HannsG HW173D dead. Recap = new fault.
+ More Options
Posts
  • retiredcaps
    • Apr 2010
    • 9271
    #61
    Re: HannsG HW173D dead. Recap = new fault.
    Originally posted by Rtech
    Now thats the one,combined PWM and FET....
    Ahh, that makes sense now.
    Looking at page 14 and figure 24, I'm going to assume pin 1 is getting 160V DC.
    Pin 2 is GND.
    Pin 3 is vcc. C123 has already been replaced, but there is still fluctuating voltage across that cap.
    Pin 4 is feedback via optoisolator.
    So, on pin 3, the voltage is coming from the tertiary winding. It goes through R104 and D102 in figure 24. Here are the possibilites (if my schematic reading skills have improved - and using the schematic reference designations).
    a) R104 is bad. I believe R104 corresponds to the resistor just right of the big Capxon cap. Unsolder one leg of R104 and measure the ohms and compare it to the band color.
    b) D102 is bad. I believe D102 corresponds to D110 on the power board. You can test this "in circuit" to see if it is shorted. Put your multimeter on diode test. Put black on one side and red on the other. Record reading. Now reverse probes and record 2nd reading.
    A good diode should measure between 0.4 and 0.7V one way and 0L or "1" the other way.
    It might also be worth testing the diode (D12?) just above the C123 cap in case I picked the wrong diode on the power board.
    c) If R104 and D102 (D12?) are okay, then the chip itself is bad.
    --- begin sig file ---
    --- end sig file ---
    • slvfox2008
      • Jan 2011
      • 28
      #62
      Pin 2 is GND.
      A) I cannot find a R104. I have a R101(near big cap), 102, 113, & 114.
      B) Have not tested yet but D110 looks bad.
      I have a D120 but not a D12
      Going to start testing now.
      • slvfox2008
        • Jan 2011
        • 28
        #63
        The test is over for the FSC part. Shorted out the part when testing pin1 & 2! Before that pin 2 & 3 was fluctuating between 8 and 11.
        Before that happened D110 was reading .483 and OL. Part D120 was reading .480 & OL.
        Where do I go from here?
        • slvfox2008
          • Jan 2011
          • 28
          #64
          Question, when testing D110 and D120, should I have power to the board?
          If so D110 is reading .485 & OL. D120 is .002 & .002
          • el3ctroded
            • Nov 2008
            • 198
            No, never test diodes with a board powered up.
            • retiredcaps
              • Apr 2010
              • 9271
              #66
              R104 is in the schematic. I was trying to find the corresponding resistor on your board. Often the schematic pcb designations are just samples and manufacturers can follow their own standards.
              • retiredcaps
                • Apr 2010
                • 9271
                #67
                Never test diodes with power on. Remove D120 from the board and retest out of circuit.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #68
                  If you shorted it out, you will have to replace it obviously.
                  • slvfox2008
                    • Jan 2011
                    • 28
                    #69
                    Can you tell me where I can purchase one. Is there a chance that I have done other damage to the board. Is there a chance that this part was causing the other parts to fluctuate.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #70
                      1) Phone the suppliers using findchips to see when stock will be available. If not available, ask them what is an equivalent part.
                      http://www.findchips.com/avail?part=FSCM0465RG
                      2) You might have caused some other damage. Thus you might want to order 2 of the above PWM.
                      3) Yes, this part could have been bad and caused the fluctuating voltage. Now we will never know for sure.
                      4) Test the diode out of circuit. If it is bad, you can order a replacement at the same time.
                      • slvfox2008
                        • Jan 2011
                        • 28
                        #71
                        I would like to thank all of you for your inputs and patience working with me. There are several other people experiencing the same problem and it would have been nice to have fixed this so they too could repair theirs. I am in the process of trying to locate a new semiconductor, but not having too much luck. Not many company's just want to sell you one without charging a ridiculous price.
                        • Rtech
                          • Jul 2010
                          • 1095
                          #72
                          slvfox2008....where are you in th World ,as then perhaps members may be able to point you to a 'reasonable' supplier ??
                          • slvfox2008
                            • Jan 2011
                            • 28
                            #73
                            Originally posted by rtech
                            slvfox2008....where are you in th world ,as then perhaps members may be able to point you to a 'reasonable' supplier ??
                            usa
                            • tanohack
                              • Feb 2013
                              • 38
                              • Italia
                              #74
                              Has been a long time now, but my monitor had the same defect, and the problem was simply the pins in the cable that were not enough contact pressure with your fingers to see the screen .. try ...try...
                              • giovengi
                                • Apr 2013
                                • 5
                                • Italy
                                #75
                                i have the same board...
                                can anyone post values of
                                c307
                                r302
                                d303
                                thanks for any help
                                • jfriends24
                                  • Mar 2010
                                  #76
                                  hello there! is this thread still active? i have the same lcd with bloated capacitor (C850), i replaced the bad caps but it keeps on blowing up...
                                  the inverter board looks like this:
                                  http://assets.shopjimmy.com/media/ca...M/IMG_4595.JPG
                                  what else could be the problem? how can i test the circuit using fluke 8060a to know what causing the C850 to blow up? thanks in advance masters!
                                  • Lumberjack777
                                    • Dec 2010
                                    • 464
                                    #77
                                    The most common cause for an electrolytic cap to explode after repair is if it was installed backwards. Those caps have polarity and need to be installed in the right direction. The printed circuit board usually has a circle on top for these caps. And one half is shaded, or has stripes, or similar. This is the negative side of the capacitor. (The side with the stripe on the cap goes on the shaded area of the circle)
                                    • meciu
                                      Lenovo M920Q - dead (my fault)
                                      by meciu
                                      So yesterday I was looking for a help because of "black screen" issue after BIOS flash.
                                      I was testing different BIOS/EC dumps found on the Internet, and I've made a big mistake..
                                      After flashing bios & ec - I've plugged mainboard only (with attached radiator) to the power adapter, and after a 1 second saw a smoke coming from motherboard.
                                      Quickly disconnected power-supply and then I saw tweezers touching PCIE bottom pins
                                      The smoke came from burned N-MOSFET PQ809 (SM2404NSANC), replaced it with greater NX7002AK N-MOSFET...
                                      08-10-2023, 03:28 AM
                                    • double_DD
                                      How can I be sure that my EC chip is dead?
                                      by double_DD
                                      As the title suggests, how can I be sure that my EC chip is really dead?
                                      I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                      Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                      03-12-2025, 07:47 AM
                                    • Rictech
                                      Panasonic SA-MAX770PU SMPSU board fault....
                                      by Rictech
                                      Hello everyone. 😀
                                      As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                      Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                      Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                      This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                      There are no devices that have exploded or otherwise show signs...
                                      08-26-2024, 01:05 AM
                                      ESR meter came to the rescue again today with a PLC I/O card fault
                                      I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                                      I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                                      One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                                      12-18-2023, 08:17 PM
                                    • disorder
                                      ps5 edm-033 dead after hdmi/usb ports destroyed
                                      by disorder
                                      hello guys,
                                      i need help to repair a edm-033 ps2
                                      history : as always hdmi port and usb ports destroyed after unplugged
                                      after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                      so i changed it
                                      now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                      but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                      i don't see any projection of liquid metal on pcb.
                                      01-14-2025, 12:48 PM
