Macbook Dust-Gate Preventive Cleaning
  • howardc64
    • Jun 2017
    • 653
    Just did this on my 2021 13" MBP M1. Dust-Gate design flaw still present. Depending on cleanliness of the operation environment (often eating while using MB is probably the worst). Periodic cleaning is probably warranted.
    Note this is quite challenging effort. One misstep will damage the LCD flex and render it useless. So take it to someone more experienced if uncertain.
    https://www.ifixit.com/Guide/MacBook...leaning/177920
  • envym
    by envym
    Hi everyone!
    06-27-2025, 08:54 AM
  • Flasman90
    Macbook Pro DFU Restore Issues
    by Flasman90
    I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
    - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
    - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
    08-30-2025, 10:27 AM
  • tobeend
    Bypass mdm macbook m2 ventura
    by tobeend
    1. RESET MACOS WITH IPSW
    a. Power off MacBook, press and hold the power button to enter Recovery
    b. Open Disk Utility, remove Macintosh HD
    c. Reboot, connect to the network to Activate Mac.
    d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
    d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
    e. Release the other keys, but keep holding the Power key for another 10 seconds
    f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
    05-26-2023, 07:18 AM
  • SarcasticOP
    General question about MacBook power rails for repair.
    by SarcasticOP
    I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
    • PPBUS_G3H (12.6V-12.8V)
      • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
    • PP3V42_G3H (3.42V)
      • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
    • PPVRTC_G3H (3.3V)
      • This
    12-12-2024, 05:50 PM
  • obelix24
    A2941 Macbook air 15” - 5V 0a
    by obelix24
    I’m working on one macbook air 15” m2 that was water damaged.
    keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
    i’ve put macbook in shelf and order new screen so i can fully repair it.
    Now i got the screen and macbook stays at 5v 0a.
    i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
    i don’t have schematics so i don’t know where to start can someone help me?...
    03-27-2025, 01:19 PM
