MSI 865PE Neo2-P (MS-6728) does not POST
  • gobbler
    • Jun 2009
    • 55
    Gotten this free faulty motherboard MSI 865PE Neo2-P that does not POST. CPU fan is spinning, POST card error code is d4b0. According to user manual, it is using AMIBIOS. No visible bloated caps, in circuit ESR reading for all caps quite normal.
    d4 error code :- uncompressed RUNTIME code
    b0 error code :- uncompressed SETUP code for hot-key
    Has the following caps :-
    KZG 1500uF 6.3V (x8) beside CPU
    KZG 1500uF 16V (x4) near MOSFETs
    KZG 1000uF 6.3V (x7)
    KZG 470uF 10V (x6)
    KZG 470uF 6.3V (x5)
    Any suggestion if I should desolder the caps near CPU to test?
  • gobbler
    • Jun 2009
    • 55
    Re: MSI 865PE Neo2-P (MS-6728) does not POST
    update, initially i ignored those 470uF caps. found one 470uF 6.3V in-circuit esr to be 0.7. i desoldered it and measured again, found to be 0.9. will be going to buy replacement cap soon ...
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      those are nippon chemicon. good brand, but that model is heat-sensitive and commonly fails in motherboards. they should be brown.
      sigpic
      (Insert witty quote here)
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        sounds like a failure to uncompress the bios.
        somebody had a flash fail?
        • gobbler
          • Jun 2009
          • 55
          not sure about flash failed. the guy who gave me told me cannot install windows but i cannot even get it POST!
          changed the defective 470uF 6.3V but the diagnostic POST card, error code keeps changing. something new.
          • gobbler
            • Jun 2009
            • 55
            removing the battery does not clear cmos, using the jumper to clear works. i managed to get a POST after jumper clearing cmos. tried installing windows xp, after booting up from cdrom, saw some text messages. it then goes into a blank screen.
            i thought it was bios giving problem, so i flashed to latest version. flashing bios successful message was shown on screen and so i rebooted after that.
            unable to get a POST after that, guessed i had damaged it.
            • lucky13
              • Aug 2007
              • 412
              Is this a known good p/s? Or, do you have a different p/s to test?
              Also, CMOS battery good, right?
              I should add that from what I have read, a successful write message means your flash process did not fail. So, fault is likely elsewhere especially your POST card gives different codes.
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                Not necessarily
                That should be true if booted into DOS, with no memory managers in CONFIG.SYS
                If done from a DOS prompt under Windows, anything is possible
                better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                • gobbler
                  • Jun 2009
                  • 55
                  lucky13,
                  it is a known good psu. working on another motherboard. anyway, i used another psu to test, same result. cmos battery is a new piece, measured it is 3.25V.
                  i would say now the POST card error code stays at D4 AF. as this is a MSI motherboard, it came with a D-bracket. the D-bracket has 4 diagnostic LEDs.
                  the LED1 is green, while LEDs 2-4 are red. it should be interpreted as "Early Chipset Initialization". does it mean, NB or SB is gone?
                  pfrcom,
                  i flashed the bios via a bootable floppy drive, the most primitive method.
                  • ant3202
                    • Jun 2006
                    • 275
                    • Singapore
                    check your north / southbridge for any burn marks
                    Years ago, I had one of a board with the same symptoms shown on d-led and upon inspection of the southbridge, a faint burn mark is found.
                    • gdement
                      • Jan 2007
                      • 690
                      I have an MS-6758 "875P Neo" board, which is probably similar.
                      I can get it to boot but it's unstable because I can't find a PSU that can actually run the thing. It's a pig.
                      So it's possible your PSUs are just overloaded trying to tow this particular board. Not that I'd go buying another one just on the theory.
                      • gobbler
                        • Jun 2009
                        • 55
                        if i pressed the power button for 4-5s, it can power off. so the southbridge should be working. inpection of the north bridge, dont see any burnt mark.
                        so i should ditch my thought of saving this board?
                        • gobbler
                          • Jun 2009
                          • 55
                          btw, anyone knows of a simple test for the north bridge?
