Viglen CRT monitor intermittent jumping
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    #41
    Re: Viglen CRT monitor intermittent jumping
    I just had to lift the cover & take a peek inside. Its prety clean except for a kind of white soft almost chalky coating over the HT lead. It might be from damp where it was kept in his garage. I didnt want to remove it in case it was a special anti-static coating that meant to be there. I am sure its not conductive. Take a look.. As soon as those probes arrive I can get back onto fuixing my monitor which I tried again yesterday and it definitely has no picture. Its a EGA monitor and I think its the only computer and monitor that I have here that uses EGA so cant test it on anything else. I cant see the PC being at fault so sure its the monitor.
    Hopefully this Scope wil now give us an answer.
      • 30977
      dont go over the rated voltage on the probes - just saying.
      and keep the probes set to x10 if they have a switch.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #43
        That looks a like a nice scope, ive got a trio 20mhz i really need too learn how to use one first though, i only got it to check lvds signals etc.
        • R_J
          • Jun 2012
          • 9535
          That scope looks like it will work just fine, I would'nt worry too much about the deposits on the high voltage leads, clean it off of you like, It looks like this scope was used in a humid/salty environment. That would not deposit on the leads unless it was in use.
            • 30977
            http://www.ionpool.net/arcade/tech/s...les/scope.html
            • roadrash
              • Oct 2015
              • 490
              • U.K.
              #46
              Thanks for that info Stj. I didnt get any probes with it and may have just ordered the wrong ones. I bought these ones as they looked like the best fit for this scope buty from what ive read I may be wrong. I have no info on what the input resistance or capacitance of this scope is. Ive seen on manuals for other ISO-TECH models of this scope that the input impedances are 1mΩ - 20Pf if that makes sense.
              Anyway hope these ones i ordered will do for now
              https://www.ebay.co.uk/itm/2x-100MHz...frcectupt=true
                • 30977
                those are o.k.
                you paid maybe a £ more than you needed, but they should be good.
                i have a pair of 6100's somewhere.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #48
                  i wasnt sure what probes too get for mine as my scope is only 20mhz i got these like you I had no info on what the input resistance or capacitance of this scope was mine was about £6.00 delivered
                  https://www.ebay.co.uk/itm/P6020-Hig...item41df7233d4
                    • 30977
                    probe frequency de-rates as the voltage rises - so higher is better.
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      #50
                      Please watch this eevblog video before going anywhere near a CRT monitor or Switch mode power supply with the scope.
                      It is very very important to know about the dangers of an oscilloscope before using it.
                      https://youtu.be/xaELqAo4kkQ
                      • R_J
                        • Jun 2012
                        • 9535
                        Thats why you need an isolation transformer when working on the hot side of a smps, on the cold side of this monitor you will be fine.
                        Even some of the early crt tv's had a completely hot chassis, so you had to be carefull and not have any ground touch the chassis when the set was open. touch a grounded cable and bang out went the bridge and fuse at a minimum. the cable input was actually isolated.
                        • roadrash
                          • Oct 2015
                          • 490
                          • U.K.
                          #52
                          That was very interesting and I must admit i never thought about the earth and mains referebced earth being differnt. But what if you just remove the mains earth connection to any equipment while you are probing. Wouldn't that isolate it from mains referenced earth making it isolated?
                            master hoarder
                            • May 2008
                            • 12170
                            #53
                            It would, most of the time (if the equipment uses isolated transformers inside for its power supplies).
                            But them using this piece of equipment can become dangerous, because it's no longer earthed, whereas you still are. Even if you put on thick shoes and think you are otherwise isolated, you could still get a minor shock when you touch something live, because of body capacitance. I've experienced that on 220/230V mains and it still hurts a bit. On 110/120V, you probably won't feel it.
                            In any case, this IS still dangerous, regardless of line voltage. One wrong move (touching something earthed/grounded while also touching live equipment/lines) and you will get shocked quite badly.
                              • 30977
                              this is on my list
                              https://www.aliexpress.com/store/pro...350679999.html
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                #55
                                Both an isolation transformer and the worse way of removing the earthing plug have the same problem:
                                Give the current a way to earth and there will be sparks.
                                Consider for example that the BNC contacts are exposed metal, so you might have 400VDC on them in a SMPS PFC section.
                                If you make a mistake that will be a very bad mistake.
                                Exactly the same will happen with stj's probes above: sure they may be 100 times attenuation so you can measure 2kV "safely"
                                Well, what happens when you hook up the earth lead to the wrong place? Boom!
                                The only safe way to do this is with an isolated probe, fuck isolation transformers and other such "tricks"
                                Full disclosure: I don't own an isolation probe, nor an isolation transformer, and I'm still alive
                                (That said I use my scopemeter for such work, so that's kinda "cheating", well, I like being alive...)
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #56
                                  how about using a 12 v car battery and a 12v to 240v inverter would that work?
                                  • roadrash
                                    • Oct 2015
                                    • 490
                                    • U.K.
                                    #57
                                    My probes didnt arive today so been rebuilding a engine instead. I think when i get to use this scope i will remove the mains earth connection and wear rubber gloves just to be safe for the time being fingers crossed my probes come tomorrow
                                    • R_J
                                      • Jun 2012
                                      • 9535
                                      You won't have a problem connecting the scope to the chassis ground on this monitor, The problem would come into play IF you needed to scope anything in the power supply HOT side.
                                      To measure scope anything in the hot side you would need to connect the scope ground to the (-) side of the bridge or main cap. This is where the problem comes into play and where an isolation transformer would be required.
                                      There is no need to lift the scope ground.
                                        • 30977
                                        should work - maybe a good use for a ups
                                          master hoarder
                                          • May 2008
                                          • 12170
                                          #60
                                          Some (if not most) UPSs use live-connected batteries... so an UPS probably won't work. But a car 12V to 120/240V inverter should be okay.
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • wattage
                                            by wattage
                                            Hello Badcaps Community,
                                            Yesterday, 04:41 PM
                                          • ant3202
                                            HP 27es - LED monitor - Monitor Flashing On - Off
                                            by ant3202
                                            Hi Everyone
                                            Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                            https://www.badcaps.net/forum/troubl...lashing-on-off
                                            The monitor is HP 27es LED Monitor
                                            https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                            The monitor will randomly blackout and display no signal and will recover again.
                                            Sometimes need to power and off again to restore the display but...
                                            03-20-2025, 07:30 PM
                                            Wise Wing F199 19'' LCD monitor - recapped
                                            by momaka
                                            Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                            I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                            When I saw the Craigslist post, I wasn't...
                                            08-24-2020, 10:58 AM
                                          • sew333
                                            Pc shutdown, monitor flickered with no signal after 10 seconds
                                            by sew333
                                            My pc:
                                            10850K stock 4800mhz stock Kraken X73 good temps
                                            2x16 GB DDR4 GSKILL 3000mhz XMP
                                            Seasonic Tx-850 Ultra Titanium
                                            Gigabyte Rtx 3090 Gaming OC
                                            Aorus Z490 Pro Gaming
                                            1 TB SSD
                                            4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                            Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                            Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                            Power...
                                            02-22-2022, 10:27 AM
