Benq v2210 Eco - one backlight strip not working
  • selldoor
    Slow Learner
    • 7870
    Re: Benq v2210 Eco - one backlight strip not working
    David-p - I am not sure you are following this at all - I believe the mosfets are within the OZ9955A have you looked at the pdf?
    OP -I dont know how far you got with the test flow chart - last thing it says to test are the inductors - the coils with the 330 on top - THink you can only test for continuity on the two contacts.
    Can you get a better picture of the faulty part of the board - without the flash.
    I am also reading the part where budm says
    There is OVP pin which will shut down the circuit if the Vout is too high (such as over voltage from the power supply or no LEDs attach so the voltage will rise up high), you should check the OVP of the working and not working IC.
    Check the socket and make sure the pins are soldered correctly to the board
    and no pins are badly bent or even missing. (it has happened!)
    I have assumed so, but can you confirm nothing on the back of the board
    • martinlink
      • Mar 2012
      • 19
      • Estonia
      I am consulting a more technically skilled person today, let's hope he can figure it out. If not, I'll have more time to mess with it later.
      The underside of the small green board can't be really accessed since it is soldered onto the larger board, so I can't check the inductors from the connector, but I will try to test their "legs"...
      The ICs are ultra small and checking their pins is nearly impossible without a microscope (which I will have access to in the future, but not at the moment). Also the head on my soldering iron is far too large to resolder them one by one.
      • selldoor
        Slow Learner
        • 7870
        Hi - heheh hadnt realised the green board was actually attached !!
        The socket and pins (contacts) I meant were the the socket the lamp plugs into
        if that is faulty it could give the lamps not connected fault.
        And yes inductors test where they are soldered to the board
        • martinlink
          • Mar 2012
          • 19
          • Estonia
          Red squares around parts I found to be out of spec before handing it over to the "fixer":
          R522 - 0 (should be 10K?) - fully shorted out, also small black spot in the middle
          R520 - 16,2K (should be 100K)
          R530 - 14,2K (should be 30K)
          I hope those bits are easy to find and cheap to replace :P
          Then again, there might be something else wrong with it as well, didn't go over all the pieces.
          • selldoor
            Slow Learner
            • 7870
            They should be easy to find usual problem is not knowing the value having the schematic is a great bonus.
            Maybe it is just the burnt out one that is at fault as it is coming up shorted- if you tested in circuit. the others that have a measurable value may be affected by other components they connect to.
            Please let us know how it goes.
            • martinlink
              • Mar 2012
              • 19
              • Estonia
              #26
              Yeah, I'll be sure to update if anything new happens.
              The reason I had to take it to the tech guy is, I have a couple of exams coming up in the very near future and all my study materials are on the PC, which has no monitor. So there's a bigger chance of getting it working sooner so I can start studying.
              If I had a replacement monitor, I wouldn't be in such a rush right now damn this student life without a penny to spare on a new monitor...
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4301
                • Italy - Milan
                #27
                @selldoor, i was referring to the service man. where the mosfet is external.. also there the pinout of the chip seems different from the budm document where pin 1 is SW, in SRV.MAN. there are 2 pins SW1, SW2 where i'm not sure what they does.. anyway it will probably end up with a faulty IC.. but without instrument for soldering...
                  Per diagram: R522 is 10 Ohms, it is used as fusible resistor to provide b+ to the IC VIN.
                  Those resistors are connected in series and parallel with other resistor network, so the reading will not be valid when measured on board.
                  This will be real hard to repaired due the board is soldered on to the main board that you cannot get access to the bottom side, I am sure there are more parts under the boards.
                  At this point I am even sure if the SCH actually match the board.
                  • RethoricalCheese
                    • Mar 2013
                    • 1517
                    • Estonia
                    #29
                    I can see between those two boards and there are no more parts there.
                    (I have the monitor at the moment)
                    Okay, so I started with testing all the resistors on one side and then the other side.
