WGM2792 Arcade Monitor Resistor Burn Off On Neck Board *Need Help*
  • proaudiosoft
    • Apr 2012
    • 68
    Hello all. I just Bought a Sega Sports Jam Arcade Machine with the intent on fixing it, and maybe later converting to a mame machine. I have done many in the past The sound is heard, but the CRT monitor does not turn on @ boot. When i took the back monitor cover off the machine I found a white ceramic resistor that was just laying in the metal monitor cover. After inspecting a minute I noticed r242 was missing from the neck board, and a black spot was left behind. My question is: should I just order a replacement resistor, or should I further investigate to find out what caused the resistor to fail (and/or fall off). I am just wondering if someone could point me in the right direction of what to check for? The monitor is a WGM2792-U0TS29K, the neck board is a p858. Resistor is 10w 1.5k . I will attach pic of neck board...
  • proaudiosoft
    • Apr 2012
    • 68
    Re: WGM2792 Arcade Monitor Resistor Burn Off On Neck Board *Need Help*
    One more thing, someone suggested it fell off because of a cold solder joint. I tested the resistor (pic attached), its reading 1.333K Ohms. Is it within tolerance to reuse?
      • 30997
      dont mame it, it's waste of a real machine.
      the board has no heat marks, so it probably just fell out from cracked soldering.
      put it back and check the rest of the joints - specially on large parts.
      can you foto the factory sticker with the monitor details on it?
      as it's NAOMI based, you would be better getting a NET-DIMM board and loading games from a raspbery pi or a pc as a multi-game cab
      then you can put all this on it.
      http://www.system16.com/hardware.php?id=723
        • 30997
        yes, it's probably fine.
        strange though, naomi systems usually use a japanese monitor.
        • proaudiosoft
          • Apr 2012
          • 68
          That is exactly what I plan on doing in the near future. (rpi3) I build bartop arcades for a living. I am attaching a pic of the monitor Sticker, if this is the one you want to see.
            • 30997
            never seen that model number before.
            you know it may be medium-res right?
            i didnt mean use a pi to mame it, i meant use a pi to load games into the naomi unit.
            • proaudiosoft
              • Apr 2012
              • 68
              Yes, I know it is med res. I have Cloned sd cards with about 30 systems jam packed. No, I did not know you could run games from rpi to naomi unit. Thats awesome, how does that work exactly?
                BTW, you should remove ALL those Brown/Yellow glues off the boards.
                  • 30997
                  http://www.e-venturi.com/jamma/?page_id=1073
                  • proaudiosoft
                    • Apr 2012
                    • 68
                    Thanks, I will check out when I get this fixed. I re-Installed the resistor, still no monitor glow. I am getting a little bit of smoke, like steaming off. It looks to me like its coming from the heatsink I circled in red (attached pic). Any suggestions?
                    • R_J
                      • 9535
                      That is one of the drive transistors for the crt, (my guess is green) I suspect it is shorted and the extra current through the resistor melted the solder and it fell off.
                        • 30997
                        check between the transistor leg for shorts, although i suspect you have other problems - the heater is not related to gun-drive.
                          • 30997
                          what screen size is it, 27inch? 29inch?
                          controls - digital or pots?
                          • proaudiosoft
                            • Apr 2012
                            • 68
                            Ok, thanks guys, gonna pull it and check it out now. It is a 27".... Digital, but I don't think I have the remote...
                              • 30997
                              this may be it.
                              • proaudiosoft
                                • Apr 2012
                                • 68
                                this may be it.
                                Yes, I think it may be one in the same. They both have the p858 neck board too apparently
                                • proaudiosoft
                                  • Apr 2012
                                  • 68
                                  The Transitor is a c3502e. it appears that it is a npn type from the data sheet i found online. E C B.
                                  I get .682 base to emmiter, and .679 base to collector.
                                  emmiter to base and collector to base shows open. from what I can tell its good.
                                  what should I do from here?
                                  • proaudiosoft
                                    • Apr 2012
                                    • 68
                                    Could IC201(video amp) cause the tube to not even glow if it failed?
                                    • R_J
                                      • 9535
                                      Do you have the any of the voltages on P203? +8 volts is for the heaters, if you don't have it, check back to the power supply on D811 and R858
                                      • proaudiosoft
                                        • Apr 2012
                                        • 68
                                        Yes, I have +8.63v dc at 203, also 12.3v, and 69v but still no glow?
                                          by momaka
                                          03-15-2023, 10:17 PM
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                        • Safrilhg
                                          Look for the resistor value in the BenQ G922HDAL monitor's power supply
                                          by Safrilhg
                                          Hello guys, I had a problem where I didn't know the value of the burnt SMD resistor in the power supply circuit of the BenQ G922HDAL monitor.
                                          In one of the parts, there is a burnt SMD resistor which leads to the LD7560GS IC as shown in the picture below.
                                          How to determine the appropriate SMD resistor value for this condition? Thank You...
                                          11-06-2023, 12:43 PM
                                        • redbaron1007
                                          Arcade PSU blown resistor ID
                                          by redbaron1007
                                          I'm working on one of the PSU's in my backlog today that came out of an NBA Jam arcade machine a year or so ago. The PSU is a Pan Yes brand with a model number PY-TV-C. From what I remember the 12v rail wasn't outputting anything. I opened it up and was reminded that the resistor at R28 had blown it's shell off and I have no idea how to ID a replacement for it. (see pictures) The color bands that are still intact a little are brown, black, missing band/bands, and what I'm assuming is silver. When I check it with my DMM it's reading 100ohms exactly but I don't know if that's what it's supposed...
                                          01-06-2023, 04:13 PM
                                        • wattage
                                          AOC AG493UCX 49-inch monitor - Firmware request
                                          by wattage
                                          Hello Badcaps Community,
                                          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                                          07-13-2025, 04:41 PM
