ViewSonic VA903b
  • 820uF
    • Apr 2012
    • 39
    • Russia
    Re: ViewSonic VA903b
    got the same model monitor.
    power button does nothing, no powerup when power cable attached, no caps bubleing.
    transformer seconderies seem to be ok one 789 second 791.
    what could be the problem?
    • 820uF
      • Apr 2012
      • 39
      • Russia
      hi-res pic of it
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Check the main fuse. If the fuse is good, check the voltage on the biiig black filter capacitor.
        Muh-soggy-knee
        • 820uF
          • Apr 2012
          • 39
          • Russia
          main fuse is ok.
          The 400V cap you mean while power is connected ?
          • Rtech
            • Jul 2010
            • 1095
            Yes, measure DC volts with power on ...'BE CAREFUL'.
            At the top of your picture there are 3 diodes,with Power OFF put your meter on Diode Test and measure across each.If you have not got Diode test then put on Resistance.At least one of these tend to go short circuit,which results in no voltage out.
            • 820uF
              • Apr 2012
              • 39
              • Russia
              #26
              318V it shows.
              big yellow transformer makes hearable static.
              can there be soething?
              • selldoor
                Slow Learner
                • 7870
                #27
                318V is OK can you check the volages on the connector to the main board.
                (Black and red wires) You need to have the boards connected and the lights if possible. Set meter on 20 VDC
                Black probe on a ground screw then check each pin on the socket and post the results.
                Did you test the 3 diodes as per Rtechs post no 25
                • 820uF
                  • Apr 2012
                  • 39
                  • Russia
                  #28
                  Measures with beep function:
                  1. 530
                  2. 232
                  3. 232
                  Measures with 2k diod function:
                  1. .629
                  2. .269
                  3. .269
                  Measures between ground screw and these pins:
                  1. 0,01V
                  2. 0.01V
                  3. 5,03V
                  4. 5,03V
                  5. 0,00V
                  6. 0,00V
                  • selldoor
                    Slow Learner
                    • 7870
                    #29
                    Ok for diodes you need to measure in both directions
                    Most tests we use are in this guide written by retiredcaps start at post 19
                    https://www.badcaps.net/forum/showthread.php?t=10419
                    On the voltage picture I notice a 24v on the board. If that is a list of what you are supposed to get on that connector, please can you list it.
                    Also if the top one is 24v you need to test it with meter on higher than 20vDC - sorry.
                    I have been reading the rest of this thread. It seems that on your board the 1000uf
                    caps generally fail and they recommend replacing the startup cap which is a small one on the primary side. 50v 10uf
                    • 820uF
                      • Apr 2012
                      • 39
                      • Russia
                      #30
                      Measures with 200 ohm function:
                      1. nothing both ways
                      2. 198,0 back on cathode side, second way nothing
                      3. 198,0 back on cathode side, second way nothing
                      I think the markings on PCB belong to another model.
                      Tere is marked 9 pins on PCB but it only has 6
                      replacing that small capiside the corner of that heatsink ?
                      ok i'll try
                      Thanks!
                      • selldoor
                        Slow Learner
                        • 7870
                        #31
                        As it measured more than 200 previously you need to increase the scale
                        please check them again on 2000.
                        When you say "Nothing" do you mean 0 zero or 1 as in off scale (same as probes apart.)
                        Yes since I asked about the board label I saw it on another picture so we can only guess what we should have.-
                        Hopefully changing the start up cap will help. How a bout the 1000uf you can use a 16v or 25v- I can only see the mains fuse on the board is that the only one?
                        • 820uF
                          • Apr 2012
                          • 39
                          • Russia
                          #32
                          i ment 1 - off the scale
                          Measures with 2k ohm function:
                          1. .625 back on cathode side, second way off scale (on 20k function it shows 7,53)
                          2. .267 back on cathode side, second way it shows 1,639
                          3. .267 back on cathode side, second way it shows 1,635
                          Changeing that 50v 10uf cap didn't do much
                          Only raised voltage 5,03V to 5,04V
                          • Rtech
                            • Jul 2010
                            • 1095
                            #33
                            Your Post 28 shows:-
                            1. 0,01V
                            2. 0.01V
                            3. 5,03V
                            4. 5,03V
                            5. 0,00V
                            6. 0,00V
                            which actually can be confusing as it looks as your numbering is not corect based on the Legend showing the voltages expected.Your pin 1 is actually pin 3,your pin 2 is 4 etc etc,So what you have got is
                            Adj.....0.1 v
                            On/Off..0.1v
                            5v..5v
                            5v..5v
                            Gnd..0v
                            Gnd..0v
                            So does the 5v vary when everything is plugged in and switched on, with an input signal ?? Have you changed the 1000uf capacitor ?? do you get a voltage on the on/off pin when you initally switch on ??
