Hello everbody!
Two weeks ago my old good Samsung Syncmaster 245B Plus with a faint hiss. So I took a look into the problem and found many problems with the BN44-00195A (https://cdn.badcaps-static.com/pdfs/...f8a620fd8c.pdf) on the internet. Also here, where some users had problems with bad caps. In my case all caps are looking fine and the problem may be a bit more complicated.
After I took a look at the power board if found a blown resistor with the number RM801 (22 Ohm, 1W). The two fuses were also blown. I replaced the resistor and the two fuses and gave it another shot. What could I say. Seconds after putting the power back on the same resistor has been blown again.
So I tried to find more faulty components on the power board. It seems that the diodes DM804 and DM809 are also faulty. I tried to test them with my multimeter and current flows in both directions. As far as I can tell QM802 and QM803 are still fine.
So at the moment Iβve no clue what caused this damage and Iβm sure when I replace the diodes too everything will blow up again.
Does anybody of you had any kind of experience with this error and could provide me some hints where I have to look next? Thanks a lot!
