Intel D945GCLF Bloated Samxon GC due to overheating
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Bought myself a complete ITX system some years ago on eBay, sadly the Socket A Jetway mobo in it died so I replaced it with the cheapest low power ITX board I could find at the time, the Intel D945GCLF mainboard... (Almost 3 years ago now)
    It is a Intel Atom 230 single core 1.6Ghz "beast" which I run IPCOP on.
    You might know that the original fan is really crappy and also not thermally controlled.
    I replaced it with a big copper heatsink hoping I could cool the fantastic Intel 945GC chipset passively.
    Well, about 30mins later the heatsink was over 100°C hot and the system crashed, so I put a fan ontop of it anyway
    Now I want this system to be silent since it is in my bedroom and runs 24/7 so it spins really slowly, still keeps the heatsink quite cool, temp sensor reads ca 40°C
    The CPU on the other hand is passively cooled with a tiny heatsink, it only becomes 50°C
    No wonder when it's rated at just 2W TDP, unlike the chipset which is rated for 22W TDP!
    Now Intel generally gets allot of credit for their designs, but I dunno on this one.
    First the choice of this ancient chipset using 12 times as much power as the CPU.
    Then ontop of that they put 4x electrolytic caps close to it, but the CPU which needs just 2W gets a nice Polymer capacitor? Meh...
    I contacted Big Pope and ordered some Samxon solid polymer caps from him
    Find below a list of the original caps, they where a custom order by Intel, the sizes do not exist in the Samxon catalog...
    Code:
    2x Samxon GC 1000uF 10v 10x12.5mm
    2x Samxon GD 220uF 6.3v 6x12mm
    Replacement capacitors:
    Code:
    2x Samxon X-CON ULR 1000uF 6.3V 8x11.5mm
    2x Samxon X-CON ULR 220uF 16V D6.3x11mm
    For information here are voltage readings under the capacitors, incase you have a similar board and would like to change any of the caps to another value. Note that the 220uF caps fit well however I had to bend the legs on the 1000uF because the leg spacing was too narrow...
    (Look at the photos to understand which cap is which)
    Code:
    Front left 1000uF: 1.11v
    Front right 1000uF: 1.57v
    Rear left 220uF: 1.57v
    Rear right 220uF: 2.54v
    The lone original polymer by the CPU sees 1.16v
    The little DC/DC PSU which can be seen in the upper left corner was already recapped by me with Samxons about 2 years ago because the orignal crap caps failed
    Last edited by Per Hansson; 09-17-2015, 09:26 AM. Reason: Added link to relevant older post.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Intel D945GCLF Bloated Samxon GC due to overheating
    To make it quieter why not just put one large 120mm fan over everything and run it slow?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      In case you didn't know, all the netbooks are the same too. I think the mobile 945 draws something like 6W, but that's still 3x the consumption of the Atom CPU. Talk about crappy design.
      A working TV? How boring!
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Th3_uN1Qu3; Yea I know, sad really
        I actually contemplated to buy a new ITX mobo based around the Intel NM10 chipset
        However it would be around $70 and I would need to do allot of research to know that my dual PCI riser with the 64bit Intel NIC would work...
        Much easier to just change some caps
        Actually the reason I noticed the failure was that the WLAN card stopped working, bunch of warnings about resets in the /var/log/messages logfile...
        Code:
        wifi0: hardware error; resetting
        wifi0: stuck beacon; resetting (bmiss count 11)
        370forlife; I've considered it but it's a desktop system so it would kind of defeat the desktop part (can't put anything ontop of it)
        In reality I've just been to lazy to haul the chassi off to work and just LASER cut it
        • lti
          • May 2011
          • 2547
          Those caps don't look like they were close enough to the heatsink or exposed to heat for a long enough time to have failed due to heat.
          How old is this board?
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            As I wrote in the first post the system has seen 24/7 usage for about 3 years now...