                            • 820uF
                              • Apr 2012
                              • 39
                              • Russia
                              #34
                              5v pins are soldered togeter on the other side. the do not vary.
                              Replaced 16V 1000uf with new one - still all same
                              tried 25v 1000uf cap (as one did here) - still same.
                              • selldoor
                                Slow Learner
                                • 7870
                                #35
                                Ok Can you disconnect the main board and with the lights plugged in and the board
                                plugged into the mains can you apply 3 volts to the on/off pin. Use 2x 1.5v batteries.
                                negative to a ground pin. Or if you have a 10k resistor connect the 5v to the on/off pin.
                                We are also going to need pictures of the Main Board - can you post them
                                (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                                Examples of what is needed
                                https://www.badcaps.net/forum/attach...7&d=1280167246
                                https://www.badcaps.net/forum/attach...6&d=1280167246
                                https://www.badcaps.net/forum/attach...4&d=1280167246
                                • 820uF
                                  • Apr 2012
                                  • 39
                                  • Russia
                                  #36
                                  Used some not so full 1,5 batteries on on/off pin. Got 2,7V outof these.
                                  It powered up the LCD - all pixels white.
                                  Here's some pictures:
                                    If the backlights stay on without going black using external force on power source, then your power supply/inverter board is OK. The screen is showing white due to the main board is not getting the power. Now you will have totroubleshoot the main board.
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #38
                                      I hate it when we get it down to the mainboard - it does not seem that we get them fixed very often.
                                      Start with testing the voltage regulators - think I see two but look for more.
                                      One is at U3 and one at U7.
                                      Retiredcaps has prepared a guide on how to find ,test and post results.
                                      https://www.badcaps.net/forum/showthread.php?p=261329
                                        Here is the service manual.
                                        • 820uF
                                          • Apr 2012
                                          • 39
                                          • Russia
                                          #40
                                          U3
                                          1. 5.04v
                                          2. 3,30v
                                          3. 0,00v - is this normal ?
                                          4. 3,30v
                                          U7
                                          1. 3,30v
                                          2. 1,80v
                                          3. 0,00v
                                          4. 1,80v
                                          U4
                                          1. 3,20v
                                          2. 3,20v
                                          3. 3,23v
                                          4. 0,00v
                                          5. 0,00v
                                          6. 0,00v
                                          7. 0,00v
                                          8. 0,00v
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • wattage
                                            AOC AG493UCX 49-inch monitor - Firmware request
                                            by wattage
                                            Hello Badcaps Community,
                                            The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                            07-13-2025, 04:41 PM
                                          • ant3202
                                            HP 27es - LED monitor - Monitor Flashing On - Off
                                            by ant3202
                                            Hi Everyone
                                            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                            https://www.badcaps.net/forum/troubl...lashing-on-off
                                            The monitor is HP 27es LED Monitor
                                            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                            The monitor will randomly blackout and display no signal and will recover again.
                                            Sometimes need to power and off again to restore the display but...
                                            03-20-2025, 07:30 PM
                                          • Rick_1234
                                            LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                                            by Rick_1234
                                            Good evening, gentlemen.
                                            I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                                            To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                                            https://drive.google.com/file/d/1L6S...ew?usp=sharing
                                            Things I tried
                                            - Bought a new AC adapter thinking that was the problem but the problem...
                                            06-22-2024, 04:44 PM
                                            Wise Wing F199 19'' LCD monitor - recapped
                                            by momaka
                                            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                            When I saw the Craigslist post, I wasn't...
                                            08-24-2020, 10:58 AM
