ViewSonic VA903b
    Re: ViewSonic VA903b
    The results are not much use without the part number to verify what they are meant to be. U4 and U7 are probably ok - you have presented the results
    in the wrong format -
    "3) Put your red probe on each of the pins including any "cut" or "stub" pin, but ignore the "fat" tab. The fat tab is "up" or "north". Number the pins left to right.
    4) Report them like below along with the part number (include all lines on the IC) of the IC. Don't report "they all tested good". About once every 2 weeks, we get someone who reports that only to find out they did the arithmetic wrong or mis-interpreted the results. So report all the readings."
    If you are still online you may be able to edit the results in which case I will edit this out.
    U100 -> pcb designation
    AS1117-33 -> line 1 of the IC
    0506 -> line 2 of the IC
    pin 1 = 0.000
    pin 2 = 3.301
    pin 3 = 5.001
