polymer Capacitors
  • OriginalDaggers
    As the title says, Xbox 360 Polymer Capacitors, replacing all on a Kronos 1 revision board.
    I went over a thread here (Xbox 360 with blown caps) and gather some extremely useful knowledge!
    If I have things right, I can replace them TO
    x9 : 1500uF 16V 10x20mm
    TO: 470uF Nichicon FPCAP R7
    x2 : 820uF 6.3V 8x12mm
    TO: 2.5V 820uF Nichicon FPCAP R5
    On this revision, there are other 820uF polymer capacitors for GPU/CPU - I'll be replacing those anyway with the above FPCAP R5
    What's a good replacement for the smaller caps they are..
    x12 : 100uF 16V
    x7 : 220uF 10v
    This can be anything from game consoles to arcade games to anything else that doesn't really fit into any of the above categories. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
    • 31283
    you can get 100uf and 220uf polymers
    going from 1500 to 470 is a mistake probably, why not fit 1500uf polymers?
    they are really cheap on aliexpress or if you can get kemet brand from regular suppliers
    • прямо
      • Sep 2022
      • 261
      • Indonesia
      1500uF 16V = 820uF 16V PCAP
      820uF 6.3V = 470uF 6.3V PCAP
      The polymer caps that are already onboard don't need to be replaced unless they have gone bad.
      The smaller caps don't need to be replaced with polymers.
      • OriginalDaggers
        the other thread stated, The Slim Models uses 470uF … I have yet to order any caps but digikey is my go to
        • OriginalDaggers
          Half the capacity? due to the faster discharge rate?
          • qwerty99
            Xbox 1.6 Motherboards and Polymer Capacitors
            by qwerty99
            Hello!
            I need to change the capacitors on my three original Xboxes.
            Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
            The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
            The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
            I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
            06-26-2022, 12:53 AM
          • burom
            Xbox 360 Xenon Modern Capacitor Replacements
            by burom
            I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
            I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
            06-07-2024, 05:10 PM
          • TMTGTR
            An Xbox One PSU Odyssey
            by TMTGTR
            Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
            =>Background:
            I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
            06-17-2022, 05:40 PM
          • Perry Babin
            Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
            by Perry Babin
            I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
            This is for the primary side of a switching power supply in a car audio amplifier.
            Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
            10-16-2025, 05:20 AM
          • foxer
            PS2 slims use polymer capacitors?
            by foxer
            Do we know if they do? My slim is a 70012 model, though I've seen these polymer-looking capacitors in another slim revision. The service manual says nothing (apart from the values), nor do google and the many other forums. I've already replaced all the obvious electrolytics -- with no performance problems after a year -- but these colored-top ones grouped in the back are a mystery, and I don't feel like potentially screwing up things.
            I think it's odd that apparently nothing exists online addressing these capacitors in ps2 slims in the nearly 20 years the console has been aroun...
            03-19-2023, 09:55 PM
