[Syncmaster 245B Plus] Problems with power board BN44-00195A
+ More Options
Posts
  • FredFloete
    • Oct 2016
    • 10
    Re: [Syncmaster 245B Plus] Problems with power board BN44-00195A
    Originally posted by budm
    As explained and as you can see the marking I made on the board, you still have shorted circuit on the board since the the Cm802 shows OL. You need to check those Two MOSFETs by checking the resistance between S and D pin for low resistance.
    Btw, leave out the resistor for now when checking the MOSFETs.
    So I can leave the MOSFETs in board for the measurment?
    • jean luc ferre
      laptop hp g72 b52sf screen problems
      by jean luc ferre
      on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
      the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
      i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
      i don't understand the reasons of the white stripe at the bottom of the screen below the task...
      06-07-2025, 03:27 PM
    • Hondaman
      USB problems?
      by Hondaman
      Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
      (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
      I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
      08-12-2024, 03:26 PM
    • clabr
      Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
      by clabr
      Need help to solve some problems with this laptop.
      After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
      After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
      Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
      Before this had happened I observed some other problems:
      When I tried replacing original mecanical HDD with a SSD HDD could not get them...
      12-02-2021, 08:09 AM
    • Mandor
      Samsung Syncmaster 245b BN44-00195A
      by Mandor
      Hello people.
      I have the samo problem as described in this thread:
      https://www.badcaps.net/forum/showth...highlight=245b
      The monitor was on standby and one day the screen (or just the backlight) would not turn on. Computer still recognized the monitor and was acting like it was there (5 screen setup). I switched the monitor off with the big switch by the cable, waited 5ish seconds and switched it back on. I heard a loud bang.
      Both fuses blown, resistor blown, bad mosfets.
      I checked most electrolitic caps in circuit and...
      08-06-2020, 10:19 AM
    • soopacrucial
      Samsung Syncmaster 740BF repair
      by soopacrucial
      Hi folks,
      I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
      Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
      10-29-2024, 02:40 PM
