Viglen CRT monitor intermittent jumping
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    The picture on this monitor has stated to jump. it does improve a little sometimes when left turned on for a long time. It jerked/jumped/flickered to start with then stopped and the picture was stable for over 3 hours before i turned it off. I turned it on again today and its jumping/flickering etc again and occasionally it will stay steady for ages then give a little flicker. I tried tweaking the pots than can be accessed a little each way to find if any would help and found one pot (one on the right in photo) and when turned to full range both directions, will cause the screen to scroll and then roll round to the right or left. with careful adjustment i can almost stop it jumping/flickering but only lasts until turned off and then on again next day then i have to tweak this pot again to try and stop it. I dont think this pot has anything to do with the fault though. I have up loaded lots of photos of the monitor here:
    https://drive.google.com/drive/folde...WW?usp=sharing
    Please can anyone help me solve this as its a matching monitor for a very old but lovey vintage Viglen VIG1 286 system ive had many years.
  • sean0118
    • Jun 2016
    • 103
    Re: Viglen CRT monitor intermittent jumping
    Originally posted by roadrash
    ...will cause the screen to scroll and then roll round to the right or left. with careful adjustment i can almost stop it jumping/flickering but only lasts until turned off and then on again next day then i have to tweak this pot again to try and stop it.
    That's known as loss of horizontal sync, I think that pot sets a frequency which is used to lock the horizontal frequency of the monitor to the video source. When you turn it too far the difference in the monitor and source horizontal frequencies is too large and the sync is lost.
    With regards to the problem, when it jumps, is it also to the right/left? or up/down?
    Also, what do you have it connected to? I think this can also be caused by a bad computer graphics card too.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Check/replace the e-caps in the Vertical section (I would just replace them to be certain). Resolder the pins of the Vertical output IC.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        If the monitor is over 20 years old (which most CRTs are these days, or getting close to), it is certainly checking out some of the electrolytic caps, as Ali suggested above (but it wouldn't hurt to replace any that appear to have been in hot spots or near large heatsinks).
        Also, is this a Sony CRT by any chance?
        • roadrash
          • Oct 2015
          • 490
          • U.K.
          I had another look at this monitor today and when checking the solder side of the pcb I found a very bad connection where the solder hadn't fused to one leg of a 3 legged
          component. Not sure what it is but its marked as R102 on the pcb but it dont look like any resistor ive seen. You can see it in the picures, its just behind the AC power socket.
          When I first tried the monitor after soldering the contact on one of its legs, the monitor had a nice steady & stable display and then after a few minutes or so it started to jump and I put my finger on the top of the component and it was pretty hot and hotter than I would say is normal. Can anyone tell me what this little black plastic box with 3 legs is and Should it get really hot and should all 3 of the legs have been soldered properly? Is there any way of testing it?
          • R_J
            • 9581
            Thats the degausing thermistor. there are two thermistors inside, one across ac line I believe and one in series with the degausing coil, The one in series with the coil is 8Ω ptc, It has nothing to do with anything other than crt deqausing.
            Do like the others have said and replace the caps in the vertical circuit.
            Also replace any caps in the sync seperator circuit, The vert. and Horz. sync. signals are carried on the green video input line. In the case of the vertical, the pulse needs to be seperated from the video and fed to the vertical osc. (part ofthe vert ic likely) for synchronization. If the video signal is poor this can also effect the vertical sync signal. IE: a poor cap in the G video signal path can clip the vertical pulse causing poor sync.
              • 31157
              there is probably a lot of cracked solder joints - check everything large or bolted to a heatsink.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                +1
                also noticed it has panasonic caps and crt.
                lower probability of dead caps.
                looks like the mfr tried to make a decent unit.
                add to the above list of stuff to resolder anything that runs hot.
                like higher wattage resistors.
                • roadrash
                  • Oct 2015
                  • 490
                  • U.K.
                  Thank RJ I did measure it and it measures like two resistors a 631.3 and a 20.8Ω one. Do those values sound OK?
                  The soldering on the PCB is excellent and I could only find a few that I had to resolder.
                  iquote]Also replace any caps in the sync seperator circuit, The vert. and Horz. sync. signals are carried on the green video input line. In the case of the vertical, the pulse needs to be seperated from the video and fed to the vertical osc. (part ofthe vert ic likely) for synchronization. If the video signal is poor this can also effect the vertical sync signal. IE: a poor cap in the G video signal path can clip the vertical pulse causing poor sync.[/QUOTE]
                  Can you point me where this section is on the attached pictures with the PCB now removed from the chassis. Someone might now recognise this monitor. Its certainly very well made.
                  • R_J
                    • 9581
                    The values for the thermistor are ok, they do change over time/use. Like I said, it is only for degausing the crt at startup, thats it.
                    You can see where the rear video plug connects to the board and near it is the plug that feeds the rgb signal to the crt board, there are a couple ic's around there, ic20? and ic201, also give the number of ic601
                    Also a nice picture of the trace side of the board for that area.
