WGM2792 Arcade Monitor Resistor Burn Off On Neck Board *Need Help*
  • proaudiosoft
    • Apr 2012
    • 68
    Re: WGM2792 Arcade Monitor Resistor Burn Off On Neck Board *Need Help*
    Originally posted by stj
    shop around if you go the "part-exchange" route - prices vary a lot
    Yes sir. I wish I had more time to mess with it, but I have too many projects going on right now. My work area is a nightmare lol. Now my wife's car is acting up, it never ends grrrr. I appreciate your help so much. I am sure we could have got it given more time. I am also sure I will need you help again sometime. If I can ever help you with anything I surely will. I build Bartop Arcades for a living, I would post my site, but I don't want to come off like I am spamming the boards. If you want it I will shoot you a pm though
    • proaudiosoft
      • Apr 2012
      • 68
      I just installed new chassis. Tube still does not glow or light? I guess I have a bad tube?
      • vinceroger69
        • Mar 2012
        • 6714
        #63
        or bad replacement boards not all sellers are genuine.
        • proaudiosoft
          • Apr 2012
          • 68
          I realize this. But this guy sounded on the up and up. He offers repair. He was even nice enough to ship me a "working" chassis with the agreement I would ship my bad one back to him. His chassis has a LED light wired in on external wires too, and it does light the led, just not the display/tube. I am guessing its about time to pull it and trash it?
          Edit: Also, I have the Naomi dip switch set to 1up 2-4 down. So it should be in 15khz mode. Unit works fine on external VGA when set @ 31khz
            • 31002
            slow down
            check the voltage on the heater pins on the back of the neck socket.
            that's ground and the pin leading to R215
            if the voltage is there, the tube is bad or pins need cleaning, if not then the chassis is bad.
            • proaudiosoft
              • Apr 2012
              • 68
              slow down
              can i do this with the neck board off the tube (@r215)? Aprox how high of voltage should I be looking for?
              When I pull the neck board off and turn the machine on I hear arcing at the flyback suction cup
              I read about 4vac on r215
                • 31002
                never power up a chassis without the tube connected - specially the ground strap from the tube body to the neckboard.
                you dont want 30,000v with nowhere to go!!
                the voltage your expecting / hoping for is 8v dc.
                DONT try to meter it from the connector P203 because one slip with your meter onto the G1 pin and you will need a new meter and probably new underwear!!
                • proaudiosoft
                  • Apr 2012
                  • 68
                  lol i hear that. I had 8vdc off my other board @ p203 (i did check it there carefully). So I am guessing this is a bunk tube. One resistor on this new board burned me, super hot! Oddly enough it is a different on that was falling off the original neckboard. I am guessing this tube probably has an internal short. Probably no sense in damaging two chassis
                    • 31002
                    as a last test, clean the neck pins with a fiberglass pencil or something.
                    • proaudiosoft
                      • Apr 2012
                      • 68
                      I did, its a bad tube. I threw that sucker in the can. I am glad I trashed that piece of junk. On a good note, I fitted a 32inch Samsung Led monitor in its place. I got a great deal on it, $180. Check out Pics! It will be a great machine when I am done with it. I took all the Naomi stuff out of it. This machine will be ready to sell in a couple days
                        • 31002
                        what dimm unit did it have?
                        and how much do you sell them for btw?
                        • proaudiosoft
                          • Apr 2012
                          • 68
                          I have the Dimm with the SCSI connection for GD-ROM (yeah, wish i had the Netdimm module), I have the GD-ROM, SCSI cable, Naomi Main unit, Power Supply, IO board, Sports Jam and key. Harness to connect all etc... I left the audio amp inside. why not, its already connected to speakers and has volume pot. Every thing had light use, it belonged to a church. Machine will sell for about $1500-$2000 with over 10,000 games on it. Adding 4 more buttons per player, changing graphics above, adding a nice bezel I will cut out. and either paint the void (on led bezel), or add graphics above and below monitor. I will have probably about $350 in it when its all said and done. I am sure I will get a couple hundred off the Naomi stuff easy. I have several other machines I am working on here as well. At the moment Silver Strike 2009. Getting ready to change out a bad Mainboard on it. The thing basically has a computer in it, along with extra boards and components of course. I might end up throwing Golden Tee and a switch on it as well
                            • 31002
                            i know mame cabs, i was a minor dev and rom supplier for a while.
                            • proaudiosoft
                              • Apr 2012
                              • 68
                              Interesting. I build bartop units mainly. goto bartop-arcade.com and check out some of my units
                                Nice, just make sure to turn down the backlights level to as low as possible to extend the life of the LED backlights.
                                • proaudiosoft
                                  • Apr 2012
                                  • 68
                                  Will do
                                    by momaka
                                    03-15-2023, 10:17 PM
                                  • ttmi100x
                                    HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                    by ttmi100x
                                    Greetings everyone,
                                    I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                    The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                    Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                    Upon closer inspection...
                                    07-31-2024, 06:36 PM
                                  • Safrilhg
                                    Look for the resistor value in the BenQ G922HDAL monitor's power supply
                                    by Safrilhg
                                    Hello guys, I had a problem where I didn't know the value of the burnt SMD resistor in the power supply circuit of the BenQ G922HDAL monitor.
                                    In one of the parts, there is a burnt SMD resistor which leads to the LD7560GS IC as shown in the picture below.
                                    How to determine the appropriate SMD resistor value for this condition? Thank You...
                                    11-06-2023, 12:43 PM
                                  • redbaron1007
                                    Arcade PSU blown resistor ID
                                    by redbaron1007
                                    I'm working on one of the PSU's in my backlog today that came out of an NBA Jam arcade machine a year or so ago. The PSU is a Pan Yes brand with a model number PY-TV-C. From what I remember the 12v rail wasn't outputting anything. I opened it up and was reminded that the resistor at R28 had blown it's shell off and I have no idea how to ID a replacement for it. (see pictures) The color bands that are still intact a little are brown, black, missing band/bands, and what I'm assuming is silver. When I check it with my DMM it's reading 100ohms exactly but I don't know if that's what it's supposed...
                                    01-06-2023, 04:13 PM
                                  • wattage
                                    AOC AG493UCX 49-inch monitor - Firmware request
                                    by wattage
                                    Hello Badcaps Community,
                                    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                    07-13-2025, 04:41 PM
