Original Xbox Aerogel Capacitor Removal/Replacements
  • Yatti420
    • Mar 2008
    • 130
    Hey..
    I saw that people had problems with an Aerogel Cap? Never heard of these.. Apparently used like a battery and keeps time on the xbox when unplugged.. Similiar to the cr battery in your desktop computer..
    I was reading https://www.badcaps.net/forum/showthread.php?t=8879 and wondering what value I should get for cap replacements and recommendations on where to go as I am in Canada.. Does a higher farad rating really give longer "battery" life in this application?..
    283-2776-ND (1.0F 2.5V aerogel) [stock value]
    283-2780-ND (3.3F 2.5V aerogel) I used these for a ludicrous amount of extra clock backup time.
    I'd like to replace mine aswell.. Might take a closer look at my PSUs aswell..
    Please let me know what you think..
    Thanks,
  • bluto
    • Oct 2007
    • 559
    Re: Original Xbox Aerogel Capacitor Removal/Replacements
    I used the 3.3F in one of my xboxes and it does give extra clock backup time. Although some have suggested just leaving it off because the replacement will likely leak someday too.
    • Yatti420
      • Mar 2008
      • 130
      Ok.. I do I will be doing the boxes I have shortly.. Can you confirm lead spacing is 5mm? I have this search on Mouser.. http://ca.mouser.com/Passive-Compone...z0sch4Z1z0scgs
      Do you know of this cap failing on lots of people?
      Thanks,
      • Gabriel
        • Jan 2010
        • 620
        • Norway
        Yes they do fail - https://www.badcaps.net/forum/showthread.php?t=25382
        • Yatti420
          • Mar 2008
          • 130
          Ok.. Is this a known problem with this type of cap? I'm just looking at these caps now..Think I have the search correct.. Can anybody confirm lead spacing / dimensions? Looks 5mm and 8.5 wide?..
          • Yatti420
            • Mar 2008
            • 130
            Nvm.. Took from Data sheet.. First xbox of the day.. Power supply is kapooty and aerogel had gone south.. It looks like it almost eats the surface mounted stuff around it....
            Having trouble getting the last pin out.. Once its free and everything looks good ill test them out minus the aerogel for now.. I'd like to have a long term high quality replacement.. Preferably same size dimensions as stock.. Looks like same series I can only increase to 2.2F from digikey..
            • Yatti420
              • Mar 2008
              • 130
              So first xbox of the day is complete.. Odd thing is it has poly caps in it around processor never saw this before.. Nichichon PW series elsewhere..
              Second box has same aerogel cap bad.. PSU (foxconn) in great shape though.. KZE around processor Nichichon PW elsewhere..
              I'm gonna assume the third box has same issue..
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                I don't think it is good to replace it with another aerogel branded capacitor, which is probably going to leak eventually like the old one.
                I'd use one from CDE or NEC or panasonic.
                Edit ... the thing is, almost all of the supercapacitors are rated at 1000 hours at 70 degreees celcius. Being inside a steaming hot XBOX, I can see why the original failed like it did...
                Muh-soggy-knee
                • Yatti420
                  • Mar 2008
                  • 130
                  This is an original xbox.. Shouldn't get that hot at all.. Problem seems to be age related.. All 3 boxes I have all have aerogel leakage.. So all 3 are coming out and replacements coming.. These are all v1.0 xbox.. Active GPU fan..
                  3rd box has poly caps around CPU and LXY series elsewhere.. LXZ on the powersupply for a nice match in this box.. PW(M) around the power area..
                  I Can stick with same brand easily.. Direct replacements seem cheapest.. I did see some panasonics avail which are rated for 60C.. 10C lower then stock..
                  I was thinking this as the dimensions should work height wise..
                  Panasonic Electric Double Layer Capacitors (Gold Capacitor) / HZ - 2.5V 3.3F
                  Mouser Part #:
                  667-EEC-HZ0E335
                  Manufacturer Part #:
                  EEC-HZ0E335
                  • shadow
                    • Feb 2007
                    • 732
                    Mouser Part #:
                    667-EEC-HZ0E335
                    EEC-HZ0E335
                    A direct replacement is probably cheapest. However replacing the aerogel with a capacitor of higher quality will probably last much longer (of course most likely at a higher cost).