            With capacitors rated for 105°C with a lifetime of 2000h
            The temperature on the PCB where the capacitors are is 65°C (Note the two mosfets besides them...)
            The general rule of thumb says that for every reduction of 10°C in temp the capacitors life doubles, so that turns out to be 32000 hours / 24 = 1333 days / 365 = 3.6 years
            That's close enough since it is now 20°C inside, but yesterday it was 30°C in here
            • lti
              • May 2011
              • 2547
              I didn't see other components near them. That sounds like a poor design.
              • teigaff
                • Feb 2013
                • Switzerland
                I've the same board and it won't power up. The two big capacitors 10V, 1000uF are bulged. And one in the top left corner, it's a 6,3V, 3300uF, 10mm x 25mm.
                Because I don't know exactly which caps else are defective, I want to replace all. For the most I found replacements. They are totally 17 pieces:
                2 x 10V, 1000uF, 10mm, 15mm
                1 x 6.3V, 3300uF, 10mm, 25mm
                1 x 6.3V, 820uF, 8mm, 24mm
                5 x 10V, 470uF, 8mm, 12mm
                1 x 25V, 33uF, 5mm, 11mm
                2 x 6.3V, 220uF, 6mm, 12mm
                5 x 25V, 100uF, 6mm, 12mm
                Why you chosen: 6.3V, 1000uF and 16V, 220uF? That's crossed. Is that possible?
                I didn't find the: 6,3V, 220uF on the online store. Which should I choose?
                Thanks for the explanation.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  I choose the caps I did based on what was available. (It's always fine to increase voltage).
                  As you can see in my first post the 1000uF 10v caps only see ~1.5v so reducing voltage in this case is fine aswell...
                  Interesting that your 3300uF 6.3v Samxon GD cap in the corner has failed too, I have not replaced that on my board...
                  Yea probably if that capacitor has failed too you should replace all caps, because I think then your system has been running too hot...
                  How does the caps in the powersupply look and maybe you should look at improving the airflow aswell?
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    Samxon capacitors ... so-so quality
                    Muh-soggy-knee
                    • teigaff
                      • Feb 2013
                      • Switzerland
                      I received this board from a friend of friend from him without power supply. When the board will be alive again, I'll look for a power supply.
                      So I can take a 220uF 16v 6mm ZLH Series as replacement for my 6,3V, 220uF. Right?
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        those boards started dieing at the 1 year mark in some industrial pcs i service.
                        and there is a chiller on the cabinet.
                        the few that had rubycons from the factory are still ok.
                        i preemtively fixed all the others and half were bulging at 1 year.
                        were still running but were not stable.
                        this run was 400+ units and they had to be pulled and mailed to me.
                        lets just say this client will never spec an intel board again for these builds.
                        the first 6 he bought in the developement phase all had rubycon.i greenlighted them figuring they should be ok for the 5 year warrenty on the product.
                        the samxons showed up in later shipments.intel blew them off when we noticed failures.
                        we reserve the right to substitute components of equal quality.
                        nice!
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          And it's not even a Core i5! Wow! They shouldn't even have issues of caps being stressed, much less a cap failure within just 1 year.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4951
                            • New Zealand
                            And I thought only dodgy Chinese component suppliers pulled that trick.
                            -David VanHorn
                            • theokretes
                              • Jul 2013
                              • 49
                              Samxon capacitors are low quality: after I did a lot of research and analyzed a bunch of failed hardware sporting them I wouldn't even rate them so-so. Super high failure rate, poor filtering.
                              Interestingly enough, I had an intel atom board which came OEM with samxons (along with other bad caps)-- I replaced them with some nice rubycons and ELNAs.
                              • Half-Saint
                                • Jan 2010
                                • 213
                                • Slovenia
                                Aren't Samxon caps being sold by this same website as "good quality"?
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  They are good quality for Chinese caps. While some don't like them, i have only encountered 2 failed series so far: GF and GC. This site does not carry any of them.