                    It looks like this monitor uses a combined horz/vert drive ic (ic601) and the vertical output are two seperate transistors
                    • roadrash
                      • Oct 2015
                      • 490
                      • U.K.
                      IC601 = TDA2595
                      IC204 = MC 7812C
                      IC203 = MC 7805CT
                      IC202 = N825147N
                      IC201 = 74LS04
                      Here is another picture of the PCB hope its better this time.
                      IC604 is on the right hand side of ths picture about half way up.
                      • R_J
                        • 9581
                        The vertical output is hidding, it is under the square metal heatsink next to vr604 Likely a tda1170
                        It looks like they are not using the vertical section of ic601 as there is no trace to pin #9
                        What is the ic next to ic201, the one near the OK sticker? the plug wires are covering the last digit in the ic20?
                        • roadrash
                          • Oct 2015
                          • 490
                          • U.K.
                          Its IC202 so a N825147N. It has a diode across the top linking two pins.
                          • R_J
                            • 9581
                            That is an S not a 5 N82S147N, thats why I could'nt find any info on it.
                            • R_J
                              • 9581
                              I was wrong about the sync on green It has seperate vertical and horzontal sync inputs. So the vertical sync signal comes from the rear connector and is fed to the vertical ic sync input. likely pin 8 of the vertical ic
                              I would try replacing C318 and the other small elec. next to it
                              Its a pita without a schematic.
                              • roadrash
                                • Oct 2015
                                • 490
                                • U.K.
                                Thanks RJ I will replace all the caps as you suggest and hopefully it will cure it. It is a extremely old system that had sat unpowered for many years so its bound to have suffered a bit. I noticed that when its doing its jerking there is a tendency for the picture frame size to change its size slightly, both horizontal & vertical and occaisional gets a hozizontal line flickers across half way down the screen..
                                I might see if I can get you a short video of it when its happenng if that will help.
                                  • 31157
                                  dont damage the 82s147 series chip, it's a rom and we dont have the code to program a new one.
                                  • roadrash
                                    • Oct 2015
                                    • 490
                                    • U.K.
                                    Thanks I dont think we need to remove that but if we do I will be ultra careful. Is this one of these chips where the maker of the product its being used in programs it with thir own firmware? I had a recent experience of this with a Dell System 200 vintage PC I was repairing/restoring after the keyboard controller failed. That controller was basically a processor and had a small amount of memory for custom firmware inside. It was the same as used on the IBM's of the time but Dell used differnt firmware and without Dell's version of the firmware the PC wouldn't work. I could get a new chip but not the firmware. I was lucky to come into contact with a ex DELL employee from that era who had one OEM chip so we read the firmware out of it before putting into the PC so the vintage computer group now have a copy for the future if its needed again. The PC now works great again. Without that it would have been useless and unrepairable.
                                      • 31157
                                      yes,
                                      and you should send that firmware to MAMEDEV.
                                      https://www.mamedev.org/
                                      • roadrash
                                        • Oct 2015
                                        • 490
                                        • U.K.
                                        yes,
                                        I thought mame Dev was something to do with Arcade Machines and emulators from what I remember from my emulation days. Anyway Dumps of the Dell System 200 bios and that Keyboard firmware can be found here: http://www.minuszerodegrees.net/rom/rom.htm
                                        It was the guys over on the Vintage computer forum who worked with me to help resurect this machine when that IBM type Intel D8742 keyboard controller with the uniique Dell firmware inside failed.
                                        That was a lucky recovery that never would have happened had we not found the firmware.
                                        Should I send that firmware to mamedev too then?
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • wattage
                                          AOC AG493UCX 49-inch monitor - Firmware request
                                          by wattage
                                          Hello Badcaps Community,
                                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                          07-13-2025, 04:41 PM
                                        • ant3202
                                          HP 27es - LED monitor - Monitor Flashing On - Off
                                          by ant3202
                                          Hi Everyone
                                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                          https://www.badcaps.net/forum/troubl...lashing-on-off
                                          The monitor is HP 27es LED Monitor
                                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                          The monitor will randomly blackout and display no signal and will recover again.
                                          Sometimes need to power and off again to restore the display but...
                                          03-20-2025, 07:30 PM
                                          Wise Wing F199 19'' LCD monitor - recapped
                                          by momaka
                                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                          When I saw the Craigslist post, I wasn't...
                                          08-24-2020, 10:58 AM
                                        • sew333
                                          Pc shutdown, monitor flickered with no signal after 10 seconds
                                          by sew333
                                          My pc:
                                          10850K stock 4800mhz stock Kraken X73 good temps
                                          2x16 GB DDR4 GSKILL 3000mhz XMP
                                          Seasonic Tx-850 Ultra Titanium
                                          Gigabyte Rtx 3090 Gaming OC
                                          Aorus Z490 Pro Gaming
                                          1 TB SSD
                                          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                          Power...
                                          02-22-2022, 10:27 AM