                          • lucky13
                            • Aug 2007
                            • 412
                            LOL, I have several boards "saved up" that all do just that. Hopefully one day I will come across a solution.
                            • gobbler
                              • Jun 2009
                              • 55
                              further testing, i noticed the agp graphic card hsf is not even warm. there is a mosfet directly under the end of agp slot, seems to be short after testing with multimeter. since it is directly under the agp slot, it is not possible to take the mosfet out without taking the agp slot socket.
                              also, i tested with a pci graphic card, still no display. guessed i give up hope on this board. :P
                              • bgd73
                                • Nov 2009
                                bump
                                As mobos hang onto traits, I too found a mosfet short on a ms6728, all caps good.
                                it got hot enough to melt the paint and reveal copper, yet shut off fast enough to leave everything alone.
                                where to get part #s for mosfet?
                                the focus on caps has bewildered me for along time. It is not the caps. it is the mosfets bothering the weaker.
                                on a lighter note, I read the basic function hasn't changed since 1925. Oh the electronics is so advanced and awe inspiring...
                                • Calchaqui
                                  • Oct 2005
                                  • 112
                                  Any new about that msi? or it's just lying on the cementery
                                  I LOVE WWW.BADCAPS.NET
                                  • tranquility
                                    Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
                                    by tranquility
                                    i want to repair an Onkyo TX-NR809 receiver.
                                    symptoms:
                                    on power on, display appears and i hear one click. enue functions is given.
                                    - no hdmi output
                                    - audio output not tested, but i think it is not there
                                    - usb sticks are not recognized
                                    if i read out the chips with display+standby button + tone+
                                    both dts show only ????
                                    chip is D830K013BZKB4
                                    things i have done:
                                    - reflow of the dts chip without taking off and reballing
                                    - changed the aluminium caps without the big one with 25v because i dont...
                                    08-25-2025, 01:04 AM
                                  • Lostdotfish
                                    KZG caps failed on a NOS motherboard - never been used...
                                    by Lostdotfish
                                    This is a new one on me. I picked up a new old stock DFI 865PE Infinity board recently. It's completely new, never used. While inspecting it I noticed some unexpected bulging caps...
                                    All of the 6.3v 1500uf caps had failed in place, despite the board never seeing use and being stored sensibly. I pulled the 16v caps that are the same series as a precaution and will replace them all.
                                    10-15-2025, 04:29 AM
                                  • Quin TeknoLife
                                    Help identifying location of knocked off component on motherboard
                                    by Quin TeknoLife
                                    Supposedly arround pin 5 of the bios chip, it's not the chip with the green dot but the one oriented in portraid mode, pin 1 is the topright one. More (and uncompressed) pics on my gdrive https://drive.google.com/drive/folde...n2XuHvxtrzJL_e...
                                    02-13-2025, 04:19 PM
                                  • dragometin
                                    Hitachi 40HYC42
                                    by dragometin
                                    TV Model: Hitachi 40HYC42
                                    Power Supply: 17IPS71
                                    MainBoard: 17MB95M
                                    Panel: VES400UNDS-2D-NO3
                                    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                    Is there any variants on 17IPS71 power supply's?
                                    UART output pins 10 and 12 on scart connector:
                                    Code:
                                    12:24:04.595
                                    08-08-2024, 05:53 AM
                                  • bigbeark
                                    AMI BIOS questions
                                    by bigbeark
                                    I think there may be a BIOS problem with my ASUS P5-E. I addressed this with a post in the Asus motherboard forum, but I think this may be a corrupted BIOS problem, not hardware. The board booted once and loaded the OS. Now it's stopping in the BIOS
                                    The BIOS codes that show up on the PCI card are 85, 60 and D4(twice). This is using 1 stick of RAM and moving it from DIMM A1 to A2 to A3 to A4.
                                    85 is Password/soft error check (DIMM A1)
                                    60 is DMA #1 base register test (DIMM A2)
                                    D4 is Uncompressed RUNTIME code (DIMM B1 and B2).
                                    85 is very...
                                    03-11-2020, 07:02 PM
