Dell 2007WPF Flickering Off
  • aatroxed
    • May 2014
    • 24
    My trusty Dell monitor is having issues and flickering off, sometimes for minutes at a time. The front panel buttons still glow yellow as usual, so power is still going through. When it flickers off and the dvi input is disconnected, it doesn't show the usual "no input signal" image so I'm pretty sure the problem is isolated to the monitor.
    After much effort I managed to take it apart (I'm a newbie) but can't readily identify any points of failure.
    Here we go. (I just realized the backs are useful as well. I'll those up soon if these are not clear).
    Re: Dell 2007WPF Flickering Off
    It looks like one (next to the middle inverter transformer) of the 3 caps on the inverter board has domed top, or is it just the reflection.
    You may also want to read this thread:
    https://www.badcaps.net/forum/showth...007#post447545
    BTW, when it flickers off, does the LED on the front panel also flick off?
    • aatroxed
      • May 2014
      • 24
      No the LED on the front panel stays steady the whole time.
      Are you referring to the inverter transformer in the first picture and the two small black domes near the power supply plug on the right hand side?
        OK, the first picture is the power supply board, the second picture is the inverter board and 3 black inverter transformers. Now, do you see the cap with domed top?
          • 31154
          it is domed, the 3rd side-angle pic confirms it.
          goto say btw, i think that's the best set of foto's i'v seen someone post.
          what cam was it?
          • aatroxed
            • May 2014
            • 24
            @stj Thanks, I read a few posts and knew you guys need good photos to help
            Just an old nikon coolpix s6200 point and shoot I had lying around.
            I took a few more picks of the inverter to make sure. If it is indeed bloated, you think a swap could fix it? Does it sound like its the source of the problem I described?
            Can you visually tell if that fuse is dead?
            I also included pictures where there's some glue. How would you go about removing the glue to check the components underneath?
              I would replace all 5 on that inverter board since we already see that you have bad caps. You have to use Ohm meter to check the fuse,
              • aatroxed
                • May 2014
                • 24
                I'm not technical to do it on my own so I'll have to take it in to a shop / repair guy. If the cost is much higher than a replacement, do you think its safe to go with this: http://www.aliexpress.com/item/Free-...557005607.html
                Would you go for a used part or try to scrounge for a new board?
                • Lumberjack777
                  • 464
                  This is a great example of different options for different people.
                  For me, I'd simply replace those caps, and I'd pay 5 to 6 bucks at the most.
                  That board from Aliexpress appears to have the same Elite caps; so it will most likely fail again someday. But at least it will work for you.
                  But if some repair shop is going to charge you $25 at least to repair it. Well, who knows.
                  If you can find somebody to solder the new caps for $10 or $15, that'd probably be the best option.
                  • aatroxed
                    • May 2014
                    • 24
                    What brand of caps might you use? The Elite, while they did fail, that was after 8 years.
                      • 31154
                      i would use panasonic FR series,
                      but everybody has there own favourites.
                      • bammbammfran
                        • Apr 2014
                        • 476
                        actually 8 years is not bad considering some I have seen
                        part number P12383-ND at digikey,com for the 220 x 25
                        Not sure what size the two small ones are ?
                        as Lumberjack said (no telling how long a used one will last)
                        and while it is apart, I would do the power supply too
                          I used PANASONIC FM/FR/FC series.
                          • aatroxed
                            • May 2014
                            • 24
                            Great news. Found a local who said he can fix the panel for me. I did forget to mention to use quality caps, hopefully he knows better.
                            Thanks everyone. Yall been awesome diagnosing this. I will update later. Now hopefully I haven't forgotten how to put it back together...
                            • aatroxed
                              • May 2014
                              • 24
                              Good news and bad news. The capacitors were replaced. All 3 big ones but the problem persists. It's so depressing, I really thought I had it in the bag.
                              As you can see, monitor is on and power button is yellow (its orange when computer is off) but screen is black.
                              Any other ideas?
                              Anyone think this might be related to my PSU + GPU?
                              • jetadm123
                                • 2169
                                1) check fuse on inverter board.
                                2) verify new inverter caps are correctly installed.
                                3) re-seat wiring harness on inverter.
                                4) re-seat inverter ccfl connectors.
                                5) measure voltage at fuse on both sides with respect to ground.
                                • bammbammfran
                                  • Apr 2014
                                  • 476
                                  looks lit in the picture ????
                                  Try it in a dark room or look at the monitor from the back (this might show light leaking out through some small holes
                                  post a full picture of the back ?
                                    It sure does looks like the backlights are on. Did you put the LVDS cable back in place correctly?
                                    • aatroxed
                                      • May 2014
                                      • 24
                                      I will post pics but the monitor does turn on and I can use it. It just turns off intermittently for minutes at a time and at random. It's been fine for past 5 hours for example.
                                      • bammbammfran
                                        • Apr 2014
                                        • 476
                                        well, that is not what you posted the first time !!
                                        "As you can see, monitor is on and power button is yellow (its orange when computer is off) but screen is black."
                                        Might be weak bulbs, could be a power supply issue which is why I recommended changing those caps too while it was apart
                                        • Borse2008
                                          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                          by Borse2008
                                          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                          • There’s
                                          07-15-2025, 04:55 AM
                                        • reessi
                                          ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                          by reessi
                                          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                          They are black on the right and gradually fade to nothing on the far left.
                                          They start either after 5 mins or up to 2 hours after so annoying for testing.
                                          They flicker continuously very fast! With a slight pause milli-second every second.
                                          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                          I tested each half by removing the first the left flex from...
                                          06-03-2025, 09:58 AM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
