Replacing electrolytic caps by solid caps on old motherboards
  • madscientist750
    • Aug 2023
    • ar
    I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
    I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
    I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
    • 31709
    the oldest motherboard i used polymers on was an amd K6-2.
    try to match the voltage and uf and diameter.
    if you cant find what you need wide enough then increasing the voltage rating is fine.
    a lot of old boards use 10mm caps and the placements may be 8mm unless you go up in voltage.
    DONT use polymers in the audio circuits - only for power smoothing.
    maybe post a new thread for each board with the details.
    • madscientist750
      • Aug 2023
      • ar
      I do believe this forum had capacitor lists for motherboards, should they still exist, how could i look for them?
        • 31709
        no idea.
        if you have the board then just make a list - then you will know it's correct anyway.
        • SwedishDiesel
          Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
          by SwedishDiesel
          Howdy folks,
          I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
          10-30-2021, 12:47 AM
        • Perry Babin
          How do organic polymer caps compare to liquid electrolytic for reliability
          by Perry Babin
          I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
          If not organic polymer, what would be the caps that could take the most abuse?
          08-18-2025, 04:04 PM
        • Noodneek
          Replacing all the caps on the BenQ SW2700pt's power board didn't help...
          by Noodneek
          My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
          I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
          08-30-2024, 12:52 PM
        • kotel studios
          TAGAN TG380-U01 PSU - 5v shorted after replacing caps
          by kotel studios
          Hi
          Recently I got this tagan tg380-u01 PSU with bad caps on 3.3v rail (the line was 2.5v no load!). Replaced them but no go, so I've replaced all of them, apart from some smaller ones and one under the secondary heatsink. Even that didn't help so I've replaced the others. All caps are known good ones.
          Powered it on and heard the breaker pop. Opened it up and saw some smaller caps shorted together. Fixed that up but still it trips breakers. Now I get 0ohms from 5v to GND. Secondary heatsink removed and still a short, even with the PWM IC board removed. All diodes on that...
          02-14-2025, 10:10 AM
        • bulkchart32
          are these caps good for replacing the ones in front of the cpu/gpu on an original xbox?
          by bulkchart32
          nichicon
          1500 µF 16 V Aluminum - Polymer Capacitors Radial, Can 8mOhm 2000 Hrs @ 105°C
          are what​ i used because i had heard the voltage doesn't matter as long as it is more than the original cap. i'm now reading that high voltage may make the cap's esr too high. is this a good cap for replacing those oem ones?
          05-14-2025, 02:12 PM