                                  Also some people regard Taicon as a bad cap brand. Well, Delta uses them with very few issues, and they're very cheap, and certainly better than no-name Chinese ones. I use Taicon caps to recap low-end PSUs and they seem to hold up fine.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4951
                                    • New Zealand
                                    I like the look of Taicon also. Seen several Taicons still perfectly fine and in spec while all surrounding CapXons had blown their vents out.
                                    -David VanHorn
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      Any capacitor will fail with a shitty board design like this.
                                      Read what I posted in my original posts above, the lifetime is as expected from the capacitors datasheets.
                                      Apple computers fail in the same way with Rubycon capacitors, it does not mean there is anything wrong with the capacitors there either!
                                      In my case I replaced the Samxon GC caps with Samxon ULR polymer caps, it's been running fine like that for another 3 years now...
                                      • Wester547
                                        • Nov 2011
                                        • 1268
                                        • USA.
                                        Delta also use LTEC without issue in their well ventilated and cooled power supplies, and we all know LTEC aren't good quality (probably about the same as Teapo, in my opinion... keep them under a certain temperature and they survive). :P That being said, given the ratio of failed LTECs to failed Taicons, I'd say Taicon is worlds ahead in quality excepting their HD and HI series which seem to be notorious for failing on motherboards every which way. CapXon are definitely garbage though. Often it's EVERY single one that is blown in LCD TVs and LCD monitors, not just a couple of them. I'd still guess that even Taicon capacitors age quite a bit faster than any of the Japanese counterparts because the raw materials are not of the same quality.
                                        I'd say Samxon is good quality as well (it may be hard for many to trust Chinese manufactures given that most brands suck). A couple of crap series does not make them crap. Adhering to that mindset, Chemi-con is no good.
                                        • Ven
                                          Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                                          by Ven
                                          Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                                          Issue Description:
                                          1. CPU Overheating to 100°C
                                            • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                                            • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                                            • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                                            • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                                            • Thermal
                                          02-12-2025, 03:57 PM
                                        • Nagyesz
                                          Dell inspiron 13 5000 - Doesn't turn on, overheating
                                          by Nagyesz
                                          I have a Dell laptop with me, a DELL inspiron 13 5379. It doesn't turn on. After some investigation, I found that the charger is delivering 0-3V instead of 19.5V, and this voltage fluctuates constantly. Additionally, two ICs are overheating. I searched for these ICs, and it seems they are likely related to the issue of not having 19V.
                                          Should I inject voltage somewhere, or should I replace the ICs right away?
                                          So, PU4301 is overheating, and the surrounding area is hot, possibly just because of this IC.
                                          07-13-2024, 11:27 AM
                                        • Tomylee
                                          Nintendo 2DS XL – Orange light, no blue light, signs of overheating
                                          by Tomylee
                                          Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
                                          Here's what I've observed:
                                          All ribbon cables are properly connected
                                          Battery is present and in good condition
                                          No reaction even with screens disconnected
                                          There's a visible burn mark / overheating sign on the metal shield, right above the CPU
                                          I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
                                          06-26-2025, 02:33 PM
                                        • chth96
                                          Can I replace KME cap with Samxon GF cap?
                                          by chth96
                                          Hello.
                                          I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                                          Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                                          I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                                          04-17-2024, 07:11 AM
                                        • platinumsteel
                                          Samsung S20 Ultra Charging Stopped Phone Overheating
                                          by platinumsteel
                                          Hi guys i have a Samsung S20 ultra (SM-G988U) whenever i plug in my charger it throws a Charging Stopped because phone is overheating and it makes a beeping noise. I have seen that there is a THERMISTOR on the sub board for the charging port and if this is broken or loose in any way the CPU will think something is wrong with the port and throw the error. This happened to me after i was reflowing the tuner IC's on the suboard trying to repair a no service half airplane mode issue I was having. I have already ordered a replacement port and a flex cable. But it will take 2 weeks to arrive but in...
                                          02-26-2024, 09:30 PM
