Bought myself a complete ITX system some years ago on eBay, sadly the Socket A Jetway mobo in it died so I replaced it with the cheapest low power ITX board I could find at the time, the Intel D945GCLF mainboard... (Almost 3 years ago now)
It is a Intel Atom 230 single core 1.6Ghz "beast" which I run IPCOP on.
You might know that the original fan is really crappy and also not thermally controlled.
I replaced it with a big copper heatsink hoping I could cool the fantastic Intel 945GC chipset passively.
Well, about 30mins later the heatsink was over 100°C hot and the system crashed, so I put a fan ontop of it anyway
Now I want this system to be silent since it is in my bedroom and runs 24/7 so it spins really slowly, still keeps the heatsink quite cool, temp sensor reads ca 40°C
The CPU on the other hand is passively cooled with a tiny heatsink, it only becomes 50°C
No wonder when it's rated at just 2W TDP, unlike the chipset which is rated for 22W TDP!
Now Intel generally gets allot of credit for their designs, but I dunno on this one.
First the choice of this ancient chipset using 12 times as much power as the CPU.
Then ontop of that they put 4x electrolytic caps close to it, but the CPU which needs just 2W gets a nice Polymer capacitor? Meh...
I contacted Big Pope and ordered some Samxon solid polymer caps from him
Find below a list of the original caps, they where a custom order by Intel, the sizes do not exist in the Samxon catalog...
Replacement capacitors:
For information here are voltage readings under the capacitors, incase you have a similar board and would like to change any of the caps to another value. Note that the 220uF caps fit well however I had to bend the legs on the 1000uF because the leg spacing was too narrow...
(Look at the photos to understand which cap is which)
The lone original polymer by the CPU sees 1.16v
The little DC/DC PSU which can be seen in the upper left corner was already recapped by me with Samxons about 2 years ago because the orignal crap caps failed
Code:
2x Samxon GC 1000uF 10v 10x12.5mm 2x Samxon GD 220uF 6.3v 6x12mm
Code:
2x Samxon X-CON ULR 1000uF 6.3V 8x11.5mm 2x Samxon X-CON ULR 220uF 16V D6.3x11mm
Code:
Front left 1000uF: 1.11v Front right 1000uF: 1.57v Rear left 220uF: 1.57v Rear right 220uF: 2.54v