                    • Yatti420
                      • Mar 2008
                      • 130
                      I can find the same brand and cap / or same brand slightly higher capacitence.. I just need to measure/fit everything to make Sure it works and fits.. I think the 2.2F was approx 8mm X 20mm with 3.5mm spacing ..
                      • Yatti420
                        • Mar 2008
                        • 130
                        I ordered these as a stock replacement.. 604-1149-ND.. Cheapest also not same brand as what im pulling out.. We will see how they hold up.. Should fit fine as the PW(M) is 10x20..
                        • japlytic
                          • Oct 2005
                          • 2086
                          On eBay Australia, I saw some Samwha 400F 2.7V supercaps at a great price - I think this would last without a recharge for a couple of weeks at least!
                          • Yatti420
                            • Mar 2008
                            • 130
                            I just needed something as a quick replacement to bring these boxes back to stock.. All 4 completed here.. No issues using the ELNA.. Only difference is as follows..
                            http://www.digikey.ca/product-search...rt=604-1149-ND
                            The comparison between stock and the ELNA equivalents are here.. Difference I see is ESR.. 1 Ohm (ELNA) versus 500mOhm (STOCK-ORIGINAL) Does this mean the ELNA will dissipate charge faster?
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              FYI: Aerogel isn't a brand but a material:
                              http://en.wikipedia.org/wiki/Aerogel
                              Which is used for, among other things, in supercapacitors:
                              http://en.wikipedia.org/wiki/Supercapacitor
                              IMHO this technology is still in its infancy... hence the lower durability.
                              sigpic
                              (Insert witty quote here)
                              • Yatti420
                                • Mar 2008
                                • 130
                                Re: Original Xbox Aerogel Super Capacitor Removal/Replacements
                                Indeed a supercapacitor.
                                • rogerTrutman
                                  • Apr 2014
                                  • 2
                                  • France
                                  thanks for all the informations !!
                                  • ohren
                                    Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                    by ohren
                                    Hello!
                                    I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                    Measured voltages with no load:
                                    After rectifier diodes
                                    12V: 6.17 V
                                    5V: 5.67 V
                                    Secondary transformer pins AC measurement (really don't know if this says anything)
                                    12V: 2-2.5 V
                                    5V: 1.04 V
                                    I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                    03-18-2023, 10:33 AM
                                  • tccyo22
                                    Xbox One Original missing 12v enable signal
                                    by tccyo22
                                    Hi there, I have an Xbox One original in which I have all the 1.8v, 3.3v and 5.0v standby power rails present, however my 12v rail is not turning on and the enable signal PSU_V12P0_EN from the SMC to turn the power supply on is missing. There is high resistance on this line so it's not shorted directly to ground which leaves me with not many options.
                                    Was looking at a schematic and see the enable is created by the SMC. I have 3.3v on SMC_RST_N_IN but I'm a little stuck on where to look next. Is it likely that the SMC has gone bad or am I missing something else (it's my first time with...
                                    08-14-2023, 06:06 AM
                                  • burom
                                    Xbox 360 Xenon Modern Capacitor Replacements
                                    by burom
                                    I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
                                    I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
                                    06-07-2024, 05:10 PM
                                  • bulkchart32
                                    does anyone have a schemtaic for what circuit each cap is in on the original xbox?
                                    by bulkchart32
                                    i have a 1.1v and i am having issues with faint wavy lines on the screen that i am trying to make perfect so it will be my main xbox.. also have some 1.0v's that are doing it but to a lesser degree. i really don't want to do a full board recap, especially don't want to have to replace those smds, so i want to find which specific caps that filter the video signal. i have already replaced several caps and messed up one of them that caused a dead short(has been repaired). so i really don't want to just do all the caps. plus, those 1.1v boards have a lot of them. i'd really like to just focus on the...
                                    05-16-2025, 07:33 PM
                                  • bulkchart32
                                    are these caps good for replacing the ones in front of the cpu/gpu on an original xbox?
                                    by bulkchart32
                                    nichicon
                                    1500 µF 16 V Aluminum - Polymer Capacitors Radial, Can 8mOhm 2000 Hrs @ 105°C
                                    are what​ i used because i had heard the voltage doesn't matter as long as it is more than the original cap. i'm now reading that high voltage may make the cap's esr too high. is this a good cap for replacing those oem ones?
                                    05-14-2025, 02:12 PM
