Hello to all you guys here. I want to recap a few motherboards but they are all dusty. Is there any special solvents that can be used to clean the boards without doing any damage to them? I was thinking of using ordinary rubbing alcohol can it be used?
Cleaning Motherboards
Re: Cleaning Motherboards
Smokers in Jamaica?
This thread might be of interest.
https://www.badcaps.net/forum/showthread.php?t=1463
Welcome to badcaps.net Jamrock
Alcohol is ok, but Simple Green is realy a good (far better) stuff. I figured it out to obtain it, and for PCB cleaning i must say it is so far one of the best cleaning solutions i have used. If dust is the only concern, some canned air and vacuum cleaner is all you need.Comment
Welcome to the forums! ALWAYS take out the cmos battery and let the motherboard discharge before simple greening it. It works exceptionally well and should breathe new life into the board. Good luck!Comment
...no but we do have Simple Green (which is what you meant, right?)Originally posted by tazwegionWe can't get simply green down here in Oz
See my posts on this page.....
https://www.badcaps.net/forum/showth...?t=1463&page=3
In short, Bunnings has it.Comment
Hi All
Cods69, is this the stuff you are talking about mate
Simple Green GP
For that matter is this the stuff everybody else is referring too?
I did read that other post awhile backYou step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...Comment
Yep, that's it.
I found it in the cleaning isle in Bunnings.
I got a 2 litre bottle for about $20.
I use it for nearly everything now (I like the root beer smell) and you don't need to use much either as you can dilute it quite a bit.Last edited by cods69; 01-12-2007, 07:36 PM.Comment
Yep, thats the cool stuff we talk abouth. I have choosen to use Crystal Green, as i do not need green colour and good smell for cleaning elektronics. Last thing i cleand with it, was a Acer FP751, all the plastic`s part`s are realy brown, duno if it was smoke crap or just some other dirth, but it just driped away under the Simple green solution. Awsome.Comment
Hi Gonzo0815
Thank you too for your reply.....
I take it its this stuff
crystal SG
Great for Roads too
This mob seem to make a heap of stuff....cleaning units as well
There site is well worth a look through for info on how to use it etc
Enviro friendly....we need more stuff thats nice to our environment
Cheers
If they aren't covered in tobacco tar, I usually just take the battery out and any fans if present, then immerse in a detergent bath, lightly stroke with a paintbrush while immersed (easier than a toothbrush but you don't want to let any stray bristles stay behind in slots, etc) IF necessary, then rinse with tap water, shake out excess water gently (w/o flexing the board) and put next to a fan for a day.
Some try to be more exotic but this works fine for me, I've been cleaning like this for years. To me it would be a waste to use distilled water, alcohol, etc, unless you had something that needed it (like remaining flux residue).Comment
This is probably ok, but from my experience, something like coffee with mil and shugar is not that easy to remove from a well sophisticated board with lotsa larg PLCC`s.
And that is for me the situation, when i need something wich is working w/o mechanical power.
Distilled water shure is somehow overkill, but if the gear is expensive like laptop boards i would like to be on the save side.
Remaining flux is easily removed with a paint brush and some acetone.Comment
I don't like to use acetone because it can degrade certain types of plastics and even wash the print right off of labels immediately. Granted a paper label doesn't much like getting wet no matter what you use, but with alcohol or detergent there is a good chance it will survive fairly well.Comment
I only use lacquer thinner or acteone after I've replaced any caps and had to clean the remaining flux on the underside of the board. I use a q-tip or equivalent and gently brush around the solder connections. It seems to work quite well and I've not had any problems yet.Comment
A little bit of dawn and some fresh water will do fine as well. Nothing fancy. I keep a heat gun around and use it on warm since I don't want to wait overnight. I did a LOT of emergency reclaimation in the Navy. I use Isopropyl Alcohol to get the flux off my solder jobs.Comment
i worked in the electronics industry around 1984/5 where i was making the original psion organiser hand held. in them days we used to clean the PCB with freon which was boiled in a vat (boils at a very low temperature). we used to dip the assembled PCB into the freon for 2 or 3 minutes then remove it. the only problem was that you could not dip a board containing any variable resistors as they would have the factory applied lubricant washed out of them which would cause premature failure. considering that we also made a lot of boards destined for military use this would not have been a very good idea. freon has now been banned as it damages the ozone layer. to think that we used to dip our hands in the crap.Comment
That worked good but it's illegal to use Freon that way now.Mann-Made Global Warming.
- Dr Seuss
by rumi409 Hi,
I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...1 Photo -
I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.-
by howardc64Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
https://www.ifixit.com/Guide/MacBook...leaning/17792010-09-2024, 10:10 AM -
by claws77are there any resources that talk about cleaning keyboards thoroughly, by that i mean removing keycaps and cleaning.
i am worried about breaking those keycaps or the plastic retainer clip.08-12-2024, 07:46 PM -
by loopsterHello guys,
could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
Error 10: Failed to open with processed commands.
Unable to open file: C:\Users\Elitebook...1 Photo-
Channel: BIOS Requests ONLY!
- Loading...
