HP W2207H Screen to Black in a second or two
  • BobT1955
    • Nov 2014
    • 13
    Turning the monitor on/off shows the image for a second then goes to black. I can read the screen using a flashlight.
    It looks like the inverter board has a few domed caps so my assumption at this point is that is the cause (see images).
    Board Front -
    Board Rear -
    Caps Side View -
    Caps Top View -
    Board Part Nbr -
    Board Rev Info -
    Performing a search I found a few sources in Asia for the 490891400101R board for $20 including shipping.
    http://www.aliexpress.com/item/Free-...976031099.html
    http://www.aliexpress.com/wholesale?...=490891400101r
    Most of the forum posts here recommend replacing the caps with quality ones. Any updated opinions on which way to go? If it's replacing the caps then what is the best source and which do I need?
    Thanks in advance for your help!
    - Bob
  • BobT1955
    • Nov 2014
    • 13
    Re: HP W2207H Screen to Black in a second or two
    Bump - I've been gone a while... no help or advice on this? Can anyone help - please?
      • 12145
      • U.S.
      good question, if your ok with the solder iron, I would try replacing those 2 bulging, low esr caps from digikey maybe, more caps could be bad but that's where I would start.
        If you get the replacement board, it will probably come with those bad caps that they should not use in the first place.
        You can get good caps from digikey or mouser. I use PANASONIC FM/FC/FR series for all my repair works.
        • BobT1955
          • Nov 2014
          • 13
          Thanks you nomoresonys and budm for the replies!
          I think I'll try the capacitor replacement first and buy the board if all else fails.
          I've done some fine soldering in the past (XBox, iPod, small and large appliances).
          I have a Radio Shack dual wattage soldering 'station' (20/40 watt). Is this OK?
          The existing two bulging CapXion caps are identical -
          1000uF 25V
          > - > (negative lead indicator)
          GF 105°C
          P740
          VENT
          Measurements -
          Diameter: 12.5 mm
          Height: 20 mm
          Lead Spacing: 5 mm
          I went to Digikey and here is what came up -
          Digi-Key Part Number: P12379-ND
          Manufacturer: Panasonic Electronic Components
          Manufacturer Part Number: EEU-FM1E102
          Description: CAP ALUM 1000UF 25V 20% RADIAL
          Lead Free Status / RoHS Status: Lead free / RoHS Compliant
          Full specs at link: http://www.digikey.com/product-searc...ader=search_go
          Would this be an acceptable replacement for the two bulging caps?
          Do I need to replace the "white glue" with some other adhesive (RTV?) after the caps are replaced?
          Thanks again for both of your help! (can you hear my sigh of relief? )
          - Bob
          • BobT1955
            • Nov 2014
            • 13
            Thanks for the reply! I've posted a response to you and another member who replied to my question. I didn't think to post my full response to each of you individually to auto-notify you - sorry.
            • GameMaster1229
              Oh nice! The HP w2207 monitor! I have replaced and fixed about 5 of these monitors! These monitors almost always bulge at the same spot and yes those caps are almost always to blame! Once those caps are replaced with quality caps, your monitor shall return to stable power.
              • BobT1955
                • Nov 2014
                • 13
                Can I ask what caps you used? I had a few other questions in my post #5 above. Can you help with those as well?
                Thank you!
                - Bob
                  FM/ FR/FC are all OK to use, no need to put the glue back on.
                  • BobT1955
                    • Nov 2014
                    • 13
                    I've been traveling a bit and will be for a little bit more. I haven't been able to order the caps or work on the repair yet but will do so when I can.
                    Please keep this thread open.
                    Wishing all a happy and healthy 2015!
                    - Bob
                    • selldoor
                      Slow Learner
                      • 7870
                      Threads do not close just come back on when you are ready, if you need help,
                      or just to tell us its fixed.
                      Best wishes to you also.
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • TheDando
                        MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 Screen Connector
                        by TheDando
                        Hey guys I've got a MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 with a broken screen connector on the motherboard.I was wondering how I would go about finding a exact replacement for it.I can't seem to find any schematics that would help me so I'm kinda stumped.I did buy a screen connector that I thought was close enough but it doesn't really invoke much confidence in me that it works perfectly as plugging the screen into sometimes does output a "glitchy" image for just a few seconds.So now I'm kinda in a cross road where I'm pretty sure it could be a faulty screen but I...
                        10-28-2024, 06:59 PM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • mrtek
                        Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                        by mrtek
                        Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                        11-26-2024, 09:58 AM
