HannsG HW173D dead. Recap = new fault.
  • stuartherring
    • 11
    I've been given a HannsG HW173D LCD display that doesn't work, to keep or throw out. So I thought I'd see what was wrong with it.
    Original Fault : display didn't light, power LED flashed Green then Orange, with a curious flick in color.
    Opened it up, found bulging CapXon capacitors on PSU. Changed these for caps I had lying around, including 2 from an old TV set.
    Original (CapXon) Replaced with
    1000uF 10v 1000uF 25v (from old TV)
    1000uF 10v 1000uF 16v (from old TV)
    450uF 25v 450uF 35v (Sanyo, New)
    This improved things. Display now lights up, LED turns green, then back to amber if no signal on DVI or PC input, or stays green if there's valid signal.
    But the display isn't good. See attached pictures. Usually, I get the vertical colored lines. Sometimes I get a lava lamp effect with a few horizontal lines.
    At this point I started googling and found this wonderful site! Thank you in advance! I kinda knew that bulging caps weren't a Good Thing, which is why I changed them, but didn't realise how bad the problem was. Spent hours reading the useful stuff you have here.
    Measuring the voltage from the PSU board/ Video board connector, I noticed something interesting and wondered if it was relevant.
    +5v is at +5.31 - +5.33v all times. But +12 changes. If PSU is powered on it's own, +12 line is +12.09v.
    If Video board attached, LED orange, then +12 line is +12.91 - +12.94 (slight fluctuation)
    If video board attached, LED Green, then +12 line is +13.95 - +14v (slight fluctuation)
    With display connected and running, +12 line stays steady at +14.65v
    Should this concern me?
    Is it wortth me recapping with new, good caps? (the old TV ones were all I had to hand! ) Or does the fault seem more serious, given the strange display I've got on the LCD. Should I just chuck it out?
    My knowledge of electronics is self taught and patchy, but not totally ignorant. (I knew bulging caps were bad before reading this site )
    Any advice would be gratefully received.
    Hope attached pics help. The 3 loose caps are the ones I took out (notice bulging on 2 of them). The close up of the caps near the heatsink are the ones I put in. I see no other sign of damage on the board or to other caps.
    Stu
  • aubrey52
    • Nov 2009
    • 29
    Re: HannsG HW173D dead. Recap = new fault.
    strange display mi be bad lcd screen.
    ck all cap sec time round to make sure. some of your old cap mi be bad.
    do you have ESR meter, you can ck all of you cap on board.
    if not buy one it will help you down road.
    would p.s look see if p/s board have ic part number 203d6
    i need know voltage on all of 8 pin and voltage on ic 431
    thanks
    let me know asap
    here service manaul for you
    • stuartherring
      • 11
      Thanks, off to check voltages now.
      I realise the caps I put in as replacements might be bad, that's why I wondered if it might not be worth bothering to replace all the caps with new ones if there's likely to be a more serious fault elsewhere. But was encouraged by getting the thing to power up, even if I don't get a sensible display.
      I don't have an ESR meter Only test equipment I have is digital voltmeter!
      Stu
      • stuartherring
        • 11
        I don't see any ic marked 203d6 on either side of the p/s board. (I googled that, I see it is an 8 pin surface mount IC. Only 8 pin surface mount IC that I have on this board is on the underside, and it's marked sp8k3, so I don't think that's it).
        Nor do I have an ic 431 on the board! Only ic I can see is IC230, which is a 3 pin thing in a transistor-style package. Can't read what is actually printed on the package, just IC230 on the PCB next to it.
        I also note that the circuit diagram you kindly attached refers to caps in the 900 range, ie C904, C909. Mine are marked in 100 200 300 ranges. Are we talking about the same board? Have a look at the pic I sent in my first post, praps it's a variant on the board you're thinking of? Or praps I've missed something obvious?
        Any other thoughts? I was all excited I'd get this thing going this evening!
        Stu
        • stuartherring
          • 11
          Additional info :
          The p/s board is marked AC INPUT 100-240V 1A 50/60Hz DC OUTPUT +12V 0.4A +5.2V 3.0A
          P/N 3BS01 46412GP
          (also says FSP032-2PI01)
          Googling for this shows it as VIEWSONIC, N/A, PC MONITOR - POWER SUPPLY, FSP032-2PI01, 3BS0146412GP at discount-merchant.com, so this board isn't limited to just my model of LCD display.
          But there I remain stuck.
          Stu
          • aubrey52
            • Nov 2009
            • 29
            The 5 capacitors that need to be replaced are shown on the right circled in yellow. The values and positions are as follows: C303 is 220uf 25volt, C261 is 470uf 25 volt, C241 and C244 are 1000uf 10volt and C242 is 470uf 10volt. Remember to install the replacement capacitors with the polarity stripe going the same direction as the old ones come out.
            did you do this
            let me know good luck
            i thanks for offer to look at voltage for me
            ck my board it is litte differ
            i hop this help you fix it
            aubrey51
            • aubrey52
              • Nov 2009
              • 29
              i for got tell you not to used 85cm capacitors
              must be replace with 105cm capacitors
              heat will kill 85cm will stop working
              105cm temp is 105 deg just look capacitors marking 85 no good
              105 good tv used lot of 85cm capacitors
              i hop help you lot
              thanks
              aubrey52
              fot got tell you i got this from differ tech such fix your monitor
              • terry
                • Oct 2007
                • 91
                • Milton Keynes, Bucks
                Hi Everone, I have 5 off these moitors, recaped them all but thay still will not switch on. Have tested the power-inverter board in a working one, so I know the power-inverter boards are ok. If I press the power button I do not get anything. Not sure what to do next.