                    The only difference I found was that R527/528 have 450k/470k accordingly,
                    the other side has R511/512, which are 175k/180k accordingly.
                    Other resistors, diodes and coils show same values.
                    Edit:
                    By removing C522 and C520, all those 4 resistors had same value. Soo... Just a faulty capacitor?
                    The problem is.. I don't have a 10uF capacitor sitting around anywhere.
                    Or how high does the voltage reach there? Found a 10uF 50V only.
                    • selldoor
                      Slow Learner
                      • 7870
                      #30
                      I thought C522 was the one that had just been replaced?
                      Wouldnt have thought both caps could be bad as the lights light on the good half?
                      Was the resistor R522 burnt out?
                      I dont know the max voltage - v out only seems to be 17v.
                      If you have the monitor can you start up the boards and test the voltage
                      at the cap on the good side?
                      • RethoricalCheese
                        • Mar 2013
                        • 1517
                        • Estonia
                        #31
                        Yeah, it had been replaced, just wanted to test without caps.
                        Soldered them back on like they were - good side has 17V on cap, bad side has between 1 and 2 volts.
                        • selldoor
                          Slow Learner
                          • 7870
                          #32
                          Budm had suggested that the resistor R522 was a fuse resistor so if it has burnt out or partially failed might that cause the low voltage on the cap?
                          Does it have any resistance?
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4301
                            • Italy - Milan
                            #33
                            if the presence of that cap alters the resistors reading why don't you test it in ohms for short?
                            • RethoricalCheese
                              • Mar 2013
                              • 1517
                              • Estonia
                              #34
                              R522 is 14 ohms, R507 is 10.7 ohms.
                              Cap is not shorted, tested already.
                              And tried to see if the cap caused that low voltage - wasn't the case.
                              • RethoricalCheese
                                • Mar 2013
                                • 1517
                                • Estonia
                                #35
                                I found out that bad side coil just had a bad solder. Resoldered it - shows around 17V now. The problem is - no backlight.
                                I will test voltages on C501/502 later.
                                • Gjackson
                                  Question about UE60JU6800K backlight power.
                                  by Gjackson
                                  got my hands on a Samsung UE60JU6800K, initially it apparently had a bunch of white circles on screen which I confirmed was due to loose diffusers when I opened the set up and found a mountain of them at the bottom. The person I got if from stored the TV unused for a lengthy period after this so when I got it the backlight was completely gone. I took out the strips and almost all of the LED's have a crack on the yellow phosphor form the center of the LED outward, the ones that don't have this crack seem to work still (Maybe due to humidity after a long period?). Anyways I...
                                  06-11-2024, 06:03 AM
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                • edugimeno
                                  Help findinf LED strips for TDSystems K32DLT1H
                                  by edugimeno
                                  Hi There!
                                  I bought a broken 32" TV today. It has sound but no image. I checked with a flashlight and it was missing backlight
                                  Disassembled down to the led strips and found this TV has been serviced before. Not sure if it was fixed, worked again for some time, and broke again, or maybe last repair wasn't successful
                                  Looks like on previous repair, the center LED strip was replaced with a different model, 7 leds in it instead of 8, but when checking LEDS one by one, leds on the center strip were brighter with same test voltage (multimeter in DIODE mode) so maybe the...
                                  11-05-2022, 03:36 PM
                                • DanPoka
                                  Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                  by DanPoka
                                  I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                  Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                  This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                  02-15-2025, 05:05 AM
                                • Comp_Pro
                                  No Backlight Macbook A1990 820-01041
                                  by Comp_Pro
                                  Hello all,
                                  Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                  Tests performed:
                                  There is no backlight even with a good screen.
                                  Backlight IC is receiving the correct support voltages.
                                  Fuse F8400 ok
                                  Current sense resistor R8400 ok
                                  Backlight IC is receiving 3.3V on enable pin.
                                  Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                  Backlight IC receiving 5V from PP5V_G3S
                                  Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                  I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                  05-06-2024, 10:23 PM