                Thanks for any help
                Terry
                • PlainBill
                  • Feb 2009
                  • 7034
                  Thanks for any help
                  Terry
                  That one sounds familiar. Let's try a few things.
                  First of all, what do you mean by "I do not get anything". Does the power LED come on or not?
                  Second, have you tried swapping the logic card from a 'good' monitor to one of the 'bad' monitors?
                  Last, if these tests show the problem is the logic card, post good pictures of the top and back sides of the logic card.
                  PlainBill
                  • stuartherring
                    • 11
                    Originally posted by aubrey52
                    The 5 capacitors that need to be replaced are shown on the right circled in yellow. The values and positions are as follows: C303 is 220uf 25volt, C261 is 470uf 25 volt, C241 and C244 are 1000uf 10volt and C242 is 470uf 10volt. aubrey51
                    Thanks, I will get some new caps and try reokacing those, though some of them I have already changed, admittedly with old caps from a TV set
                    Stu
                    • terry
                      • Oct 2007
                      • 91
                      Hi PlainBill
                      When I press the power button, I do not get anything, no power LED. I tested the voltage on the power switch and there is 5v, when I press the power switch this goes to 0v.
                      If use the logic card from a working monitor then everthing is ok, monitor works fine. The problem is with the logic board
                      I have add some picture of the logic board
                      Terry
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Hi PlainBill
                        Terry
                        That presents a problem. Troubleshooting the logic board requires a schematic. Without one, about all you can do is see if the regulators are working.
                        PlainBill
                        • slvfox2008
                          • Jan 2011
                          • 28
                          I noticed the logic board also has CapXon capacitors. This may be the problem why some people are having problems with their Logic Boards. I replace all the capacitors on the inverter board and still had a problem. Thats when I noticed the CapXon capacitors on the logic board. Going to change them and see what happens.
                          • terry
                            • Oct 2007
                            • 91
                            Hi, If you can please let me know if replaceing the CapXon on the Logic Board works. I have 5 HW173D and 2 HW193D with faulty Logic Boards.
                            • Rtech
                              • Jul 2010
                              • 1095
                              Interesting !!!!! in that I have had quite a few Hanns G monitors, all different models,and in the majority of cases, the Logic boards have failed.Am currently sitting with Qty 2 of HX191,with the same problem,and I doubt replacements will be available in the near future.
                              • slvfox2008
                                • Jan 2011
                                • 28
                                Replacing the CapXon Capacitors on the Logic Board did not work. Lost as what to do next.
                                • Scenic
                                  o.O
                                  • Sep 2007
                                  • 2642
                                  check the voltage regulators.
                                  seems like that area got quite hot (PCB discoloration)
                                  • slvfox2008
                                    • Jan 2011
                                    • 28
                                    Thx for the info. Being new at this, how do I go about testing?
                                    • slvfox2008
                                      • Jan 2011
                                      • 28
                                      I checked across each of the leads on the 1.8V and got a reading of 1V (cannot do 10th). On the 3.3v I got a reading of 1V.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        Let's make sure you are measuring this correctly.
                                        Put your multimeter on 20V DC (if manual). Put your black probe on a ground screw and leave it there the whole time. For each voltage regulator, put your red probe on all the pins one at a time. Report measurement for each regulator and each pin.
                                        --- begin sig file ---
                                        --- end sig file ---
                                        • meciu
                                          Lenovo M920Q - dead (my fault)
                                          by meciu
                                          So yesterday I was looking for a help because of "black screen" issue after BIOS flash.
                                          I was testing different BIOS/EC dumps found on the Internet, and I've made a big mistake..
                                          After flashing bios & ec - I've plugged mainboard only (with attached radiator) to the power adapter, and after a 1 second saw a smoke coming from motherboard.
                                          Quickly disconnected power-supply and then I saw tweezers touching PCIE bottom pins
                                          The smoke came from burned N-MOSFET PQ809 (SM2404NSANC), replaced it with greater NX7002AK N-MOSFET...
                                          08-10-2023, 03:28 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • Rictech
                                          Panasonic SA-MAX770PU SMPSU board fault....
                                          by Rictech
                                          Hello everyone. 😀
                                          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                          There are no devices that have exploded or otherwise show signs...
                                          08-26-2024, 01:05 AM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
                                          ESR meter came to the rescue again today with a PLC I/O card fault
                                          by sam_sam_sam
                                          I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                                          I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                                          One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                                          12-18-2023, 08:17 PM
